Also see: Wipers and Wiper Wiring
Datsun 1200 came with two different wiper switches.
- New (intermittent) Wiper Switch: rectangular 6-connector
- Old (original type) wiper switch: square 6-connector with blue wires
Do not confused with the Lighting switch — both have the same connector.
New Wiper switch (intermittent type) has one blue wire.
Intermittent Wipers for 1200s April 1978 and newer
- 25260-G1060 SWITCH ASSY-WIPER [six spade connector]
Others
B210 Wiper Switch and Lighting Switch
B10
510
620
Datsun 620 truck uses a NILES wiper switches look identical to Datsun 1200 switches, except for a spacer. Some have black escutcheon. All 620 wiper switches use Datsun 1200 knobs.
For USA, 1978-1979 Datun 620 with Deluxe trim have an intermittent wiper switch, which pulls out three clicks (OFF, INT, Low, High). All other use the two-speed switch (OFF, Low, High). So either a 4-position switch with white rectangle connector or a 3-position switch with yellow square connector.
USA Standard and Intermittent switch pictured both connected to the Fiberscope fiber optic illumination unit
Datsun 620 USA catalog COMP-SWITCH,WIPER 25260-B5500 1972 [non-illuminated] 25260-B6401 1973-1975 25260-B8060 1976-1978 25260-B8060 1979 except DX 25260-B9300 1979 DX COMP-SWITCH,WIPER (INTERMITENT) * 28890-B8060 AMP UNIT-INTERMITENT WIPER * 24018-B9300 HARNESS-WIPER * 08360-61291 SCREW 2 * 01552-00411 CLIP [zip tie] 25163-B5011 ESCUTCHEON 25265-H1000 KNOB-WIPER SWITCH 1972 25265-H7001 KNOB-WIPER SWITCH 1973-1979 25170-U0500 ASSY-ATTACHMENT WITH ILLUMINATION 1973-1979 * for illumination lamp * 26261-89900 BULB (12V/3.4W) * 25170-E7500 SOCKET-BULB * 08310-40814 SCREW WITH SPRING WASHER SWITCH-ILLMINATION CONTROL (1973 did not use a switch) * 25280-B8001 1974-1977 * 25280-B8002 1978-1979 * 25280-B9800 1979 Deluxe 25287-B7900 PROTECTOR-ILLUMINATION SWITCH KNOB-ILLUMINATION SWITCH * 25285-P0100 1974-1975 * 25285-B8000 1976-1977 * 25285-R5300 1978-1979 * 25285-U2000 1976-1979
ダットサン トラック 1972 620 Japan catalog C-234 revision 1977.2 25260-B5000 SWITCH COMP.-wiper 25265-H7001 KNOB-wiper switch
ダットサン トラック 620 Japan catalog C-410 revision 1980-05 [1976-1979] 25260-B5000 SWITCH COMP.-wiper -7708 25260-B5005 SWITCH COMP.-wiper 7709- W/INTERMIT * 28890-B8060 AMP-INTERMITENT WIPER 7709- ALL * 28890-R4710 AMP-INTERMITENT WIPER -7708 *ALL [option] *PU T,V,OST 25265-H7001 KNOB-wiper switch
1973-up USA 620 uses a lighted switch as do all USA vehicles starting with the 1973 model year
25260-B5000 JDM non-intermittent
Illuminated
Japan GL/GX USA 1973
Knobs
- 1972: "WIPER/WASHER"
- Newer: picture symbol
- 25265-H1000 KNOB-WIPER SWITCH
- 25265-H4600 KNOB-WIPER SWITCH 0172- USA
- 25265-H7001 KNOB-WIPER SWITCH 0772- USA
- 95265-H3100 KNOB ASS'Y-wiper [1972 Japan]
- 95265-H3101 KNOB ASS'Y-wiper (illumination) [1972 Japan]
B110 #25260-H1001 COMP.-SWITCH, wiper [1970, 1971] 25260-H3100 SWITCH COMP.-wiper [1972] 25260-H2511 SWITCH COMP.-wiper (illumination) (op.) [1972] 95265-H1000 KNOB-wiper switch 95265-H3100 KNOB ASS'Y-wiper [1972] 95265-H3101 KNOB ASS'Y-wiper (illumination) [1972] 25199-H1000 SPRING [ferrule/fastener]
B120 サニトラ スイッチ アッセンブリー、 ワイパー #25260-H1001 SWITCH COMP.-wiper -8109 25260-G1060 SWITCH ASSY-WIPER 7804-8109 F/INTMT WIPER ONLY 25260-G1060 SWITCH ASSY-WIPER 8110- ALL 25163-H1000 ESCUTCHEON-switch 25161-H1000 SPACER 25256-H1000 KNOB-wiper switch 25199-H1000 SPRING
PB110 #25260-H1001 SWITCH COMP.-wiper 25260-H2510 SWITCH COMP.-wiper, with illumination (op.) 95265-H1000 KNOB ASS'Y-wiper 25199-H1000 SPRING 25265-E7500 KNOB-wiper, with illumination (op.) 25170-H2510 LAMP ASS'Y-illumination
#25260-H1001 COMP-SWITCH WIPER 25260-H4600 COMP-SWITCH WIPER 0172- [text knob] 25260-H7001 COMP-SWITCH WIPER 0772- [illuminated] ** superseded 25260-H7001 25265-H1000 KNOB-WIPER SWITCH [symbol] 25265-H4600 KNOB-WIPER SWITCH [text] 25265-H7001 KNOB-WIPER SWITCH [green illuminated] [also B210]** superseded 25265-H7000 25265-H5200 KNOB-WIPER SWITCH 25199-H1000 SPRING
25170-H2510 ASSY-LAMP,ILLUMINATION 0772-
08964-10510 NUT-SPRING 0772-
08540-51612 SCREW 0772-
25260-H1001
standard wiper switch 25260-H1001
NILES TYPED JAPAN
