B10 Alternator
Revision as of 08:17, 10 May 2012; view current revision
Categories: Datsun B10 | Charging System
Datsun 1000 uses the early Datsun alternator, A Mitsubishi or Hitachi unit with a four-spade rectangular connector. It was available in 25A or 30A versions. This is the same alternator as used by Datsun 411 and early Datsun 510. It is the same diameter as the more modern Datsun 1200 and 510 35A alternator.
B10 Datsun 1000 Hitachi
23100-18001 LT125-D2
23100-18005 LT125-D2 (ISO)
23100-H0100 LT125-06 from 1969
23100-H0300 LT125-06 from 1969 Coupe
23100-A4600 LT130-65 (op.) Van, T
23100-A4601 LT130-65 (op.) Coupe
B10 Datsun 1000 Mitsubishi single-lug
23100-18010 214-886
23100-18015 214-886 (ISO)
B10 Datsun 1000 Mitsubishi two-lug
23100-H0110 AF2025A
23100-H0110 AF2030A5 (op.) (exc. Coupe)
23100-H0110 AF2030A6 (op.) Coupe
BRACKET-alternator
11710-18000 <x> 11710-H0100
11710-H0100
11710-27720 506W alternator (op.) Rally
Large Terminals, large wires
* A/BAT - To battery via Fusible Link
* E - To earth/ground point (engine block)
This is the same as newer Datsun alternators
Rectangular connector
W - A to A on regulator
WB - F to F on regulator
Y - N to N on regulator
B - E to E on regulator
Regulator
A - to A on alternator
F - to F on alternator
N - to N on alternator
E - to E on alternator
L - WR to CHG lamp in Dash
I - BW to IGN switch 12V
See wiring diagram on Datsun100.com
Early 510
BW
GR
RL
GB
Datsun 510 JDM (3-lug mounting)
1967-1970
23100-21000 LT130-41 Hitachi
23100-21005 LT130-41 Hitachi (ISO)
23100-21600 LT140-66 Hitachi (op.)
23100-21605 LT140-66 Hitachi (op.) (ISO)
23100-A4800 LT140-53 Hitachi PP, PY
23100-21005 LT130-41K Hitachi P510
23100-A4600 LT130-65 Hitachi
* SAME AS LATE DATSUN 1000
23100-A4601 LT130-72 Hitachi
23100-21010 12V-30A Mitsubishi
23100-21015 12V-30A Mitsubishi (ISO)
23100-A4610 12V-30A, AG2030A Mitsubishi
23100-A4611 12V-30A, AG2030A Mitsubishi
23100-21615 214-028, 40A Mitsubishi PP,PY
23100-A4810 AG2040A Mitsubishi PP,PY
410
Datsun 410 JDM (3-lug mounting)
23100-61200 12V-300W Mitsubishi
23100-10600 12V-300W Hitachi
23100-10601 12V-300W Hitachi
411
W
W
WB
B
Mounting
1000 alternator has one-lug lower boss (early 1000)
1000 alternator has two lower ears (later 1000)
1200 alternator has two lower ears
Early (1000) alternator versus Datsun 1200 alternator.
Same front mounting face
Same diameter fan pully
early 1000 Bottom mounting lugs differ
later 1000 same mounting lugs
