Weber DGV Adapters
Revision as of 06:14, 7 August 2011; view current revision
Category: Fuel System
The Weber 32/36 (DGV) carburetor has a larger bolt pattern than the stock Hitachi on a Datsun A-series engine. You can modify the stock manifold, or use an adapter plate.
10870.jpg Comparo
You can make a DGV-compatible intake:
But most of us use an adapter plate:
Adapters for many models are available for sale, but I made my own adapter for the Nissan A12 engine out of a block of aluminum:
    Custom machined adapter (left) and kit-provided cast adapter
Plate Numbers
Fits all with 80mm x 43mm carb base
Chrysler/Mitsubishi Colt, Galant,Lancer, Sigma
- Citroen CX2200, CX2400
- Daihatsu with 80mm x 43mm carb base
- Datsun 1600, 180B, 200B, 240K, 260C, Bluebird, 510, 610
- Fiat 125 coupe, X-19, 131
- Ford Courier with mazda engine
- Holden Gemini 1600 OHC (Isuzu)
- Isuzu, Bellet, Gemini, Luv
- Mazda 1200, 1300, 808, 323 rear wheel drive model, 1500, 1800,929,
  Capella 121, mazda 1400
- Mitsubishi Express L300, Mitsubishi Colt, Galant,Lancer, Sigma
- Toyota corolla 1100,1200 1300 1966-1984
3K,4K 5K, 1983-1987 corolla/sprinter/seca
Corona, Celica, Crown, Celica 1600 TA22 1971-75
Make Your Own Plate
  1. Dimensions: 1 x 2.75 x 5 inches (minimum would be approximately 10 x 6.7 x 11.4 mm)
  2. Using a Nissan gasket as a template on one side, and the Weber gasket on the other, mark the holes.
  3. Drill two bores ~30mm and 27mm to match the intake manifold. You might have a machine shop do this; I had access to a lathe with a large bit chuck into it.
  4. Drill and Countersink holes for stock Nissan pattern using a drill press to get them straight.
  5. Thread holes for Weber pattern
  6. Use a round rasp file to smooth out the transition from the small Nissan bore holes to the larger Weber holes you drew from the template
2976.jpg Kit
3038.jpg Experiments
11589.jpg 11590.jpg 11591.jpg 11596.jpg 3067.jpg 5178.jpg 5315.jpg 7235.jpg ttp://datsun1200.com/uploads/thumbs/7236.jpg 11270.jpg
