TS/Beam Switch Assembly (dimmer switch, flicker switch) is a key part of the Turn Signals system.
Connects To
The turn signal switch connects to:
- Steering Column
- Steering wheel. Specifically the pins on the bottom of the steering wheel hub cancel the turn signals when the wheel is turned
- Horn pad on the steering wheel, via the copper spring-action contact
The TS/Beam Switch mounts on the Steering Column, just behind the Steering wheel. It contains the turn signal lever stalk, cancelling mechanism and the Horn contact wiring.
Standard switch 25540-H1007 SWITCH COMP-turn signal & dimmer STD, B120 -7803 $155.78 USD * superceded 25540-H1006
passing switch type 25540-H1100 SWITCH COMP-turn signal & dimmer * OPTION DX, GL, GX * Optional on B120 -7803 * Standard on B120 7804-
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
ディマースイッチ ウィンカースイッチ
