The wiper motor bolts to the engine compartment firewall. LHD cars sweep to the left, RHD sweeps to the right. For the windscreen washer, see Kangaroo Bag.
The windscreen wipers are about both the outside parts, and the linkage inside the passenger compartment.
Outside Parts: * Wiper Motor * Arms * Blades * "Refills" (Rubber inserts)
Inside Parts: * Linkage * Switch * Fuse
Location
B110 - below the Cowl seam line
B210 - above the Cowl seam line
Wiper Motor
As with the rest of the wiper system, the wiper motor for RHD and LHD are reversed. RHD models have the wiper motor on left side, just below the left bonnet hinge.
Wiper Switch
Wiper Blades, Arms and Inserts
The wiper arm is the metal part that goes back and forth
The wiper blade is the part that snaps into the arms and holds the rubber wiping insert. Datsun calls these two parts together the Blade Assembly
The wiper insert is the rubber strip (the refill) that fits into the blade.
Wiper Arms
The arms are the part outside the windshield, without the rubber insert/refill.
NISSAN GENUINE PARTS ARM ASSY WIPER 26380-H1000
RHD
26380-H1000 ARM ASS'Y-wiper ALL (except GX) 26380-H2300 ARM ASS'Y-wiper GX
LHD
26380-H1600 ASSY-ARM WIPER
upper: '56L' underneath by spring
lower: 'AE' mark on top, visible when installed
Wiper Arm Comparo: B110 vs B210 (Left-hand drive)
Wiper Blades
The blade is the metal part that holds the rubber inserts (refills). These two parts combined are called the blade assembly
Datsun 1200 uses 16" (405mm) wiper blades. The original blade was a stainless steel design marked "56L" on the bottom and "AE" on top. This blade takes 5/16" wide refills (9mm).
NOTE: Your 1200 may have had the original blades replaced at some point. Aftermarket blades may take a different type of rubber insert.
To separate blade from arm, insert knife as shown to lift up tab. Then pull the blade off the arm.
GX-5 option: For high-speed stability, it has a built-in wind spoiler
RHD
* 26360-H1000 BLADE ASS'Y-wiper ALL (except GX) * 26360-H2300 BLADE ASS'Y-wiper GX * 26370-A4600/A4601 BLADE ASS'Y-wiper GX-5, Optional ALL (same as Datsun 510 SSS/CSS blades) * B6370-89901 OLD Type L=400 Black
LHD
26375-U5200 ASSY-BLADE WIPER [Option, High Speed] * replaces 26375-A4601 ASSY-BLADE WIPER OP > 26375-A4600 26360-B5200 ASSY-BLADE WIPER [non-High Speed] B210 26375-H7700 ASSY-BLADE WIPER [Matte Black, 1978) B210
Nissan Accessories
B6370-89915 Nissan Genuine Wiper Blades for B110,B210,B310,F10,510,610,620,720 and more
S-lock type
Aftermarket Blades
Datsun 1200 wiper arms have a 7mm bayonet end.Aftermarket 16" blades that include a 7mm bayonet adapter work with the factory arms.
From $2 each at Rockauto
Compatible blade assemblies include:
- ANCO 14C16ᴳ 14-Series; 16"
- TRICO 30160ᴳ 30 Series; 16"
- HELLA 9XW398114016Iᴳ Standard Blade Teflon Coated 16"
- ANCO 3116ᴳ 31-Series 16"
- TRICO 31160ᴳ View
- TRICO 161ᴳ Exact Fit
- VALEO 604467ᴳ Traditional Titanium Wiper Blade 16"
- ANCO 3016ᴳ Winter Conventional Blade w/ Anti-Icing Boots 16"
- TRICO 37160ᴳ Chill 16"
- TRICO 35160ᴳ Ice Beam Style 16"
- TRICO 16160ᴳ NeoForm with Teflon Coating 16"
- TRICO 25160ᴳ Force 16"
- VALEO 604479ᴳ Titanium Beam Style 16"
- MOTORCRAFT WW1602PFᴳ Premium Flat Blade
- ACDELCO 89916ᴳ Professional Beam Wiper Blades with Spoiler
- TRICO 32160ᴳ Sentry 16"
- ANCO C16UBᴳ Contour 16" beam-type (monoblade)
- TRICO 13180ᴳ Ultra 16" beam type
Refills
For stock wiper arms, the refills are 16" long x 5/16" "Universal" style.
Although many stores recommend a new blade assembly, upon request they may sell you a much more inexpensive refill. It takes another minute to feed the insert into the blade, but you can save a lot of money. Because the original Datsun 1200 blades are quality stainless steel, they still look good and operate fine. Aftermarket blades are plastic or cheap stamped steel that rust in a few years.
NOTE: over the years many 1200 blades have been replaced with quick-replacment blades. If so, the original style refills won't fit.
NOTE: If you have trouble sourcing 5/16 inch x 16" wiper inserts, you can replace the entire metal blade with a different type (see #Aftermarket Blades). The only downside is the extra cost, plus the style (looks) will be different. Replacing the inserts is less expensive e.g. $5 for inserts, $15 for blades.
* NAPA 762-3164ᴳ Package says "Standard" type * TRICO 44-160ᴳ
Trico 44 Series Universal wiper refills are designed to fit most long frame TRICO, Tridon, Roberk, Anco, Pylon and Original Equipment plastic blades. Designed with metal end clips for ease of installation.
Trico 44 Series are rubber bonded to a plastic rib. Longer ones such as the 44-120 (20") can be cut down to 16".
- TRICO 44-120ᴳ November 2022 $7/pair
Linkage
Pivots
B110 has shaft connectors using a C-clip. B210 is similar but uses ball-stud snap-in socket connectors.
Every 1200 has locations for both RHD and LHD pivots
B110 wiper pivots 28870-H1000 [center pivot (double-arm type)] & 28875-H1000 [single-arm] (RHD, use 28870-H1600 for LHD)
B210 wiper pivots 28870-H5000 & 28875-H5000
Pivot Seals
28876-H1000 SEAL-PIVOT WINDSHIELD WIPER 2 $2.43 USD
ピボット リンケージ
Wiper wiring includes the fuse in the Fuse Box and the wires and connectors.
Customizing
See: * Wiper Relocation * Wiper Motor Upgrades * Intermittent Wipers
ワイパー
