A12GX Part Numbers
Revision as of 04:56, 23 December 2009; view current revision
Categories: Engine Mechanical | Hitachi Twin Carb
GX unique parts
Also see:
Comparison
Cylinder Heads
  • 11041-H2300,11041-H2301,11041-H2302 HEAD ASSY-CYLINDER A12 GX B110
  • 11041-H5702 HEAD ASS'Y-cylinder A12T B210
  • 11041-M0801 HEAD ASSY-CYLINDER A12T E10
  • 11041-M2460 HEAD ASSY-CYLINDER A14T B210, F10
Engine
  • 11010-H2300 BLOCK ASS'Y-cylinder
  • 10001-H2350 ENGINE ASS'Y-with clutch (High Gas)
  • 10001-H2355 ENGINE ASS'Y-with clutch (Reg Gas)
  • 10001-H2351 ENGINE ASS'Y-with clutch (????) (High Gas) op.
  • 10001-H2356 ENGINE ASS'Y-with clutch (????) (Reg Gas) op.
  • 10001-H7205 ENGINE ASS'Y-with clutch (High Gas) GX-5
  • 10001-H7255 ENGINE ASS'Y-with clutch (Reg Gas) GX-5
  • 10001-H7251 ENGINE ASS'Y-with clutch (????) (High Gas) GX-5 op.
  • 10001-H7256 ENGINE ASS'Y-with clutch (????) (Reg Gas) GX-5 op.
  • 10100-H4250 ENGINE ASS'Y-with drive plate (Reg Gas) GX-A
  • 10102-H2300 ENGINE ASS'Y-bare (High Gas)
    • 12010-18021 PISTON SET-with piston pin (std size) (High Gas)
    • 21045-H2300 PIPE-suction, water pump
    • 13001-H2300 CAMSHAFT ASS'Y
  • 10102-H2305 ENGINE ASS'Y-bare (Reg Gas)
  • 10103-H2300 ENGINE ASS'Y-short (High Gas)
  • 10103-H2305 ENGINE ASS'Y-short (Reg Gas)
  • 10101-H2325 ENGINE GASKET KIT GX
  • 10101-H2326 ENGINE GASKET KIT-(from '72-6) GX
  • 10101-H2327 ENGINE GASKET KIT-(from '73-4) GX
  • 30411-H5000 PLATE-engine rear, GX-5
  • 08110-62010 BOLT-fixing oil pan (1 of the 12 bolts is different from regular engine)
  • OIL PUMP -- same as regular engine
Cylinder Head and Valve Cover
  • 13264-H2300 COVER ASS'Y-valve rocker GX
  • 11041-H2300 HEAD ASS'Y-cylinder GX
    • 13201-H2300 VALVE-intake 4
    • 13203-H2300 SPRING-valve outer 8
    • 13204-H2301 SPRING-valve inner 8
    • 13204-M0820 HIGH-PERFORMANCE VALVE SPRING/INNER (8) Datsun Competition
      • same as 12109-M0820(?)
    • 13205-H2300 SEAT-valve spring 8
    • 13207-H2300 SEAL-oil valve 8
    • 13207-H2301 SEAL-oil valve (from '72-7) 8 GX
    • 13207-H2310 SEAL-oil valve (from '72-8) 8 GX
    • 13202-H2300 VALVE-exhaust 4
    • DELETE FROM GX: 13219-H1000 SHROUD-inner valve (from '73-4) 8
  • 11041-H2301 HEAD ASS'Y-cylinder (from '73-3)
  • 13212-H2310 GUIDE-valve, intake GX
  • 13213-H2310 GUIDE-valve, exhaust GX
  • 08213-82810 STUD-manifold (same as standad, but with 2 extra studs)
  • 11044-H2300 GASKET-cylinder head GX
  • 11044-H2325 GASKET-cylinder head GX (from '72-6)
  • 11045-H2300 RING "O" (from '72-6, goes with new type head gasket)
  • 11056-H2301 BOLT-cylinder head (9 total)
  • 11057-H2301 BOLT-cylinder head, center (1 total)
  • 10005-H2301 SLINGER-engine front (from '73-3)
    • [10005-H230x is in the Cherry catalog, not listed in 1200 catalog]
    • 10005-H2300 SLINGER-engine front
Manifold
  • 1 14003-H2330 MANIFOLD-intake
    • 1974 Nissan Cherry catalog lists 14003-H5731 for A12T engine
  • 2 00933-11800 PLUG-welch 2
  • 3 00933-12000 PLUG-welch 1
  • 4 08931-30200 PLUG-taper 1
  • 5 14059-H2300 CONNECTOR-water hose 1
  • 6 08213-82810 STUD-carburetor fixing 4 (same as manifold-to-head studs)
  • 7 14004-H2300 MANIFOLD-exhaust
  • 8 08213-82800 STUD-fixing exhaust tube 3
  • 9 08911-10810 NUT-fixing manifold 11
  • 10 08915-13810 WASHER-lock, fixing manifold 7
  • 11 14037-32200 YOKE-manifold 4
  • 12 14035-H2300 GASKET-manifold, (steel best)
  • 13 14055-H2301 HOSE-manifold water
  • 14 08723-12000 CLAMP-hose 2
  • 15 14330-H2301 PLATE-heat shield
    • 14330-H2302 PLATE-heat shield (from '72-11)
  • 16 16174-H2300 INSULATOR-carburetor 2
  • 17 16175-A5100 GASKET-insulator 2
  • 18 11810-A3500 VALVE ASS'Y-crank case emission control
  • 19 11826-H2300 HOSE-rocker cover to control valve
  • 20 16572-10801 CLAMP-hose
  • 21 16572-H1000 CLAMP-hose
Nissan Competition
Source: 1984 Nissan Competition Catalog
  • 16010-H2336 38MM SU CARB (FRONT)
  • 16010-H2337 38MM SU CARB (REAR)
  • 14003-H2330 GX INTAKE MANIFOLD
  • 11826-H2300 BLOCK TO MANIFOLD HOSE
  • 14035-H2300 MANIFOLD GASKET
  • 14033-H2300 GX HEAT SHIELD
  • 16031-H2300 OVERFLOW TUBE/FRONT
  • 16031-H2301 OVERFLOW TUBE/REAR
  • 16174-H2300 INSULATOR (2)
  • 16175-A5100 INSULATOR GASKET (2)
  • 16361-H2300 THROTTLE SHAFT ASSY
  • 16376-H2300 ACCELERTOR CABLE BRACKET
  • 17523-H2302 FUEL TUBE
  • 18410-H2302 CHOKE CABLE
Carburetor
  • 16010-H2332 CARBURETOR ASS'Y-twin, front
  • 16010-H2334 CARBURETOR ASS'Y-twin, front (from '71-11)
  • 16010-H2336 CARBURETOR ASS'Y-twin, front (from '73-1)
  • 16010-H2333 CARBURETOR ASS'Y-twin, rear
  • 16010-H2335 CARBURETOR ASS'Y-twin, rear (from '71-11)
  • 16010-H2337 CARBURETOR ASS'Y-twin, rear (from '73-1)
  • 1 16122-H2310 SHAFT ASS'Y-throttle
  • 2 16324-H2310 FILTER ASS'Y-piston
  • 3 16144-H2310 NUT ASS'Y-idle adjusting
    16144-H2311 NUT ASS'Y-idle adjusting (from '71-11)
  • 4 16145-H2310 SPRING-idle adjusting screw 2
  • 5 16355-H2310 NOZZLE ASS'Y
    16355-H2310 NOZZLE ASS'Y (from '71-11)
  • (6) 16127-H2310 PLATE ASS'Y-throttle adjusting, front
  • 6 16127-H2311 PLATE ASS'Y-throttle adjusting, rear
  • (7) 16277-H2312 LEVER ASS'Y-first idle, front
  • 7 16277-H2313 LEVER ASS'Y-first idle, rear
    16277-H2315 LEVER ASS'Y-first idle, rear (from '71-11)
    16134-H2310 LEVER ASS'Y-throttle, front
  • 8 16134-H2313 LEVER ASS'Y-throttle, rear
  • 9 16083-58000 SLEEVE 2
  • 10 16214-25610 NUT (8 radius) 2
  • 11 16116-H2310 SLEEVE 2
  • 12 16190-10401 SPRING-starter, return (B)
  • 12 16190-74310 SPRING-starter, return (A)
  • 13 16147-14611 PLATE-cam (B)
  • 13 16147-74311 PLATE-cam (A)
  • 14 16116-14610 SLEEVE (B)
  • 15 16157-14610 SPRING-connecting (B)
  • 15 16157-74310 SPRING-connecting (A)
  • 16 16238-H2310 LEVER ASS'Y-choke, front
  • 16 16238-H2311 LEVER ASS'Y-choke, rear
  • 17 16147-H2310 PLATE-connection, front
  • 17 16147-H2311 PLATE-connection, rear
  • 18 16227-H2300 ADAPTER-front
  • 18 16227-H2311 ADAPTER-rear
  • 19 16322-E3210 BOLT (8Ø) (2)
  • 20 16356-25610 PIPE-rubber, fuel (2)
  • 21 16358-E4310 CLIP-fuel pipe (4)
  • 22 16061-10400 FLOAT
  • 23 16101-H1000 VALVE ASS'Y-needle
    16101-18010 VALVE ASS'Y-needle (from '71-11)
  • 24 16062-10400 LEVER-float (up to '71-10) (2)
    from '71-11
    • 16062-H2310 LEVER-float, front (from '71-11) (1)
    • 16062-H2710 LEVER-float, rear (from '71-11) (1)
  • 25 16066-25610 SHAFT-float
  • 26 16331-10400 SCREW-nipple set
  • 27 16098-25710 FILTER
  • 28 16554-H2310 JET-needle
  • 28 16554-H2316 JET-needle (from '71-11)
  • 29 16031-A8710 PLUG-drain
  • 30 16148-H2310 CLAMP-choke, front
  • 30 16149-H2310 CLAMP-choke, rear
    16149-H2311 CLAMP-choke, rear (from '71-11)
  • 31 16346-10615 SPRING-suction
  • 32 16341-25610 NUT ASS'Y-oil cap
  • 33 16194-H2310 SPRING-throttle
    16194-H2311 SPRING-throttle (from '71-11)
    16194-H2312 SPRING-throttle (from '73-1)
  • 16455-H2310 GASKET SET
    • 16335-14610 PACKING (10Ø) (4)
    • GASKET-float chamber (2)
    • WASHER (8Ø) (2)
    • PACKING (18Ø) (2)
    • WASHER (10Ø) (2)
Carburetor Linkage
  • 4 16361-H2300 SHAFT ASS'Y-throttle
  • 5 16376-H2300 BRACKET-accelerator cable
  • 6 08915-13510 WASHER-lock,fixing accelerator cable bracket 2
  • 7 08460-51000 SCREW-fixing accelerator cable bracket 2
  • 8 16031-H2300 TUBE-over flow, front
  • 9 16031-H2301 TUBE-over flow, rear
16031-15801 TUBE-over flow, (Vinyl 6 x 9 x 160) 2
Choke Linkage
  • 18410-H2301 WIRE COMP,-choke control GX
    18410-H2302 WIRE COMP,-choke control (from '72-12) GX
    • 24250-89929 GROMMET
  • 18415-H2300 KNOB ASS'Y-choke control
    18415-H1000 KNOB ASS'Y-choke control (from '72-12)
Air Cleaner
  • 1 16500-H2300 CLEANER ASS'Y-air (for twin)
  • 2 16526-H2300 COVER ASS'Y-upper
  • 3 16536-H2300 PACKING
  • 4 16546-H2300 ELEMENT ASS'Y-paper
  • 5 16528-H2300 COVER ASS'Y-lower
  • 6 16536-H2300 PACKING
  • 7 16523-12200 GASKET (carburetor to air cleaner) 2
  • 8 16548-22000 PACKING
  • 9 16568-08000 PACKING
  • 10 16516-H2300 BOLT ASS'Y-center 2
  • 11 08120-81662 BOLT (fixing air cleaner to carburetor) 4
  • 12 11828-H2300 HOSE-air cleaner to pipe connector
  • 13 16572-H1000 CLAMP-hose
AIR CLEANER (HOT AIR TYPE) - Optional
  • 16500-H2310 CLEANER ASS'Y-air
  • 14 16590-H2310 COVER-manifold
  • 15 16530-H2310 DUCT-cover to air cleaner
  • 16 14896-C0600 BAND-hose
Fuel Piping
  • 14 17523-H2302 TUBE-fuel pump to carburetor
  • 15 17106-H2300 CLAMP-fuel tube
  • 16 17107-H2300 CLAMP-fuel tube
  • 17 17108-H2300 CLAMP-fuel tube
  • 18 08740-08020 HOSE-fuel (l=80mm) 3
  • 19 08723-11400 CLAMP-hose 6
Fuel Pump
  • 17010-H2302 PUMP ASS'Y-fuel GX
  • 17010-H2303 PUMP ASS'Y-fuel (ISO hose) (from '71-11) GX
  • 21060-A4600 FAN-cooling
Engine Electrical
HITACHI
  • 22100-H2300 DISTRIBUTOR ASS'Y-(D407-54) (High Gas)
    • 22110-14600 SPRING SET-governor (High Gas)
    • 22132-14605 CAM-ASS'Y (High Gas)
    • DELETE (?) 22301-H1000 CONTROL ASS'Y-vacuum (except GX-H)
  • 22100-18006 DISTRIBUTOR ASS'Y-(D412-53K) (Reg Gas)
    • 22110-18001 SPRING SET-governor (Reg Gas)
    • 22132-18005 CAM-ASS'Y (Reg Gas)
MITSUBISHI
  • 22100-H18016 DISTRIBUTOR ASS'Y-(TVA-4F2L) (Reg Gas)
    • 22127-18010 SPRING-governor (Reg Gas) 2
  • 22318-E3001 TUBE-distributor vacuum advance (l = 480 mm)
  • GX RESISTOR IGNITION COIL
  • 22401-A4616 PLUG-spark (N.G.K.=BP6ES) 4 [regular A12 is BP5ES]
  • 22401-A4705 PLUG-spark (??=L45PW) 4 (Hitachi)
Transmission
CLUTCH for GX is same with regular models
  • 31063-H3410 CONNECTOR-vacuum tube GXA
  • 32865-H2300 KNOB-control lever 4-speed
  • 32010-H7251 TRANSMISSION ASS'Y (17/5) GX-5
    • 32865-H7200 KNOB-control lever GX-5
    • 11322-H7200 MEMBER-engine mounting, rear
    11322-H7201 MEMBER-engine mounting, rear (from '72-10)
    • 11323-H7200 STOPPER-engine mounting, rear
    • 24033-H7200 CABLE-reverse lamp switch GX-5
Misc
  • 17501-H7210 TUBE-fuel (fuel tank to engine) Coupe GX-5
  • 24103-H7200 [Wiring] HARNESS-instrument GX-5
  • 24043-H2025 CABLE SET-clock (for console box)
  • 24043-H2001 CABLE-clock, front
  • 24044-H2000 CABLE-clock, rear
See Also:
  • 26350-89906 BUZZER-back warning GX-5
  • 26351-H7200 BRACKET-buzzer GX-5
  • 08513-51012 SCREW-stopping (for buzzer bracket) GX-5
  • 26380-H2300 ARM ASS'Y-wiper 2
    • 26381-H2300 NUT-wiper arm 2
  • 28360-H2300 BLADE ASS'Y-wiper 2
  • 26370-A4001 BLADE ASS'Y-wiper 2 GX-5 (op. on all other models)
  • 54611-H2300 BAR-torsion, front stabilizer [antiswaybar]
    • 54617-H2300 BUSHING-stabilizer
  • 40315-H1900 CAP-road wheel [hubcap]
GX and GL use a different wheel than STD and DX. Slightly different to fit over disc brakes?
  • 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose GX-5
    46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose (from '73-5) GX-5
Exhaust Piping
  • 20010-H2301 TUBE ASS'Y-exhaust, front - GX 4-speed
  • 20010-H3400 TUBE ASS'Y-exhaust, front - GXA (GX Automatic)
  • 20010-H7200 TUBE ASS'Y-exhaust, front - GX-5
  • 20603-H2300 GASKET-exhaust tube - GX and GX-5
  • 20602-27700 NUT-fixing, tube end - GX-5
  • 08915-13810 WASTHER-spring lock (3) - GX-5
  • 20321-H2500 FINISHER-exhaust - GL, GX [chrome extension]
Radiator
  • 21400-H2300 RADIATOR ASS'Y
  • 21506-H2301 HOSE ASS'Y-radiator, lower
