Adjustment
Brake Pedal
- Loosen the stopper nut
- Measure height of pedal. It should be 143.5 mm. Insert shims on outside of firewall until height is 143.5 mm
- Tighten stopper until height is 139.5 to 143.5 mm. Tighten stopper nut.
- Double-check free play (5-15 mm)
- Double-check total travel of pedal (120mm)
Clutch Pedal
See:
Accelerator Pedal
Pedal bushing: B10, B110, B210 & B310 USA & JDM:
- 46525-18000 BUSHING-pedal fulcrum (2)
- replaced by 46525-N8200 0880-up $1.64 USD
- 46512-H0101 RUBBER-BRAKE PEDAL STOPPER $3.00 USD
- 46531-18001 COVER-PEDAL PAD for BRAKE MANUAL $2.52
- 46531-20301 COVER-PEDAL PAD for BRAKE AUTOMATIC NLA
- 46525-18000 BUSH-PEDAL FULCRUM for CLUTCH $1.64 USD
- 46531-M3000 COVER-PEDAL PAD for CLUTCH $2.52 USD
- formerly 46531-18001
46520-H1603 ASSY-PEDAL BRAKE 46520-H1602 ASSY-PEDAL BRAKE 46520-H1702 ASSY-PEDAL BRAKE 46525-18000 BUSH-PEDAL FULCRUM 46512-H0101 RUBBER-BRAKE PEDAL STOPPER 46531-18001 COVER-PEDAL PAD 46531-M3000 COVER-PEDAL PAD 46531-20301 COVER-PEDAL PAD 46560-18000 PIN-PEDAL FULCRUM 46483-10800 SPACER-PEDAL SHAFT 08915-14010 WASHER-LOCK M10 08911-14010 NUT-HEX M10X1.25 46559-20300 TUBE-FULCRUM 46123-78500 PIN-CLEVIS 46123-A0600 PIN-CLEVIS 46123-E6600 PIN-CLEVIS 34485-14805 PIN-SPRING 01532-00031 PIN-SNAP 46585-H1000 SPRING RETURN PEDAL 46510-18001 STOPPER-PEDAL 08911-30810 NUT-HEX GAM M8X1.25
