Carpet
From Datsun 1200 Club
Category: Body
Datsun 1200 came standard with #rubber mats covering the floor — and with carpet covering the transmission tunnel in the front seat area. Optional was full carpeting.
1302.jpgAlbum 1302
Full Carpeting
Full carpet was option but rare in USA (most only seen on some coupes).
28287.jpgAlbum 28287
It is a four-piece set:
1. Right Front Floor
2. Tunnel Carpet
3. Left Front floor
4. Rear floor
The rear piece stretches across the car and over the rear portion of the tunnel.
15944.jpgAlbum 15944
USA Catalog COUPE, SEDAN
74902-H2031 CARPET-FLOOR FRONT RH OP
74904 see #Tunnnel Carpet
74903-H2031 CARPET-FLOOR FRONT LH OP COUPE, SEDAN.MANUAL
74903-H2025 CARPET-FLOOR FRONT LH OP SEDAN.AUTOMATIC
74907-H1102 CARPET-FLOOR REAR COUPE <> 74907-H1101
74907-H2011 CARPET-FLOOR REAR OP
Each floor piece is secured by a hook in all corners. The tunnel piece is neither glued down nor hooked.
61140-0502P HOOK (12)
08530-52512 SCREW-TAPPING (12)
Colors
The carpet cloth is houndstooth pattern.
blue/black
yellow/black
gray/black
Blue pattern
28286.jpgAlbum 28286
Gray pattern
13667.jpgAlbum 13667
Yellow pattern
1976.jpgAlbum 1976
Tunnel Carpet
Except for Standard 1200s, all 1200s were fitted with a piece of carpet covering the tunnel forward of the front seats. Standards came with a #rubber mat covering the tunnel.
9970.jpgAlbum 9970
74904-H2025 CARPET-FLOOR TUNNEL AUTOMATIC
74904-H2031 CARPET-FLOOR TUNNEL 4-SPEED
H20     designed for 1200 GL
The tunnel piece has a cutout for the shifter hole
7575.jpgAlbum 7575
Upscale GL and GX models had a 'foot patch' on the tunnel carpet next to the clutch pedal. All USA cars were fitted with the GL-type tunnel carpet but in a unique blue color.
1976.jpgAlbum 1976 7479.jpgAlbum 7479
Rubber Mats
Ute
Behind-the-seat carpet
5531.jpgAlbum 5531
It is glued, it goes to the lip which aligns with the base of the tray. This helps reduce Roadnoise, as from factory would only cover floor.
Parts
Tunnel carpet is NLA (No Longer Available) from Nissan in the USA, Canada and Japan.
AUS: Knox carpet fits the automatic tunnel, is a bit large for the standard manual transmission tunnel and will gather about the gathers at the sides near the doors. Fitting an extra layer of insulation will help.
AUS: Trufit
USA: Mail Order custom carpet from ACC in Alabama
Knox carpet
Insulation
From the factory, only the tunnel had insulation, a jute type. Additionally, there are some asbestos heat shields on the floor which also have some noise-dampening characteristics.
Factory jute insulation was glued to the tunnel
10146_4bfa3c29a9c04.jpgPost 318721
Fitting carpet insulation will significantly quiet the 1200 cabin — even under the factory rubber mats.
28288.jpgAlbum 28288
The Coin Trays will finish off the installation
23056.jpgAlbum 23056
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Carpet"
This page has been accessed 31,335 times. This page was last modified 17:15, 7 March 2025. Content is available under Datsun 1200 Club.
