The Datsun 1200 used a 1.5 inch exhaust system with a very, very, very quiet muffler — the factory Datsun 1200 muffler was so quiet you couldn't hear the engine running at idle. The muffler included a permanently attached tail pipe.
Exhaust Pipe, Muffler, Tail Pipe
Original mufflers came with integrated exhaust pipe - Bottom (old) is the factory piece. This pipe was part of the muffler.
The muffler should flow at least 2.2 cfm per flywheel HP. For a 69 hp A12, that is 152 cfm, easily achieved with the factory 1-1/2 inch piping.
Muffler is located just in front of the Rear Axle
Coupe & Sedan have the same muffler location, only the bend shape of the tailpipe portion differs a little. This bend allows the pipe to go over the rear axle.
The body of the muffler is suspended by two rubber rings and contributes to quietness of the exhaust system (there are no rattles from the exhaust).
Tailpipe exits at the rear, below the bumper
Size
Muffler measurements from my 1200 sedan with factory original muffler:
* 11-5/8" Shell length * 8-1/4" Shell oval width * 3-3/4" Shell oval height * 1.5" front inlet, centered * 1.5" rear outlet, on far left of oval
There is enough room under a sedan that a muffler about 2" longer may fit.
The 1200 GX exhaust system is finished with a small resonator and a muffler later on. The resonator terminates the air column at an exact lenght for optimum power, and also reduces harmonic noise.
A15E EGI dual exhaust (92 hp). This one has been modified to remove the muffler for racing where noise limits do not apply
Nissan JDM Catalog 20010-H1000 TUBE ASS'Y-exhaust, front - ALL (exc. GX, Automatic)20010-H1020 TUBE ASS'Y-exhaust, front - Automatic 20010-H2301 TUBE ASS'Y-exhaust, front - GX 4-speed 20010-H3400 TUBE ASS'Y-exhaust, front - GXA (GX Automatic) 20010-H7200 TUBE ASS'Y-exhaust, front - GX-5 20603-H2300 GASKET-exhaust tube - GX and GX-5 20602-27700 NUT-fixing, tube end (2) - ALL (except GX, GX-5) 20602-27700 NUT-fixing, tube end - GX-5 08915-13810 WASTHER-spring lock (3) - GX-5 20635-18000 STOPPER-muffler bound - ALL 20100-H1000 MUFFLER ASS'Y-with rear tube - Sedan 20100-H1400 MUFFLER ASS'Y-with rear tube - Van 20100-H2500 MUFFLER ASS'Y-with rear tube - Coupe 20630-18000 RING-rubber, muffler clamp (2) 20620-H1000 CLIP-tube, exhaust
06915-43810 WASHER-plain (2) 08915-13810 WASHER-lock 08110-85510 or 08110-86010 BOLT 08911-10810 NUT 20640-18000 STRAP-exhaust hanger
20641-18000 WASHER-plain (2) 08911-10810 NUT (2) 08915-13810 WASHER-lock (2) 08110-82210 BOLT (2) 20321-H2500 FINISHER-exhaust - GL, GX 20720-N2225 SEALER KIT-exhaust tube joint - ALL
USA Catalog 20010-H3100 ASSY-TUBE EXHAUST FRONT Sedan Manual Trans > 20010-H1000 $34.92 20100-H7001 ASSY-MUFFLER WITH REAR TUBE Sedan Manual Trans > 20100-H1000 $84.72 NLA 20321-H2000 FINISHER-EXHAUST (chrome extension) NLA 20321-H2500 FINISHER-EXHAUST (chrome extension) $18.36 NLA
Aftermarket Replacements
Aftermarket 1.5
- Dynomax 17700 ("Thrush turbo"),similar shape to stock. Oval 3.25 in. x 7.75 in. Case Length: 11 in. Overall length: 16 in. Width: 7.750 in. Thickness: 3.25 in.
1-1/2 pipe clamps: * Merit M112 or U112 * Napa BK 7335325
Rubber Donut Hangers * Merit 8166 ???
Aftermarket GX (is it the same as the S110 gasket?) * Gasket: Merit 8696 * Pipe: (1981 Nissan 720), Merit 48316
Exhaust Tip - 1-1/2" diameter * Merit 9821
Aftermarket 1.75
- Walker Super Turbo WLK-17771ᴳ
- Walker SoundFX 17909ᴳ 1.75" in/out 14x6.65 round case
- Dynomax 17771, 160 cfm
- Walker 17881 Pro-Fitᴳ, 1.75" offset/center
- Magnaflow 11123ᴳ with offset. Might be too long, it is 14" body, but it is Stainless Steel, best buy $123 in 2021
- Borla XR-1: BOR-40483ᴳ Stainless Steel, 1.75 in, 2.25 ex, 13x4.5 round case, turn-down outlet
Can Muffler
Hot-dog style mufflers (cannons or "fart cans") are mainly for looks. Having the muffler at the very end of the exhaust makes it louder, and most cans are fiberglass packed tubes ("glass-pack") which are by nature noisy. They are simply a straight-through pipe with baffles in the tube sides.
When fitting a can muffler, it is advised to also fit a large normal muffler under the car.
Dual Outlet
Arms
マフラー (アームズ)ᴳ arms-eng.comᴬᴿᶜᴴᴵⱽᴱ
2025 prices * Stainless: ~900 USD * Titanium: ~1700 USD
ARMS - Side Muffler with stainless side tubes to fit 1200 ute. Volume 94db. Main pipe φ50, tail end φ50 (2" pipes). Dual slash cut or straight cut.
Nismo
"FISCO" and "NISMO" was fitted to Sunny Truck with A15
Finish Mufflers
Add a stylish stainless steel muffler at the end of a full exhaust system.
straight-through "cannon" muffler (a straight pipe, peforated with holes and fiberglass-packed chamber) is VERY loud
