CA200
From Datsun 1200 Club
CA200 is a Nissan straight axle fitted with R200 gearset. It is the only (?) Nissan live axle with Salisbury/GM type differential, meaning the gear carrier built into the axle (i.e. it has a non-removable center section).
R31 w/28-spline axles (easily confused with BW diff)
The ratio is stamped on the engine compartment plate. The CA200 is the non-LSD version. The C200 is the LSD version.
CA43 code = 4.3 ratio
1979-1980 720 Pickup automatic transmission (some)
1979-1985 720 Pickup 4WD (some)
1981-1983 720 pickup Longbed 4WD (some)
1983-1985 720 pickup 2WD (some)
1983-1985 720 pickup Z24 Long Bed (some)
Similar
For comparison
GM salisbury-type 10-bolt out of Holden Commodore VN
Borg Warner 78 out of Australia-built R31
640.JPGAlbum 640 2143.jpgAlbum 2143
R31
JAPAN
R31 Wagon with RB20T SOHC Turbo 1986-1990 4.11 (build dates 8601-9005)
C22
GC22 JPN Vanette
 CA200 8611- some 4WD
 * OP. LSD
 * LSD use 38423-C6000 side gears
Gasket
GASKET-GEAR CARRIER
38353-Y0801
38353-Y0800
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=CA200"
This page has been accessed 7,477 times. This page was last modified 09:45, 1 February 2017. Content is available under Datsun 1200 Club.
