A14T unique parts. From the 1976 B210 JDM parts catalog. Parts that are the same as a regular B210 engine are not listed here.
Also see: Hitachi Twin Carb (A12GX, A12T and A14T engines)
Engine
Pistons, rods and crankshaft are the same as a standard A14 engine.
10101-H8425 GASKET KIT-ENGINE REPAIR 10102-H8400 ENGINE ASS'Y-BARE [long block] 10103-H8400 ENGINE ASS'Y-SHORT 11010-H8400 BLOCK ASS'Y-CYLINDER 21045-H8400 PIPE-SUCTION WATER PUMP 13001-H5700 CAMSHAFT
Cylinder Head and Valve Cover
A14T uses standard A14 head gasket, intake valves and exhaust valves. A14 standard valves (37/30) are larger than A12/A12GX valves (35/29).
11041-M2460 HEAD ASSY-CYLINDER A14T B210, F10 13264-H8400 COVER ASSY-VALVE ROCKER 13203-H2300 SPRING-VALVE OUTER 13204-H2301 SPRING-VALVE INNER 13205-H2300 SEAT-VALVE SPRING
A14/A14T standard valves 13201-H6200 VALVE-INTAKE 13202-H6200 VALVE-EXHAUST
Manifold
14003-M2450 MANIFOLD-INTAKE 14065-M2400 STUD [carb mounting] (8) 14004-H8400 MANIFOLD-EXHAUST 14013-M2400 PLATE-HEAT SHIELD FRONT 14014-M2400 PLATE-HEAT SHIELD REAR 14035-M2401 GASKET-MANIFOLD TO CYLINDER HEAD 14055-M2400 HOSE-WATER [intake to water pipe] 14100-M2400 THERMOSTAT ASSY-MANIFOLD WATER 14330-M2461 PLATE-HEAT SHIELD CARBURETOR front 14331-M2460 PLATE-HEAT SHIELD CARBURETOR rear 14875-M2400 CONNECTOR-VACUUM HOSE
The A14T inlet manifold is easily ID'd by the 4-bolt carburetor flanges. A12 twin-carb engines had 2-bolt flanges.
full-size picture
Emission Control
14120-M2460 TUBE ASSY-EGR 14711-M2460 PASSAGE-EGR 14791-M2401 CONNECTOR-INLET ELBOW 14791-H2461 CONNECTOR-VACUUM STRAIGHT 14720-M2400 GASKET-EGR PASSAGE 14741-Q1100 VALVE ASSY-BPT 14745-M2461 BRACKET-BPT VALVE 14751-M2461 TUBE ASSY-BPT 14755-H8200 TUBE-PASSAGE TO BPT 14792-M2462 CONNECTOR-PIPE 14826-M2200 BRACKET ASSY-EAI PIPE 14835-U7500 VALVE ASSY-AB with 4-speed 14860-H8400 HOSE-AIR 14823-H8400 PIPE ASSY-EAI 14861-H8400 HOSE AIR 14862-M2400 HOSE-AIR CLEANER TO AB VALVE 14863-H8400 HOSE-AB VALVE TO INLET CONNECTOR 14869-H8401 CLAMP-HOSE 14889-H7200 ORIFICE-AB VALVE 14896-M2400 CLIP-HARNESS 14956-U6700 VALVE ASSY-SOLENOID EGR-CUT 14957-H8400 BRACKET-VACUUM SWITCH 02141-67400 HOSE-EVAPO 02141-358Y0 HOSE-VACUUM E.A.R. TO CONNECTOR
Exhaust Piping
A14T used standard A14 exhaust piping, albeit with a special single-outlet exhaust manifold.
Radiator
This radiator uses the same shroud and top hose as A14 automatic radiator. Possibly it is the same size.
21400-H7210 RADIATOR ASS'Y
Accelerator Pedal
18010-H5801 PEDAL ASSY-ACCELERATOR [same as L16 MT B210] 18215-H5800 SPRING-PEDAL ROD [same as L16 MT B210] 18200-H7510 WIRE ASSY-ACCELERATOR
Fuel
11826-M2460 HOSE-ROCKER COVER TO AIR CLEANER to 7612 11826-M2461 HOSE-ROCKER COVER TO AIR CLEANER from 7701 11828-M2460 HOSE-PIPE CONNECTOR TO VALVE 11830-M2460 CONNECTOR-PIPE 16587-N0901 CONNECTOR-3 WAY 14920-M2401 VALVE ASSY-CONTROL 22472-B8000 CLAMP-VACUUM TUBE 14896-M2400 BAND-HOSE 16335-M2460 ORIFICE-NO 2 16290-K0500 CLAMP-VACUUM HOSE 22319-M2462 CLAMP-VACUUM HOSE 22472-G0302 CLAMP-VACUUM HOSE [same as VB210] 22339-M2400 HOSE-VACUUM CONTROL PASSAGE CONN TO A/C 22340-M2400 HOSE-VACUUM CONTROL P/M OPENER TO DASH POT 22312-H7202 HOSE-VACUUM CONTROL L=120 S/B2318-73002 22318-N8610 HOSE-VACUUM CONTROL L=80 S/B2318-73002 22320-N4214 HOSE-VACUUM CONTROL L=50 S/B2318-73002 22320-Y4002 HOSE-VACUUM CONTROL L=155 S/B2318-N3300 22312-M2460 HOSE-VACUUM CONTROL BPT TO TVV
Carburetor
A14T carbs can be identified by the triangular bolt pattern and 38mm bore.
NOTE: 260Z carbs also look like this but are 46mm bore.
full-size photo
16010-H8430 CARBURETOR ASSY FRONT 16010-H8450 CARBURETOR ASSY REAR
Fuel
A14T uses stock A14 fuel pump.
17522-H8401 TUBE ASSY-FUEL [steel fuel rail]
Air Cleaner
The A14T air cleaner has triangular bolt-pattern on the carburetor side.
16500-H8400 CLEANER ASSY-AIR * 08110-61662 BOLT 16530-U6001 DUCT-AIR * 08772-14400 (2) 16590-H8400 COVER ASSY-EXHAUST MANIFOLD * 08915-43610 WASHER * 08110-61010 BOLT 16546-H2300 ELEMENT ASSY 16565-M2400 FILTER [small]
Also see: Hitachi Twin Carb Air Cleaner
Propeller Shaft
Also see: Propeller Shaft Swaps
37000-H7510 SHAFT ASSY-PROPELLER A14T F4 [4-Speed] AMPCO 3 JOINT (440+742) x 63.5 x 1.6
Brakes
47474-H7500 HOSE-MASTERVAC 47476-H7510 CONNECTOR ASSY-MASTERVAC HOSE to 7608 47476-H7511 CONNECTOR ASSY-MASTERVAC HOSE from 7609
