Seat rails are of two kinds: 1) Full adjustable fore-aft sliding 2) Non-sliding (truck passenger side).
Unbolt the rails from your seats and bolt them to the new seat.
H16 left seat - Coupe & all USA (sedan & coupe)
Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
* Side to side: 15-11/16 inch
* Front to back: 12-3/16 inch
USA seat with Seat Belt Warning System switch
B110 rails in B10 (one-piece slide cut into two)
B210* seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat.
* early B210 seats fit B110 directly * late B210 seats have a non-flat bottom
If you don't have the B110/B210 rails, you can adapt B310 slides:
Modifying B310 brackets to fit B110 chassis
Location
The seat rails bolt to the floor risers.
Front Riser "A", Rear risers "B" and "C"
Lowering
Converter Seats
1200s from Oct 1989 have a Catalytic Convertor.
Passenger side rail is shaped differently to clear the Catalytic Convertor bulge in the floor
Truck
Truck driver's seat has an adjustable slide. The passenger seat is a fixed (non-adjustable) "seat riser" bracket.
87500-G1000 SLIDE ASS'Y-driver seat ドライバ- シート スライド -1974 87501-G1000 SLIDE-RH SEAT, OUTSIDE スライド、RH シート アウトサイド 87502-G1000 SLIDE-RH SEAT, INSIDE スライド、RH シート インサイド 87556 87505-G1000 BRACKET ASSY-FRONT SEAT, LH ブラクット アッセンブリ、フロント シートLH RISER ASS'Y-seat シート ライザー [non-adjustable]
08110-81862 BOLT fixing slide to floor (8) 08915-43810 WASHER fixing slide to floor (8) 08310-82014 SCREW fixing slide to seat (8) 08310-81812 -7510 08915-13810 WASHER fixing slide to seat (8)
Bride
The famous Bride rails for Sunny Truck
200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
- Side to side: 15-11/16 inch
- Front to back (left side): 12-3/16 inch
- Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
- slanted tabs
- 15-1/2" at base, 16-1/4" at bottom edges
- front tab: 1-7/16" long
- rear tab: 1-3/8" long
- slanted tabs
Bride B122 Part Numbers
- LH: code N030VO type V*1 TTM-L No. 939063
- RH: code N029VO type V*1 TTM-L No. 939064
- V type: for Bride full bucket, 30 mm height
- S type: for Bride reclining seat
- VF type: for Bride full bucket, no slide (fixed position)
Photo Gallery
Click any thumbnail to see it full size (external web site)
シート スリイド シート リイザー ブラケット
