A15 Engine
(Redirected from A15)
Categories: A-series Engines | Engine Mechanical
The A15 is a 1488cc) engine produced from 1979 through 2209 (it is for sale in the 2009 Nissan C22 Vanette in Malaysia). The stroke was increased by 5 mm from the A14 engine's 77 mm to measure 82 mm. It produces 85hp. It used a different block casting but the same 'tall-block' deck height as the A14. In the Roadstar it is capable of 49 mpg (17,3 km/L). A fuel injected version of the A15 (A15E) was offered in Asian markets.
  • A15 ID Mark
  • Notice how the block extends above the timing cover by about 1 inch
Horsepower
From 67 to 80 HP
USA A15 lo-power fuel economy version with Automatic
Engine Family A140F
67 HP @ 5200 RPM (SAE)
Plates after 1980 do not list the Horsepower.
A14 vs A15
A15 uses the second A14 block casting (same block as A14):
  • 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99' bore size
    • Bore: 76 mm
    • Stroke A15: 82mm
    • Stroke A14: 77mm
    • Pin Height: The A15 piston has a 30mm pin to crown height, while the A14 has a 32.5mm height
Earlier A14 blocks were slightly different. The A15 oil pan has slight bumps in the side to allow the larger crank to swing without touch the pan sides.
  • Comparo: Early A14 block with Late A14/A15 block
Applications
  • 1974-1978 Nissan (commercial) forklift (Asian markets)
Datsun B310
  • 1979-1982 Datsun B310 (rear-wheel drive) a.k.a. 210, Sunny or 150Y
  • 1980-1982 Datsun N10 (front wheel drive) a.k.a. 310, Pulsar or Cherry
  • Nissan Vanette C120 June 1980- November 1988
  • Nissan Vanette C22 September 1985- June 1991
  • Nissan Vanette SS van & SE truck (S20) April 1994- 1999
Malaysia
  • Nissan Vanette C22 (1984-2009)
New Zealand
  • Sportstar and Roadstar utes (B120) from Nissan New Zealand 1980-1985
Pistons
North America
B310
PISTON SET-WITH PIN
STANDARD
12010-H9714 A15 CAL	-0780
12010-H9802 A15 CAL	0880-
12010-H9704 A15 FED	-0779
12010-H9714 A15 FED	0879-0780
12010-H9802 A15 FED	0880-
12010-H9714 A15 CAN	0879-
+0.5 mm oversize
12010-H9804 (0.50 O.S.) A15 USA	0880-
12010-H9716 (0.50 O.S.) A15 CAL	-0780
12010-H9706 (0.50 O.S.) A15 FED	-0780
12010-H9716 (0.50 O.S.) A15 CAN	0879-0378
+1.0 mm oversize
12010-H9806 (1.00 O.S.) A15 USA	0880-
12010-H9718 (1.00 O.S.) A15 CAL	-0780
12010-H9708 (1.00 O.S.) A15 FED	-0780
12010-H9920 (1.00 O.S.) A15 FED(MAN)	-0780
12010-H9718 (1.00 O.S.) A15 CAN	0879-
N10
12010-H9802 A15 STD
12010-H9804 A15 +0.5
12010-H9806 A15 +1.0
Nissan Malaysia
Brand new 2010 C22 Nissan Vanette.
Vanette Specs
C120 JDM - H89 Type A15
11041-H8904 HEAD ASSY-CYLINDER A14 Non-Emission Type
* 13201-H6200 VALVE-INTAKE 37mm
* 13202-H6200 VALVE-EXHAUST 30mm
11044-H7202 GASKET-HEAD 76mm
14035-05H01 GASKET-MANIFOLD <> 14035-H8901
* Wet Type
* New Bolt Pattern
13001-H6200 CAMSHAFT A15.K -8209 [248/256 typical use: A14/A15]
13001-H9800 CAMSHAFT A15.(V,T) -8209 [244/248 typical use:emission]
13001-H9800 CAMSHAFT 8209-
C22 JDM -
11041-G5100, 11041-G5101 CYLINDER HEAD
* Intake valves: 37mm 13201-H6200
* Exhaust valves: 30mm 13202-H6200
14035-05H01
* Wet Type
* New Bolt Pattern
* 244/248 Duration
th_470.jpg th_471.jpg 1869.jpg 1870.jpg 7630.jpg 8022.jpg 10202.jpg 16259.jpg 17776.jpg
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=A15_Engine"
This page has been accessed 12,296 times. This page was last modified 05:54, 3 January 2013. Content is available under Datsun 1200 Club.
