The "Knuckle arm" (steering arm) is sandwiched between the Ball Joint and the strut assembly.
There is only one size for B110, the 45mm strut type. But it comes in two versions: 1970-1975, and 1976-up.
Datsun knuckle arms come in two basic sizes, 75mm & 80mm:
- narrow bolt spacing for 45mm strut tubes (used by B110)
- wide bolt spacing for 50.8 mm strut tubes (used by most other Datsuns)
Additionally, the size of the taper hole for the ball joint is important.
- B110 and B210 and B310 small uses the small taper
- Some B310 use a large taper
Then there is the length of the arm -- long arm give a slower steering response, but less effort is required to turn the wheels. Shorter arms give faster response.
Short-arm Modified for use with 2" struts
The large-size B310 arm (commonly used when swapping struts) will change your 15:1 steering to an effective 16:1 as it is 9% longer.
Comparison
It seems B310 with W5000/W5060 steering arm uses the same size tie-rod ends as the smaller units (B110 and B210).
Knuckle Arm
B120 early +H1000/H1025 rod assy H1000/H5000
B120 7510- +H1025 rod assy H7400 -8507 H7440 8508-
B210 early +H5025 H5000 H7400 late van
B210 late +H5025 rod assy H7400
PB210/USA B210 +H5800 rod assy U0101
B310 +W5025 rod assy H7400 regular cars W5000/W5060 power cars
steering arm
40052 = Knuckle Arm RH
40053 = Knuckle Arm LH
Knuckle Arm RH
- B10: 40052-18000 (different from newer models)
- B110: 40052-H1000 <- 40052-H5000
- PB110: 40052-H2501
- B120: 40052-H5000 to 1974, 40052-H7400 (75-8504), 40052-H7440 (8504-)
- B210: 40052-H5000 (74-75 A12)
- B210: 40052-H7400 (1976-up A engine, except USA)
- B210: 40052-U0101 (USA, also PB, also L16)
- B310: 40052-W5000 (All US, all A15, most A14)
- B310: 40052-H7200 (A12, A13, and budget A14 models)
- B310: 40052-W5060 (big engines, 8001-up)
Spacers
When Lowering the front suspension, if going ultra-low, strut spacers (roll center adapters) are used. They are intended to correct the lower arm angle when the vehicle height is dropped, to minimize bump steer.
ロールセンターアダプタ
