Brake lamp located in the dash cluster gauge lights up if there is a problem.
Brake Stop Lights
Hand Brake Switch
Lamp switch for Hand Brake pull-handle was fitted to USA 1200s, Japan Sunny Truck staring 7510, and is fitted to newer Australia utes.
The switch turns on the warning lamp
Parking Brake Lever
full
Dash-top Lamp (AUSTRALIA)
Cluster Gauge Lamp (USA/late JAPAN)
Dash Lamp (early JAPAN)
Pressure Loss Switch
A brake check switch is used on some 1200s to signal if there is a problem with the brake pressure.
See Warning Light Switch#Wiring
Schematic
The dash lamps are always connect to 12V when IGN switch is on. They only light up when a switch grounds the bulb. A switch is fitted to the hand brake lever. When you pull the lever, it grounds the circuit.
- G: Green wire from IGN fuse to dash cluster lamps
- B: Black wire to main body earth bolt in engine compartment
- Y/G: Yellow wire w/Green stripe, from switch to bulb, grounds the bulb
