The PB110 "Sunny Excellent 1400" model line for the most part uses unique badging, with only few emblems shared with the Sunny 1200.
image search サニー エクセレント 1400 バッジᴵ
The badges that appear to be the same as A12-powered B110 are:
- #Nissan Full Auto Matic badge (SEDAN)
- #Steering wheel badges
Grille
Coupe and sedan use the same grille.
62312-H2725 'S' shield-shaped radiator grille ornament
Grille can be placed Upside Down
PB110 Excellent 1400 uses the same center badge on its steering wheels as the regular B110 1200.
'Sunny' Quarter Badge
Both sedan & coupe used the Sunny badge -- one on right side, and one on left side.
NOTE:The PB110 emblem is in a different font than the B110 version.
76854-H2800 EMBLEM - body side 'Sunny' (coupe, sedan)
76854-H2800 EMBLEM - body side 'Sunny' (coupe,sedan)
Compare to the B110 sedan badge font 76854-H1000
The fastening pins look to be in the same places horizontally but the vertical alignment may differ?
Coupe
Quarter
Coupe side (rear of quarter panel): 'Sunny' then 'Excellent' followed by: 'GL','GX' or 'Deluxe'
EMBLEM - body side #76854-H2800 'Sunny' (coupe,sedan) 76854-H2500 'Excellent' RH 76855-H2500 'Excellent' LH
MARK 76862-H2500 'Deluxe' mark 76862-H2600 'GL' mark 76862-H2700 'GX' mark
Sunny
#76854-H2800 'Sunny' (coupe,sedan) [~160mm long x ~65mm high]
Excellent
76854-H2500 'Excellent' RH [~199mm long] 76855-H2500 'Excellent' LH
Similar: * PB110 coupe side 'Excellent' 'E' loops up high no background, italics script* PB210 coupe side 'Excellent' 'E' loops midway up solid background, compressed script
Deluxe
76862-H2500 '1400 Deluxe' mark
GL
GX
76862-H2700 'GX' mark ~90 mm long, infill color is the typical 'GX red' although it fades over the years
Rear Panel
Center Rear: 'Excellent' on black-out panel between taillights
EMBLEM - rear finisher
79820-H2525 'EXCELLENT'
Trunk lid fitting
MARK #84822-H2501 '1400 DELUXE' #84822-H2601 '1400 GL' #84822-H2701 '1400 GX' #79200-H2520 'NISSAN FULL AUTO MATIC'
1400 DELUXE
84822-H2501 MARK '1400DELUXE'
1400 GL
84822-H2601 MARK '1400GL'
1400 GX
84822-H2701 MARK '1400GX' * ~180mm long
Automatic Badge (COUPE)
79200-H2520 MARK "NISSAN FULL AUTOMATIC" * similar, but not same as B110 * not same as Sedan
Coupe placement of automatic badge
photo needed
Sedan
#C-pillar #Quarter rear side #Trunk Lid rear
Sedan GL set with R and L c-pillar badges
C-pillar
BADGE 76852-H2800 'Excellent DELUXE' 76852-H2900 'Excellent GL' 76852-H3000 'Excellent GX'
76852-H2800
76852-H2900
76852-H3000
Quarter
#76854-H2800 EMBLEM - body side 'Sunny' (coupe, sedan)
Trunk Lid
MARK #84824-H2800 '1400' #79200-H2820 'NISSAN FULL AUTO MATIC'
EMBLEM for Trim Level (Deluxe, GL or GX) #84822-H2800 'EXCELLENT DELUXE' #84822-H2900 'EXCELLENT GL' #84822-H3000 'EXCELLENT GX'
(left) '1400' + #Automatic
Automatic Badge (SEDAN)
79200-H2820 'Nissan Full Auto Matic' badge * same as late B110 * different from PB110 Coupe
Automatic badge (sedan placement on left side of trunk lid)
84824-H2800
84824-H2800 '1400' MARK PB110 SEDAN ~85mm long (placement: left side trunk lid)
84822-H2800
84822-H2900
84822-H3000
