Engine ID Mark
From Datsun 1200 Club
Category: A-series Engines
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
The engine number is stamped on the engine block itself. It positively identifies the engine size (e.g. A12) as well as the serial number. The mark is always on the left (distributor) side of a Datsun A-series engine, but the location varies with the year. If you do not see the number, wipe the grease off the engine block.
Engine Number
Left Side of Engine
To about 1980  |  From about 1981
Below #4 plug  |  Below #2 plug
1970-1973
1970-1973 A12 Engine ID Mark is below #4 spark plug, on jutting pad (above starter)
174_50f624caf00ca.jpgUpload click to view 770.jpgAlbum 770 174_50033e9468514.jpgUpload click to view 174_50f624c1ed952.jpgUpload click to view
1973-1981
Model years 1974~1981 A12 ID Mark, below #4 plug
the pad is flat to the engine
Stamp is below #4 spark plug, on vertical pad
17147.jpgAlbum click to view
Early Tall-Block (A13/A14/A15) has large space between serial number pad and cylinder head
16699.jpgAlbum 16699
A13 tall block (1974 model year)
28747.jpgAlbum 28747
28748.jpgAlbum 28748
1981-1995
Model years 1982-1995 A12 ID Mark Type B is below #2 & #3 spark plugs, center of block, above fuel pump, forward of distributor
23706.jpgAlbum 23706 23705.jpgAlbum 23705
A12-E
26177.jpgAlbum 26177
Late: above fuel pump boss, below #2 plug
18742.jpgAlbum 18742 23704.jpgAlbum 23704
Late Tall-block (A14 or A15) ID Mark location is below #2 & #3 spark plugs, center of block, above fuel pump, forward of distributor
18238.jpgAlbum 18238
Matching Numbers
If the engine is the original one, the serial number will match that on the Model Number Plate.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Engine_ID_Mark"
This page has been accessed 30,221 times. This page was last modified 08:23, 8 February 2023. Content is available under Datsun 1200 Club.
