<-- Back to: Lighting System
Fog Lights were an Option.
B110
Factory Fog Lamps options for the B110 1200 include
- #H1012 Rectangular
- H1014 Round 126mm diameter
- H1016 Round 122mm diameter
- H1018 Round 160mm diameter
- #257 Round 160mm diameter
26151-H1012
Stud-mount type with 'S' icon embossed in the glass
Switch
25160-H1010 ASS'Y-SWITCH, lighting ALL (except GL) 25160-H1110 ASS'Y-SWITCH, lighting GL * 1200 GL * 1400 (PB110) 24100-H1000 ASS'Y-CABLE, fog lamp
PB110
Datsun Sunny 1400 had the fog lamps built into the grille.
Main: PB110 lights#Fog Lights
Aftermarket/Custom
Unknown -- found on 1200 with facelift grille
Datsun 1000
B10 Fog Lamp LENS 160mm
B10 * 89901 Ichikawa 35W (op.) ALL * 18001 Ichikawa 35W (op.) ALL * 18010 Koito sealed beam (op.) ALL * 257 Koito 55W 160mm (op.) Coupe * KB10#Sports Options iodine(沃素) * KB10#Sports Options small
Ichiko 市光 Ichikawa 市川 Koito 小糸
26151-25710
(optional) Coupe KB10 10 26150-25710 ASS'Y-LAMP, fog with bracket (小糸 Koito) (2) 26750-89900 BULB 12V-55W (2) 26151-25710 LENS (2) 26152-25710 RIM (2)
Fog Lamps 26151-25710 LENS 160mm KOITO
Datsun B210
Fog Lamps for B210 Grille
EARLY -1975 * ROUND 26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526 * RECTANGLE S,V OPTION 26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026 25160-H6001 SWITCH COMP.-lighting with fog
LATE 1976- LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens) * top bolt centered 25160-H5827 PB210 GX (op.)DX,GL > 25160-H5825 <> 26150-H5826 * top bolt offset 26150-H7525 S.A14.GX *S.A12,A14-GX *V 26150-H7526 K.A14.GX *K.DX,GL-L16 26150-H7925 L16.GX *L16.GL 26150-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA] 26150-H7428 *K F/OKINAWA 26150-H7926 *L16 F/OKINAWA
25160-H6001 SWITCH ASSY-LIGHTING W/FOG 25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI 25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
H79 L16-powered (B211)
B310
Round headlight B310 Grille only.
LAMP KIT-FOG IKI 26150-H8525 A12 26150-H8925 A14
25370-H8500 SWITCH ASSY-FOG LAMP 25375-S0100 KNOB-FOG LAMP SWITCH
LAMP ASSY-FOG RH 26150-H8500 * #S,K.A12S -7909 * #V.A12 26150-H8900 * K.GX #S.GX #W #DX,GL -7909 * #V.A14
'NISSAN' lamps with adjuster - A14 grille
Aftermarket fog lamps fitted - Strap-fastened to the grille
(SEV MARCHAL 750 759)
フォグ ランプ
