Also see:
Part Numbers Index Main articles for usage, photos, cross-reference * Distributor & contact points set * Coil * Spark plugs
1 22180-71200 RING-"0"DISTRIBUTOR SUPPORT A12 2 08110-61210 BOLT-HEX FIXING DISTRIBUTOR TO BLOCK A12 3 08915-13610 WASHER-LOCK FIXING DISTRIBUTOR A12 4 08915-43610 WASHER-PLAIN FIXING DISTRIBUTOR A12 5 22318-18000 TUBE-DISTRIBUTOR VACUUM ADVANCE A12 -370 0 5 B2318-73002 TUBE-DISTRIBUTOR VACUUM ADVANCE(5M) A12 0470- 2 22318-18000 6 22328-H1000 CLAMP-TUBE VACUUM CONTROL A12 6 22328-H1001 CLAMP-TUBE VACUUM CONTROL A12 -370 0 6 22328-H1002 CLAMP-TUBE VACUUM CONTROL A12 0470- 2 22328-H1000 7 22450-18228 SET-CABLE HIGH TENSION A12 7 22450-H1025 SET-CABLE,HIGH TENSION A12 2 22450-18228 8 22450-18201 CABLE-HIGH TENSION COIL TO DISTRIBUTOR A12 8 22450-18202 CABLE-HIGH TENSION COIL TO DISTRIBUTOR A12 1271- 2 22450-18201 9 22451-18200 CABLE-HIGH TENSION NO.1 A12 9 22451-18201 CABLE-HIGH TENSION NO.1 A12 0671- 2 22451-18200 10 22452-18201 CABLE-HIGH TENSION NO.2 A12 2 22452-18200 10 22452-18200 CABLE-HIGH TENSION NO.2 A12 11 22453-18201 CABLE-HIGH TENSION NO.3 A12 2 22453-18200 11 22453-18200 CABLE-HIGH TENSION NO.3 A12 12 22454-18200 CABLE-HIGH TENSION NO.4 A12 12 22454-18201 CABLE-HIGH TENSION NO.4 A12 2 22454-18200 13 22433-14806 COIL-IGNITION(HITACHI) A12 13 22433-14606 COIL-IGNITION(HITACHI) A12 5 22433-14806 13 22433-A5400 COIL-IGNITION (HITACHI) A12 0671-0672 22 22433-14606 13 22433-U2000 COIL-IGNITION (HITACHI) A12 0772- 5 22433-A5400 13 22433-14816 COIL-IGNITION(HANSHIN) A12 13 22433-14616 COIL-IGNITION(HANSHIN) A12 5 22433-14816 13 22433-A5410 COIL-IGNITION (HANSHIN) A12 0671-0672 22 22433-14616 13 22433-U2010 COIL-IGNITION (HANSHIN) A12 0772- 5 22433-A5410 14 22460-14606 RESISTER-IGNITION COIL (HITACHI) A12 14 22460-U2210 RESISTER-IGNITION COIL (HANSIN) A12 0772- 2 22460-14615 14 22460-U2200 RESISTER-IGNITION COIL (HITACHI) A12 0772- 2 22460-14606 14 22460-14615 RESISTER-IGNITION COIL (HANSHIN) A12 15 08513-61212 SCREW-MACHINE M6 IGNITION COIL TO BODY 2 A12 16 08915-53610 WASHER-PLAIN M6 IGNITION COIL TO BODY 2 A12 17 22401-A4804 PLUG-SPARK L44PW(HITACHI) 4 OP A12 17 22401-A4617 PLUG-SPARK 4 A12 2 22401-75507 17 22401-75507 PLUG-SPARK BP-7E(N.G.K) 4 OP A12 17 22401-75500 PLUG-SPARK BP-6E(N.G.K) 4 A12 17 22401-75504 PLUG-SPARK BP-4E(N.G.K) 4 OP A12 17 22401-A4707 PLUG-SPARK L47PW(HITACHI) 4 OP A12 2 22401-21007 17 22401-21007 PLUG-SPARK L47P(HITACHI) 4 OP A12 17 22401-21005 PLUG-SPARK L45P(HITACHI) 4 OP A12 17 22401-A4704 PLUG-SPARK L47PW(HITACHI) 4 OP A12 17 22401-21004 PLUG-SPARK L44P(HITACHI) 4 OP A12 17 22401-A4706 PLUG-SPARK L46PW(HITACHI) 4 A12 2 22401-21000 17 22401-A4705 PLUG-SPARK L45PW(HITACHI) 4 OP A12 6070- 2 22401-21000 17 22401-21000 PLUG-SPARK L46P(HITACHI) 4 A12 17 22401-A4605 PLUG-SPARK BP-5ES(N.G.K) 4 A12 2 22401-75500 17 22401-A4616 PLUG-SPARK BP-6ES(N.G.K) 4 OP A12 0570- 2 22401-75500 18 11710-H0100 BRACKET-ALTERNATOR A12 19 08131-02210 BOLT-HEX M10 FIXING ALTERNATOR B 2 A12 20 08915-14010 WASHER-SPRING M10 FIXING ALTERNATOR B 2 A12 21 08130-83010 BOLT-HEX M8 ALTERNATOR FIXING 2 A12 22 08911-20810 NUT-HEX M8 ALTERNATOR FIXING 2 A12 23 08915-43810 WASHER-PLAIN M8 ALTERNATOR FIXING 2 A12 24 08915-13810 WASHER-SPRING ALTERNATOR FIXING 2 A12 25 11715-18001 BAR-ADJUSTING ALTERNATOR A12 25 11715-H2300 BAR-ADJUSTING ALTERNATOR A12 2 11715-18001 25 11715-M0100 BAR-ADJUSTING ALTERNATOR A12 2 11715-H2300 26 08110-81610 BOLT-HEX M8 BAR FIXING A12 27 08915-13810 WASHER-SPRING A12 28 22401-A4725 SET-IGNITION(HITACHI) A12 29 22401-A4706 PLUG-SPARK(L46-PW) 4 A12 30 22145-18005 SET-CONTACT A12
