Datsun 1200 used steel and rubber fuel lines. As usual for the time period, no fuel return line was used until the emission-controlled 1989 models.
Chassis fuel line comes from the Fuel Tank into the Engine Bay. A rubber hose will connect it to the Fuel Filter
From the filter, a rubber hose goes to the Fuel pump, then out to the #Fuel Rail
Fuel Rail
17523-H1002 JDM TUBE-fuel pump to carburetor 7011- <> 17522-H1002 < 17522-H1000 -7010 17523-H1900 USA 0671-0370 0 17523-H1902 USA 0470- <> 17523-H1901 17523-H2300 GX
- Right side of rocker cover middle
- Left side of rocker cover rear (non-GX) or front (GX)
- Front of fuel tube bolts to thermostat housing via clamp-bracket
Datsun 1200 Fuel Rail bolts to the rocker cover and thermostat Housing.
B210 Fuel Rail bolts to the cylinder head, allowing for easier rocker cover removal
17522-H8401 TUBE ASSY-FUEL A14T
Late B120 Sunny Truck from Oct 1989 has dual fuel/return line
EFI Fuel Rail
A14E and A15E use a circular fuel rail with attached fuel regulator.
See Main Article: EGI#Fuel_Piping
See Fuel Piping Part Numbers
