Early
B210 EARLY means:
- JDM 1973-1975
- USA 1974-1976 Model year (to July 1976)
- AUS ???
Early Sedan
NOTE: USA sedans used the coupe grille.
NOTE VB210 Vans (wagons) also used this sedan grille.
Silver, with non-standard center emblem
[http://datsun1200.com/uploads/newbb/10405_49d6d7100f65b.jpg]
- 62302-H5125 JDM GRILLE KIT-radiator (ex. GX)
- 62302-H5225 JDM GRILLE KIT-radiator GX
- 62304-H5100 MOULDING-grille radiator (R.H.) GL,GX, V.SP-DX [half-eyebrow]
- 62305-H5100 MOULDING-grille radiator (L.H.) GL,GX V.SP-DX [half-eyebrow]
Ornament
The early sedan grille used these badges. The 'S' or 'D' mark is chrome with red-painted inlay
- 62312-H5025 JDM ORNAMENT KIT-radiator grille V-STD
- 62312-H5026 JDM ORNAMENT KIT-radiator grille (S) DX [intertwined 'S' mark]
- 62312-H5125 JDM ORNAMENT KIT-radiator grille (S) GL
- 62312-H5225 JDM ORNAMENT KIT-radiator grille (S) GX
- AUS ['D' mark]
Fog Lamp
Rectangular Fog Lamp (sedan style) * 26150-H5027 LAMP KIT-fog (from '75-4) (op.) S-all, Van ** replaced 26150-H5026 LAMP KIT-fog (from '74-1) (op.) S-all, Van *** superceded 26150-H5025 LAMP KIT-fog (op.) S-all, Van
Early Coupe
The early Coupe grille has a bold honeycomb style to invoke a sense of power. It is also used by all early USA Sedans.
- 62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan
- 62302-H5500 JDM GRILLE KIT-radiator K-DX,K-GL
- 62302-H5700 JDM GRILLE KIT-radiator K-GX
Ornament
The early coupe grille used this badge:
- 62312-H5525 JDM ORNAMENT KIT-radiator grille ['S' shield-shaped mark]
- 62312-H5526 USA KIT-ORNAMENT RADIATOR GRILLE -0776 ['D' shield]
- AUS ['D' mark]
Fog Lamp
- 62310-H5500 JDM MASK-fog lamp A K-DX
- 62310-H5600 JDM MASK-fog lamp A K-GL
- 26150-H5500 JDM LAMP ASS'Y-fog K-GX (op.)K-DX,K-GL
Round Fog Lamp (coupe-style) * 26150-H5527 LAMP KIT-fog (from '75-4) (op.) K-DX,K-GL ** replaced 26150-H5526 LAMP KIT-fog (from '74-1) K-GX (op.) K-DX,K-GL *** superceded 26150-H5525 LAMP KIT-fog (op.) K-GX (op.) K-DX,K-GL
USA used amber Turn Signal lamps in place of the JDM fog lamps
[http://datsun1200.com/uploads/newbb/174_4c3902216a198.jpg]
(non-USA has the Turn Signal/Markers/Indicators in the bumper)
Late
LATE B210 means:
- JDM 1976-1977 (B310 production began November 1977)
- USA 1977-1978 Model year (from August 1976)
- AUS ???
Late Sedan
New Grille has a clearly rectangular center section. There is a bright chrome strip outlining the center section.
- no fog lamps
- amber fog lamps
- yellow fog lamps
- Silver outline with silver center section (AU)
- Silver outline with black center section (UK GLS, UK Estate)
- Black outline with black center section (GX, SSS, FRA)
JDM 7702-7707
- 62302-H7426 GRILLE KIT-FRONT S.A12,A14,-=STR, V.DX,SPDX
- 62302-H7425 GRILLE KIT-FRONT =STR, V.SMDX
- 62302-H7401 JDM GRILLE ASSY-RADIATOR =STR+V.SMDX (2-dr STD 4-speed + Van Semi-DX)
- 62302-H7402 JDM GRILLE ASSY-RADIATOR K.A12S,A14S.DX,GL
- 62302-H7420 JDM GRILLE ASSY-RADIATOR S.A12,A14-=STR V.DX,SPDX
- 62302-H7502 JDM GRILLE ASSY-RADIATOR *S.A14S.GX [same as USA]
- 62304-H7410 MOULDING-RADIATOR GRILLE S.A12,A14-=STR, V.DX,SPDX
- 62304-H7411 MOULDING-RADIATOR GRILLE S.A12,A14-=STR
North America B210s used this sedan grille for all coupes, like this Canadian Coupe:
- Black or gray ouline with same color center section
- 62302-H7526 USA KIT GRILLE-RADIATOR (WITH MOULDI 0876-0177
- 62302-H7500 USA GRILLE-RADIATOR 0876-0177
- 62304-H7410 USA MOULDING-GRILLE RADIATOR 0876-0177
- F2302-H7420 USA KIT GRILLE-RADIATOR (WITH MOULDI 0277-0777
- 62302-H7502 USA GRILLE-RADIATOR 0277-0777
- 62304-H7411 USA MOULDING-GRILLE RADIATOR 0277-
- 62302-H7700 USA GRILLE-RADIATOR 0877- [Black]
- 62304-H7411 USA MOULDING-GRILLE RADIATOR 0877-
Ornament
- 62312-H7401 USA ORNAMENT-RADIATOR GRILLE 0876- ['D' mark]
- 62312-H7425 JDM ORNAMENT-FRONT S.A12,A14 V ['S' intertwined mark]
Late Coupe
NOTE: USA and Canada coupes used the late Sedan grille
The late coupe grille is nearly the same as early coupe grille, but has a horizontal bar through it with a new emblem mounted right over this bar.
H7427
JDM
- 62302-H7427 JDM GRILLE KIT-FRONT K.A12,K.A14.DX,GL
- 62302-H7525 JDM GRILLE KIT-FRONT K.A14.GX
- 62302-H7506 JDM GRILLE ASSY-RADIATOR K.A14.GX
- 62304-H7506 JDM MOULDING-RADIATOR GRILLE K.A12,A14
Ornament
グリル
PB210
B210-based Datsun Sunny 1400 Excellent (PB210), and 140Z & 160Z coupes used a twin-nostril grille.
See PB210 for more information.
Excellent 1600
- 62302-H7925 GRILLE KIT-FRONT L16.GL
- 62302-H7926 GRILLE KIT-FRONT L16.GX
- 62302-H7900 GRILLE ASSY-RADIATOR K.L16S
- 62304-H7900 MOULDING-RADIATOR GRILLE L16
- 62311-H7925 ORNAMENT-FRONT [S-badge looks like 1/2 Mid-model Sunny Truck badge] Coupe & Sedan
- Slightly pointed
- Single center-section (no twin-nostril look)
- no horizontal bar
- no fog lamps
