The Datsun 1200 cylinder head gasket fit A12 and A10 engines. Aftermarket gaskets vary in material and size of cooling holes.
Also See: * Changing Head Gasket * Tune-up
Nissan recommends re-torquing the head gasket bolts ever twenty-four months (every two years):
1972 USA Owners manual
Retighten cylinder head bolts, manifold nuts & carburetor securing nuts.
Blown Gasket
11044-18004 GASKET-CYLINDER HEAD A12 superceeded![]()
11044-H1000 GASKET-CYLINDER HEAD A12 11044-H1000 GASKET-cylinder head B110, B210 to '75-4 11044-H1025 B210 from '75-5 11044-H1026 11044-H1027 11044-H3900 GASKET-CYLINDER HEAD A12 0671-
fits: A10 PULSAR 1000 BN10 988cc 1978-ON A10 SUNNY 1000 B10,B20 1000 1966-1970 A12 SUNNY 1200 B110,B210,C20 1171cc 1970-73.3 A12 SUNNY 1200 B210 1973.4-75 A10 CHERRY 1000 E10, F10 988 1970.10-73.9 A12 CHERRY 1200 PE10, F10 1171cc 1972-78
11044-H2300 A12GX, A12T 11044-H2301 [thinner?] A12GX, A12T 11044-H2325 A12GX from '72-6![]()
Head Set
11044-H3926 KIT-GASKET,CYLINDER HEAD 11042-H3927 KIT-GASKET,CYLINDER HEAD
Head Set gasket includes all you need to change the head:
Cylinder head gasket Valve stem seals Rocker cover gasket Gasket-manifold to cylinder head
it may include the following:
thermostat gasket intake-to-exhaust manifold gasket (heat riser gasket) oil cap packing (gasket) fuel pump gaskets
Gasket Head Set * Victor HS3602 * FEL-Pro HS21181PT * ROL HS32060
GX Metal
Nissan Competition
11044-M0821 COMPETITION HEAD GASKET
Gasket has a bore diameter of 79mm/3.11", an uncrushed thickness of 0.8mm/0.032" and displaces 3.9cc's.
Nismo head gaskets for Nissan A series motor A12,A13,A14,A15 Engine
11044-M0822 t=0.8 79.0 mm bore diameter 11044-M0823 t=0.6 80.0 mm bore![]()
Spacer Gasket
シリンダーヘッドガスケット
