Also see:
Part Numbers Index Main article for usage, photos, cross-reference Fender (guard/wing) Hood (bonnet) Mirrors Core Support
Sedan
1 62500-H1000 ASSY-SUPPORT,RADIATOR CORE SEDAN 2 62512-H1000 RAIL-SUPPORT,RADIATOR CORE, UPPER SEDAN 3 62522-H1001 STAY-HOOD CATCH SEDAN 4 62612-H1000 PANEL-APRON,FRONT SEDAN 5 63100-H1900 ASSY-FENDER,FRONT,RH SEDAN 6 63101-H1900 ASSY-FENDER,FRONT,LH SEDAN 7 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) SEDAN 8 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) SEDAN 9 63810-H1001 SEALER-COWL TOP(L=250MM) (2) SEDAN 0670- 9 63810-H1000 SEALER-COWL TOP(L=200MM) (2) SEDAN 10 63811-H1000 SEALER-FRONT FENDER (2) SEDAN 11 64100-H1000 ASSY-HOODLEDGE,RH SEDAN 11 64100-H3100 ASSY-HOODLEDGE.R.H. SEDAN 1271- 11 64100-H7000 ASSY-HOODLEDGE,RH SEDAN 0772- 12 64101-H1000 ASSY-HOODLEDGE,LH SEDAN 12 64101-H7000 ASSY-HOODLEDGE,LH SEDAN 0772- 13 24420-21401 FRAME-BATTERY,FIX SEDAN 13 24420-J0600 FRAME-BATTERY,FIX SEDAN 14 24440-21000 ROD-BATTERY,FIX (2) SEDAN 14 24422-18001 ROD-BATTERY,FIX (2) SEDAN 14 24438-21000 ROD-BATTERY,FIX (2) SEDAN 15 24427-H1000 STAY-BATTERY BRACKET SEDAN 15 24427-H1001 STAY-BATTERY BRACKET (2) SEDAN 16 77720-89910 BOLT-SPECIAL (3) SEDAN 16 77720-89913 BOLT-SPECIAL (3) SEDAN 17 24428-19102 TRAY-BATTERY SEDAN 17 24428-89920 TRAY-BATTERY SEDAN 1170- 18 08911-10610 NUT-HEX (2) SEDAN 19 08915-43610 WASHER-PLAIN (2) SEDAN 19 08915-4361A WASHER-PLAIN (2) SEDAN 20 65100-H1000 ASSY-PANEL,HOOD SEDAN 20 F5100-G1902 ASSY-PANEL,HOOD SEDAN 21 65400-H1001 ASSY-HINGE,HOOD,RH SEDAN 22 65401-H1001 ASSY-HINGE,HOOD,LH SEDAN 23 65409-H1000 PIN-HINGE,TO BRACKET (2) SEDAN 65409-80W00 PIN-HINGE,TO BRACKET (2) SEDAN 24 08915-13810 WASHER-LOCK,HINGE TO BRACKET (2) SEDAN 25 08110-61210 BOLT-HEX,HINGE TO HOOD (4) SEDAN 26 08915-43610 WASHER-PLAIN,HINGE TO HOOD (4) SEDAN 27 08915-13610 WASHER-LOCK,HINGE TO HOOD (4) SEDAN 28 65510-H1000 ROD-HOOD SUPPORT SEDAN 28 65510-G1200 ROD-HOOD SUPPORT SEDAN 29 65512-H1000 GROMMET-ROD,HOOD SEDAN 29 65512-H2500 GROMMET-ROD,HOOD SEDAN 1070- 30 65514-H1000 CLAMP-ROD,HOOD SEDAN 30 65514-55W00 CLAMP-ROD,HOOD SEDAN 31 96302-H1900 ASSY-DOOR MIRROR LH SEDAN 96301-H5950 ASSY-DOOR MIRROR RH SEDAN 31 96302-H5950 ASSY-DOOR MIRROR LH SEDAN 32 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) SEDAN
Coupe
1 63100-H1900 ASSY-FRONT FENDER RH COUPE 2 63101-H1900 ASSY-FRONT FENDER LH COUPE 3 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) COUPE 4 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) COUPE 5 63810-H1001 SEALER-COWL TOP (2) COUPE 0670- 2 63810-H1000 5 63810-H1000 SEALER-COWL TOP (2) COUPE 6 63811-H1000 SEALER-FRONT FENDER (2) COUPE 7 64100-H1000 ASSY-HOODLEDGE RH COUPE 7 64100-H3100 ASSY-HOODLEDGE R.H. COUPE 1271- 5 64100-H1000 7 64100-H7000 ASSY-HOODLEDGE RH COUPE 0772- 0 64100-H3100 8 64101-H1000 ASSY-HOODLEDGE LH COUPE 8 64101-H7000 ASSY-HOODLEDGE LH COUPE 0772- 0 64101-H1000 9 24420-J0600 FRAME-BATTERY FIX COUPE 2 24420-21401 9 24420-21401 FRAME-BATTERY FIX COUPE 10 24440-21000 ROD-BATTERY FIX C (2) COUPE 2 24438-21000 10 24438-21000 ROD-BATTERY FIX A (NOT ADOPTED (2) COUPE 11 24427-H1000 STAY-BATTERY BRACKET COUPE 11 24427-H1001 STAY-BATTERY BRACKET (2) COUPE 2 24427-H1000 12 24428-19102 TRAY-BATTERY COUPE 12 24428-89920 TRAY-BATTERY COUPE 1170- 2 24428-19102 13 08911-10610 NUT-HEX M6X1.0 (2) COUPE 14 08915-43610 WASHER-PLAIN M6 (2) COUPE 15 65100-H1000 ASSY-PANEL HOOD COUPE 16 65400-H1001 ASSY-HINGE HOOD RH COUPE 17 65401-H1001 ASSY-HINGE HOOD LH COUPE 18 65409-H1000 PIN-HINGE HOOD HINGE TO BRACKET (2) COUPE 19 08915-13610 WASHER-LOCK M6 HINGE TO BRACKET (2) COUPE 20 08110-61210 BOLT-HEX M6X1.0 HINGE TO HOOD (4) COUPE 21 08915-43610 WASHER-PLAIN M6 HINGE TO HOOD (4) COUPE 22 08915-13610 WASHER-LOCK M6 HINGE TO HOOD (4) COUPE 23 65510-H1000 ROD-HOOD SUPPOUT COUPE 24 65512-H1000 GROMMET-HOOD ROD COUPE 24 65512-H2500 GROMMET-HOOD ROD COUPE 1070- 2 65512-H1000 25 65514-H1000 CLAMP-ROD HOOD COUPE 26 96302-H1900 ASSY-DOOR MIRROR COUPE 27 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) COUPE
