Door cards (door interior trim panels) — which Nissan calls "door finishers" — for Datsun 1200 were available in different styles.
| Contents |
Coupe door panels will fit on a 2dr sedan with some very minor mods. The panel may sit a bit higher than the original panel but basically its just a matter of enlarging the window winder hole. Oh, and its harder to fit but it works.
Early Truck door cards are the same as 4-dr sedan.
The factory visqueen protects the door cards from moisture. The original door panels are made out of MDF-like fibreboard, the doors have polyethylene sheet applied with sealer before the door cards are fitted.
The black bead of rubber sealant is similar to RTV
Details
Coupe 1972
 full
 full
Ute Mid-model (1978-1989) Brown
Ute Late-model (1989-)
Gray
Do not confuse with B210 door cards, such as this early KB210 type:
Coupe
Coupe finishers cover the entire door (sedan finishers do not cover the top of the door)
FINISHER ASS'Y-door 80900 RH 80901 LH
JAPAN & North America 80900-H1800 RH BLACK #1742 80900-H1801 RH YELLOW 黄 (DX for JAPAN)
North American 1973 flame resistant 80900-H7101 RH BEIGE,LH-20 COUPE 0772- 80900-H7102 RH BLACK,LG-13 COUPE 0173- 80900-H7100 RH BLUE COUPE 0772-
Body Side Finisher 76900-H1800 DX/GL Black 76900-H1801 DX/GL Yellow
1973 North America 76900-H7000 BLUE 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Coupe 1972
80900-H4000 Black 89000-H4001 Yellow
Facelift finishers have a swoosh design
 full
 full
Body Side Finisher 76900-H4000 Black 76900-H4001 DX Yellow
Sedan
4-door 80900-H1000 STD black 5-rib style 80900-H1100 DX/GL/GX black chrome insert 80900-H1101 DX yellow
DX/GL/GX with chrome accent insert
STD
STD
Rear Door Finisher 82900-H1000 STD Black 82900-H1100 DX/GL/GX Black 82900-H1101 DX Yellow
DX
GL
Sedan 2-door
2-door 80900-H1200 STD black 80900-H1300 DX/GL black Japan 80900-H1301 DX yellow (USA: 1270-) 80900-H1900 DX black North America
North American 1973 flame resistant 80900-H7000 BLUE,LB-211 0772- 80900-H7001 BEIGE,LH-20 0772- 80900-H7002 BLACK,LG-13 0173-
80900-H1900 2-door North America
Body Side Finisher 76900-H1200 STD Black #1742 76900-H1300 DX/GL Black 76900-H1301 DX/GL Yellow
1973 North America 76900-H7000 BLUE,LB-211 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Body Side Finisher 76901-H1300 DX/GL, Black
Rear Side card has a distinctive upward sweep
Sedan 1972
4-door 80900-H3100 1972 STD black 80900-H3200 1972 DX black 80900-H3201 1972 DX yellow
2-door 80900-H3600 1972 STD black 80900-H3700 1972 DX black 80900-H3701 1972 DX yellow
Facelift Black STD
Truck
Sunny Truck door finishers came in two patterns:
- 1971 sedan STD simple 5-rib pattern
- 1972-1994 sedan facelift spear pattern
FINISHER ASS'Y-door 80900-H1000 -7111 BLACK same as early sedan 80900-H3100 7112-7803 BLACK same as 1972 sedan 80900-G1060 7804-7907 DARK BROWN 80900-G1660 7908-8104 BROWN 80900-G1901 8105-8910 BROWN 80900-95W00 9810- GRAY
1971 Black
Dec 1971 - Apr 1978: Facelift Black
7804-7907 DARK BROWN spear pattern
7908-8104 BROWN sweep pattern
8105-8109 BROWN
8110-8910 BROWN with pocket (driver's side only)
Oct 1989- Gray
1972-1978 Black facelift
1982-1989 Brown
 full
 full
1989-1994 Grey, driver
 full
 full
1989-1994 Grey, assistant
 full
 full
Door Pocket
80801 POCKET-DOOR 80912-G1900 BROWN RH 8110-8910 80912-95W00 GRAY RH 8910-
ドア ポケット
Clips
Clips to hold the finishers in place
Custom
Roll-cage simulating interior door panel. Color matched.
ドア フィニッシャー
