Also see:
Part Numbers Index Main article for usage, photos, cross-reference Dash Firewall Kick Panel Package Tray
DASH
Dash Side Trimming
Sedan
1 66900-H1001 TRIM-DASH SIDE RH SEDAN 1 66900-H1101 TRIM-DASH SIDE RH SEDAN 2 66901-H1601 TRIM-DASH SIDE LH SEDAN 2 66901-H1901 TRIM-DASH SIDE LH SEDAN 3 08540-41012 SCREW-TAPPING (4) SEDAN 4 08915-43420 WASHER-PLAIN (4) SEDAN 5 08410-61212 SCREW-MACHINE (2) SEDAN 5 08410-61220 SCREW-MACHINE (2) SEDAN 6 36528-22500 WASHER-PLAIN (2) SEDAN 7 66904-H1001 PLUG-DASH SIDE RH SEDAN 8 66905-H1001 PLUG-DASH SIDE LH SEDAN 9 67100-H1600 ASSY-PANEL DUSH UPPER SEDAN 10 46580-H1600 STAY-BRACKET PEDAL & STEERING POS SEDAN 11 46581-H1600 STAY-BRACKET PEDAL & STEERING POS SEDAN 12 67300-H1600 ASSY-PANEL DASH LOWER SEDAN MANUAL 12 67300-H1601 ASSY-PANEL DASH LOWER SEDAN MANUAL 0272- 12 67300-H1922 ASSY-PANEL DASH LOWER SEDAN AUTOMATIC 12 67300-H1921 ASSY-PANEL DASH LOWER SEDAN AUTOMATIC 0272- 13 18050-24900 STOPPER-ACCELERATOR PEDAL SEDAN 14 18055-H1000 BRACKET-ACCELERATOR PEDAL STOPPER SEDAN 15 18023-H1000 RETAINER-ACCELERATOR PEDAL BRACKET SEDAN 16 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS SEDAN 17 67812-H1601 GROMMET-STEERING POST SEDAN 18 67813-H1600 PLATE-STEERING GROMMET LOWER SEDAN 19 67814-H1600 PLATE-STEERING GROMMET UPPER SEDAN 20 08510-51212 SCREW-TAPPING M5 GROMMET FIX (6) SEDAN 21 67900-H1600 ASSY-DASH INSULATOR RH SEDAN 22 67901-H1600 ASSY-DASH INSULATOR LH SEDAN 23 08963-10510 NUT-SPRING TYPE A (4) SEDAN 24 96800-H1600 ASSY-PACKAGE TRAY OP SEDAN 24 96800-H1601 ASSY-PACKAGE TRAY OP SEDAN 0471- 25 08410-61212 SCREW-MACHINE (3) SEDAN 26 36528-22500 WASHER-PLAIN (3) SEDAN 26 01311-00051 WASHER-PLAIN (3) SEDAN 0171- 27 28890-H1000 COVER-WIPER LINK SEDAN 0771- 28 08510-51612 SCREW (4) SEDAN 0771- 29 77730-89906 NUT (4) SEDAN 0771- 30 67830-H1000 CAP-BRACKET PACKAGE TRAY SEDAN(STD) 31 68100-H1600 ASSY-PANELINSTRUMENT SEDAN 32 01111-00022 BOLT-HEX M6X1 INST TO DASH SIDE (2) SEDAN 33 08915-13610 WASHER-LOCK INST TO DASH SIDE (2) SEDAN 34 08915-43610 WASHER-PLAIN INST TO DASH SIDE (2) SEDAN 35 08440-51612 SCREW-MACHINE M5X0.8 INST TODASH UP (3) SEDAN 36 08915-13510 WASHER-LOCK INST TO DASH UP (3) SEDAN
Coupe
1 66900-H1101 TRIM-DASH SIDE RH COUPE 2 66901-H1901 TRIM-DASH SIDE LH COUPE 3 08540-41012 SCREW-TAPPING (4) COUPE 4 08915-43420 WASHER-PLAIN (4) COUPE 5 66904-H1001 PLUG-DASH SIDE RH COUPE 6 66905-H1001 PLUG-DASH SIDE LH COUPE 7 67100-H1600 ASSY-PANEL DUSH UPPER COUPE 8 46580-H1600 STAY-BRACKET PEDAL & STEERING POS COUPE 9 46581-H1600 STAY-BRACKET PEDAL & STEERING POS COUPE 10 67300-H1922 ASSY-PANEL,DASH,LOWER COUPE,AUTOMATIC 10 67300-H1921 ASSY-PANEL,DASH,LOWER COUPE,AUTOMATIC 0272- 2 67300-H1922 10 67300-H1601 ASSY-PANEL,DASH,LOWER COUPE,MANUAL 0272- 2 67300-H1600 10 67300-H1600 ASSY-PANEL DASH LOWER COUPE,MANUAL 11 18050-24900 STOPPER-ACCELERATOR PEDAL COUPE 12 18055-H1000 BRACKET-ACCELERATOR PEDAL STOPPER COUPE 13 18023-H1000 RETAINER-ACCLERATOR PEDAL BRACKET COUPE 14 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS COUPE 15 67812-H1601 GROMMET-STEERING POST COUPE 16 67813-H1600 PLATE-STEERING GROMMET UPPER COUPE 17 67814-H1600 PLATE-STEERING GROMMET LOWER COUPE 18 08510-51212 SCREW-TAPPING M5 GROMMET FIX (6) COUPE 19 48324-H1005 CLAMP-STEERING POST UPPER COUPE 20 48326-H1005 CLAMP-STEERING POST LOWER COUPE 21 48325-04100 PACKING-STEERING POST COUPE 22 08110-82010 BOLT-HEX M8X1.25 CLAMP FIX (2) COUPE 23 08915-43810 WASHER-PLAIN M8 CLAMP FIX (2) COUPE 24 08915-13810 WASHER-LOCK CLAMP FIX (2) COUPE 25 67900-H1600 ASSY-DASH INSULATOR RH COUPE 26 67901-H1600 ASSY-DASH INSULATOR LH COUPE 27 08963-10510 NUT-SPRING TYPE A (4) COUPE 28 96800-H1600 ASSY-PACKAGE TRAY COUPE 28 96800-H1601 ASSY-PACKAGE TRAY COUPE 0471- 2 96800-H1600 29 08410-51212 SCREW-MACHINE (3) COUPE 30 96830-A0800 WASHER-PLAIN (3) COUPE 31 28890-H1000 COVER-WIPER LINK COUPE 0771- 32 08510-51612 SCREW (4) COUPE 0771- 33 77730-89906 NUT (4) COUPE 0771- 34 68100-H1600 ASSY-PANEL INSTRUMENT COUPE 35 01111-00022 BOLT-HEX M6X1 INST TO DASH SIDE (2) COUPE 36 08915-13610 WASHER-LOCK INST TO DASH SIDE (2) COUPE 37 08915-43610 WASHER-PLAIN INST TO DASH SIDE (2) COUPE 38 08440-51612 SCREW-MACHINE M5X0.8 INST TO DASH UP (3) COUPE 39 08915-13510 WASHER-LOCK INST TO DASH UP (3) COUPE
