The Glove Box is also known as the glove compartment or cubby-hole takes up the passenger side of the Dashboard. Datsun 1200 uses a closing glovebox, with a hinged door (lid or cover). There are two areas to place cups on the inside of the lid.
NOTE: B210 glovebox does not fit the B110.
Latched door | Latchless door (held closed by spring pressure)
Box
The glove box is made out of heavy card stock, and stapled together. 3 pieces of card with 2 strips reinforcing the top and bottom edges.
Top edge: metal (riveted on). Bottom edge: paper (stapled on)
Lid
EARLY GLOVE BOX LID H10 Black DX,GL,GX H26 Blue GL H27 Brown GX
Latchless style (JDM 1200s & early Australia)
1972 USA key code sticker
1972 USA tire inflation sticker
1972 Lid
For the 1972 JDM facelift the lid cover was restyled. The hinge and inside appears to be a continuation.
Lid Hinge
Hinge detail. If often wears away the box material.
If the lid becomes loose, repeated use will start tearing the dash-pad material.
BOX - LHD/RHD same 68960-H1000 ASSY-BOX GLOVE $17.17 USD
LID - LHD 68920-H1900 ASSY-LID GLOVE BOX LHD $60.85 USD
LID - RHD JAPAN LID-GLOVE BOX 68920-H1000 7001-7803 BLACK (including PB110 DX/GL/GX) 68920-H2600 PB110 GL BLUE 68920-H2700 PB110 GX BROWN 68920-H3100 1972 FACELIFT 'SUNNY' 68920-G1060 7804-8910 BROWN 68920-95W00 8910-9403 GRAY
H31 1972 Facelift
Brown
グローブボックス グローブボックスカバー
