Turn signal switch
Revision as of 06:28, 29 November 2017; view current revision
TS/Beam Switch Assembly (dimmer switch) is a key part of the Turn Signals system.
19645.jpgAlbum 19645
The TS/Beam Switch mounts on the Steering Column, just behind the Steering wheel. It contains the turn signal lever stalk, cancelling mechanism and the Horn contact wiring.
Standard switch
25540-H1007 SWITCH COMP-turn signal & dimmer STD, B120 -7803 $155.78 USD
* superceded 25540-H1006
passing switch type
25540-H1100 SWITCH COMP-turn signal & dimmer
* OPTION DX, GL, GX
* Optional on B120 -7803
* Standard on B120 7804-
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
23134.jpgAlbum 23134 19664.jpgAlbum 19664
19662.jpgAlbum 19662 19663.jpgAlbum 19663 23135.jpgAlbum 23135 23136.jpgAlbum 23136
ディマースイッチ ウィンカースイッチ
