<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference Rear Axle Tires Wheel Hubcaps
Truck
40315-15400 CAP-road wheel STD 40315-H1000 CAP-road wheel DX -7907, (op.)STD 40343-H8510 ORNAMENT-DISC WHEEL 7908-
reference: 1974 B120 Parts Catalog C-288, page 70-2 1997 B120 Parts Catalog C-415, page F40-03
1 43010-H1004 COMP-CASE REAR AXLE SEDAN 0673- 5 43010-H1003 43010-H1404 COMP-CASE REAR AXLE COUPE 0673- 5 43010-H1803 43010-H1802 COMP-CASE REAR AXLE COUPE -1172 43010-H1003 COMP-CASE REAR AXLE SEDAN 1272-0573 2 43010-H1002 43010-H1002 COMP-CASE REAR AXLE SEDAN -1172 43010-H1803 COMP-CASE REAR AXLE COUPE 1272-0573 2 43010-H1802 2 43067-H0100 STUD-GEAR CARRIER FIX (8) 3 43059-A1600 PLUG-TAPER SQUARE SOCKET 4 32103-14600 ASSY-PLUG DRAIN 5 38322-55100 ASSY-BREATHER 6 38162-G0300 ASSY-SHAFT REAR AXLE (2) 7 40222-18000 BOLT-HUB ROAD WHEEL (8) 8 43065-10600 CLIP-BRAKE TUBE (2) 9 43066-22500 SEAT-CONNECTOR BRAKE HOSE 10 43070-04101 SPACER-REAR AXLE BEARING (2) -1172 10 43070-H5000 SPACER-REAR AXLE BEARING (2) 1272- 43070-04101 11 43215-18000 BEARING-REAR AXLE (2) SEDAN COUPE 11 43215-H5000 BEARING-REAR AXLE (2) SEDAN COUPE 0673-1172 5 43215-18000 12 43255-18000 COLLAR-REAR AXLE BEARING (2) 12 43255-H1000 COLLAR-REAR AXLE BEARING (2) 1271- 2 43255-18000 13 43036-H5000 SHIM-REAR AXLE CASE END (0) SEDAN COUPE 0673-1172 5 43036-10601 13 43036-10601 SHIM-REAR AXLE CASE END (0) SEDAN COUPE 14 43239-04100 PACKING-GREASE CATCHER (2) -1172 14 43239-H5000 PACKING-GREASE CATCHER (2) 1272- 43239-04100 15 43237-18000 CATCHER-GREASE RH -1172 16 43236-H5000 CATCHER-GREASE (2) 2 1272- 43236-18000 16 43236-18000 CATCHER-GREASE LH -1172 17 43252-18000 SEAL-OIL REAR AXLE SHAFT (2) 17 43252-H1000 SEAL-OIL REAR AXLE SHAFT (2) 0372- 43252-18000 17 43252-H1010 SEAL-OIL REAR AXLE SHAFT (2) 0372- 43252-H1000 18 08915-23810 WASHER-SPRING LOCK (8) 19 43063-18001 BOLT-FIX REAR BRAKE DISC (8) 20 08912-43810 NUT-HEX SELF LOCK (8) 21 43206-18000 DRUM-BRAKE (2) 22 40300-H1001 ASSY-ROAD WHEEL 4JX12 (3) DELUXE 23 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WITHE FMVSS (3) OP 23 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL FMVSS (3) OP 23 40312-H1922 TIRE 6.00-12-4PR FMVSS (3) 23 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS (3) OP 24 40315-H1100 COVER-ROAD WHEEL (2) DELUXE (OP STD) 25 40315-H1800 COVER-ROAD WHEEL (2) P COUPE 25 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) (2) COUPE 0872- 5 40315-H1800 26 40225-27700 NUT-ROAD WHEEL 1 (16) 27 40324-H1000 WEIGHT 40G WHEEL BALANCE (0) 2 40324-18000 27 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED (0) 27 40328-18000 WEIGHT 80G WHEEL BALANCE (NOT ADOPTED (0) 27 40327-H1000 WEIGHT 70G WHEEL BALANCE (0) 2 40327-18000 27 40327-18000 WEIGHT 70G WHEEL BALANCE (0) 27 40326-H1000 WEIGHT 60G WHEEL BALANCE (0) 2 40326-18000 27 40326-18000 WEIGHT 60G WHEEL BALANCE (0) 27 40330-18000 WEIGHT 100G WHEEL BALANCE (NOT ADOPTED (0) 27 40324-18000 WEIGHT 40G WHEEL BALANCE (0) 27 40323-H1000 WEIGHT 30G WHEEL BALANCE (0) 2 40323-18000 27 40323-18000 WEIGHT 30G WHEEL BALANCE (0) 27 40322-H1000 WEIGHT 20G WHEEL BALANCE (0) 2 40322-18000 27 40322-18000 WEIGHT 20G WHEEL BALANCE (0) 27 40321-H1000 WEIGHT 10G WHEEL BALANCE (0) 2 40321-18000 27 40321-18000 WEIGHT 10G WHEEL BALANCE (0) 27 40325-H1000 WEIGHT 50G WHEEL BALANCE (0) 2 40326-18000 27 40325-18000 WEIGHT 50G WHEEL BALANCE (0) 28 40360-H1000 CHAIN-TIRE (4) 4 OP COUPE
1973 LB110 USA Parts Catalog, page 62-1
