Steering Column Cover
Revision as of 01:40, 30 May 2025; view current revision
Category: Steering System
<-- back to Steering Column
The steering column shell finishes the steering column, covering the turn signal switch and provides a mounting surface for the Hazards switch.
NOTE: The same shell molding is finished for either a 32mm or 26.5mm steering column shaft
  • H1015 D32⌀
  • H1010 D26.5⌀
30395.jpgAlbum 30395
The covers encloses the hazards switch and the turn signal switch. It does not cover the steering lock and key lock.
19664.jpgAlbum 19664
The two halves of the shell are fastened together with three screws. The slotted hole is for the column-fixing screw.
2142.jpgAlbum 2142
48470-H1010 COVER SET-STEERING COLUMN [cut for 25.6 mm diameter shaft]
25707.jpgAlbum 25707
RHD
* 48471-H1150 SET-SHELL,steering 3-speed
* 48471-H1170 SET-SHELL,steering 4-speed
08530-42012 SCREW 3
08540-41212 SCREW
column shift (3-speed) with Hazard & Parking Switch
15130.jpgAlbum 15130 2760.jpgAlbum 2760
LHD
USA: Hazard switch only
2136.jpgAlbum 2136
* 48470-H4650 SET-SHELL STEERING WITHOUT PARK LIGHT S 1 EXC OKINAWA 0172- < 48471-H1950 $23.68
* 48471-H1950 SET-SHELL STEERING WITHOUT PARK LIGHT S 1 4 SPEED < 48471-H1650
* 48471-H1650 SET-SHELL STEERING 1 4 SPEED AUTO
* 08530-42012 SCREW-TAPPING M4 3 [Tapping screw, Oval head]
* 08330-41410 SCREW-MACHINE M4 1 [Machine screw, Oval head]
willieoec-img600x450-1327300806aytynf28803.jpg willieoec-img600x450-1327300806qabigk28803.jpg willieoec-img600x450-1327300807wjogry28803.jpg
B120
Early (Black)
* 48470-G1150 COVER SET-STEERING COLUMN [Black] 7510-7803
* 48477-C0400 PLATE-CAUTION
Facelift (Dark Brown)
* 48472-G1160 COVER STEERING COLUMN DARK BROWN LOWER 7804-8910
* 48471-G1160 COVER STEERING COLUMN DARK BROWN UPPER W/LABEL 7804-8608
* 48471-G1900 COVER STEERING COLUMN DARK BROWN UPPER 8608-8910
* 48474-G1270 PLUG-SHIFT LEVER 8608-8910
* 96920-89900 PLATE-CAUTION 8110-8306
* 96920-89910 PLATE-CAUTION 8307-8910
Late Model (Gray)
* 48471-95W00 COVER-STEERING COLUMN GRAY UPPER 8910-
* 48472-95W00 COVER-STEERING COLUMN GRAY LOWER 8910-
* 48470-H1015 COVER SET-STEERING COLUMN
* 48474-95W00 PLUG-SHIFT LEVER 8910-
* 48477-C0400 [99072] PLATE-CAUTION 8910-
Hardware
* 08540-41212 [54=Tapping Screw, truss head
  04 mm diameter,12mm length] 10mm diameter head
* 08530-42012 [53=Tapping Screw, oval head
  04 mm diameter,20mm length] 8mm diameter head
NOTE: It seems the Nissan Catalog has the last two reversed. You need three of the 20mm oval head and one of the 12mm truss head. The 12mm fixes the Cover to the Column. The other three hold the two halves together. The slotted hole in the bottom shell is for the fixing screw.
Black
48470-G1150 1971-1978
30389.jpgAlbum 30389
with 3-button Hazard & Parking switch
Brown
48472-G1160 has Hazard/Parking Switch with locking connector
30390.jpgAlbum 30390 30391.jpgAlbum 30391 30392.jpgAlbum 30392
30393.jpgAlbum 30393 30394.jpgAlbum 30394
Gray
48470-H1015 with 1-button Hazard switch
25814.jpgAlbum 25814
25813.jpgAlbum 25813
6-pin connector: Turn signal switch. T-connector: 3-pin Hazard Switch
25815.jpgAlbum 25815
PB110
H25 Sunny Excellent PB110 hazard & parking (or 510?) with side-mounted Hazard and Parking switch
ステリングコラムカバー ステリング シェル
