Switch Part Numbers
Revision as of 20:51, 29 December 2015; view current revision
Categories: Catalog | Body Electrical System
Also see:
Part Numbers Index
Main articles for usage, photos, cross-reference:
Relay Fuse Box Horn Hazard Switch
Cigarette Lighter
Lighting System
Wipers & Heated Glass
1200
25520-89962 -7312 UNIT-flasher, hazard & turn signal B110,PB110
25520-89974 7401- UNIT ASSY-TURN SIGNAL FLASHER ターツ & ハザード
25880 SWITCH ASSY-HAZARD & PARKING
25290-H1001 -7803
25290-G1060 7804-8608 F/STRG COVER
25290-G1260 8608-8910 ハザード SW ノミ
25290-95W00 8910-
SWITCH ASSY-STOP LAMP
25320-H1000 -8109
25320-H8500 8110-
25320-75A00 8910-
1400
25880-H2500 SWITCH COMP-hazard & parking
25520-89962 UNIT-flasher, hazard & turn signal
Lights, Glass, Hazards
1 25160-H1010 COMP-SWITCH LIGHTING WITH FOG SWI OP
1 25160-H4600 COMP-SWITCH LIGHTING 0172- 0 25160-H1010
1 B5160-B6800 COMP-SWITCH LIGHTING 0172- 25160-H4600
1 25160-H1001 COMP-SWITCH LIGHTING
B5160-B6800 COMP-SWITCH LIGHTING 25160-H1001
2 25165-H1000 KNOB-LIGHTING SWITCH
2 25165-H4600 KNOB-LIGHTING SWITCH 0172- 0 25165-H1000
25165-T3000 KNOB-LIGHTING SWITCH 25165-H4600
3 25199-H1000 SPRING-SWITCH KNOB
4 25260-H1001 COMP-SWITCH WIPER
4 25260-H4600 COMP-SWITCH WIPER 0172- 0 25260-H1001
5 25260-H7000 COMP-SWITCH WIPER 0772- 0 25260-H4600
5 25260-H7001 COMP-SWITCH WIPER 0772- 2 25260-H7000
6 25265-H1000 KNOB-WIPER SWITCH DX
6 25265-H4600 KNOB-WIPER SWITCH 0172- 0 25265-H1000
7 25265-H7000 KNOB-WIPER SWITCH 0772- 0 25265-H4600
7 25265-H7001 KNOB-WIPER SWITCH 0772- 2 25265-H7000
25265-H5200 KNOB-WIPER SWITCH 25265-H7001
8 25199-H1000 SPRING
9 25170-H2510 ASSY-LAMP,ILLUMINATION AUTOMATIC 0772- 0
10 08964-10510 NUT-SPRING 0772-
11 08540-51612 SCREW 0772-
12 25330-H1000 COMP-CIGALETTE LIGHTER DELUXE(OP STD)
12 25330-H1001 COMP-CIGALETTE LIGHTER DELUXE(OP STD) 1072- 2 25330-H1000
B5331-H5001 COMP-CIGALETTE LIGHTER DELUXE(OP STD) 25330-H1001
13 B5330-H1001 ELEMENT-CIGAR LIGHTER DELUXE(OP STD)
14 25290-H1900 COMP-SWITCH HAZARD
14 25290-H4600 COMP-SWITCH HAZARD 0172- 0 25290-H1900
25290-H4601 COMP-SWITCH HAZARD 25290-H4600
15 08513-30812 SCREW FIXING HAZARD SWITCH 3
16 08915-13310 WASHER-SPRING 3
43 25230-H2200 SWITCH-HEAT GLASS OP. 1270-
44 08510-51212 SCREW 2 OP. 1270-
Horn, Fuse & Electrical Unit
17 25540-H1100 COMP-SWITCH TURN SIGNAL & DIMMER WITH OP
17 25540-H1006 COMP-SWITCH TURN SIGNAL & DIMMER -1272 2
17 25540-H1007 COMP-SWITCH TURN SIGNAL & DIMMER 0173- 2 25540-H1006
18 25410-H1000 BLOCK-FUSE
25410-B5102 BLOCK-FUSE 25410-H1000
19 B5415-H1000 COVER-FUSE BLOCK OP
20 08941-11000 FUSE (10A) 3
21 08941-11500 FUSE (15A) 5
22 08510-51212 SCREW 2
23 08915-13510 WASHER-SPRING 2
25240-G150A SWITCH-OIL PRESSURE ENGINE 25240-89910
24 25240-89910 SWITCH-OIL PRESSURE ENGINE
25 25360-89900 SWITCH-DOOR DELUXE(OP STD)
25 25360-89915 SWITCH-DOOR 0172- 0 25360-89900
26 25320-H1000 SWITCH-STOP LAMP
27 25520-89911 UNIT HAZARD FLASHER 2 25520-89990
25520-89997 UNIT HAZARD FLASHER 2
27 25520-89990 UNIT HAZARD FLASHER 2 2 25520-89911
28 08510-51012 SCREW-TAPPING 2
29 08915-13510 WASHER-SPRING 2
B5520-89993 UNIT-FLASHER 12V 50W 25520-89901
30 25520-89901 UNIT-FLASHER 12V 50W
31 08510-51012 SCREW-TAPPING 2
32 08915-13510 WASHER-SPRING 2
33 26310-H1000 HORN-HIGH
33 26310-H1800 HORN-HIGH COUPE
34 26330-H1000 HORN-LOW SEDAN
25620-G2501 HORN-LOW COUPE 26330-H1800
34 26330-H1800 HORN-LOW COUPE
35 08110-81410 BOLT-HEX M8 4
36 08915-13810 WASHER-SPRING 4
37 26320-14800 RELAY-HORN
38 08310-51062 SCREW-MACHINE WITH LOCK WASHER
39 26320-89905 ASSY-RELAY,PASSING OP 0471-
40 08513-51012 SCREW 2 OP 0471-
41 25390-20300 SWITCH-KICK DOWN AUTOMATIC
42 36011-89901 SWITCH-HAND BRAKE
42 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- 36011-89901
45 22110-N0901 ASSY-SWITCH, THERMOSTAT MANUAL 0671-
46 08510-51212 SCREW MANUAL 0671-
25235-P0101 ASSY-RELAY,HEATER,AUTO CHOKE 25235-P0100
47 25235-P0100 ASSY-RELAY,HEATER,AUTO CHOKE 0671-
48 08513-61212 SCREW 2 0671-
Buzzer & Warning
49 26350-89905 BUZZER 0172-
50 08513-51012 SCREW 4 0172-
51 48780-H1900 BRACKET-BUZZER 0172-
52 25230-89918 ASSY-RELAY AUTOMATIC 0172-
53 25231-H4600 BRACKET-RELAY AUTOMATIC 0172-
54 08513-51012 SCREW 2 AUTOMATIC 0172-
55 26495-H4600 LAMP-SEAT BELT WARNING 0172-
56 08961-44810 NUT-PUSH 2 0172-
57 25310-H4600 SWITCH-SEATING OP 0172-
