Gas Station Information
USA 1972 Owners manual (see page 43 for details): ![]() |
Opening the hood (bonnet):
- Brake Cylinders: Fill to top line (do not fill to the top of the reservior)
- Clutch Master Cylinder: Fill to top line (do not fill to the top of the reservior)
- Radiator: Fill to 1 inch (2.5 mm) below filler cap with Coolant
- With heater: 5-3/16 US quarts (4-15/16 Imperial qts) or 4.9 liter
- W/o heater: 4-7/16 US quarts (3-11/16 Imperial qts)
- Windshield washer tank (windscreen washer)
USA 1972 Owners manual (see page 25 for details): ![]() |
- Engine Oil: Recommend Oil Viscosity Number varies by ambient temperature range of your climate.
- Oil pan capacity: 2-7/8 US qts (2-3/8 Imp. qts) or 2.7 liter
- Oil filter: 1-1/8 US pints (1 Imp. pint) or 0.54 liter
- See Oil Specifications for more details.
- Battery: fill each cell to about 0.2 inch (5 mm) above the plates. Most batteries have a fill indicator. Do not overfill.
USA 1972 Owners manual (see page 24 for details):
It is normal to add some engine oil between the 3,000 mile (5,000 km) oil changes. |
- Transmission Gear Oil:
- Differential Gear Oil:
- Automatic Transmission Oil:
- Multipurpose grease: For "lube and filter" job and other Lubrication uses
- Brake Fluid:
- Clutch Fluid:
- Antifreeze for radiator: Coolant
During freezing weather... |
- Petrol: 9 Imperial gallons
- Gasoline: 10 US gallons
- 87 R+M/2, or 90 RON equivalent. See Fuel Requirements
USA 1972 Owners manual (see page 22 for details):
