Floor Trim Part Numbers
From Datsun 1200 Club
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Carpet & Floor Mat
Console
Kicking Plate
Insulation
Mat, jute, kicking plate, interior sill trim, wheelhouse trim, seat riser trim
Car
FLOOR TRIMMING (SEDAN)
Catalog C-173
page 85-2 1971.11
15 74902-H1001 MAT-floor, front (R.H.) S-Std. (exc. 4 speed)
   74902-H1011 MAT-floor, front (R.H.) S-Std. (exc. 3 speed)
pages 85-3 to 85-4 1971.4
16 74903-H1001 MAT-floor, front (L.H.) S-Std.
17 74904-H1001 MAT-floor, tunnel S-Std. (exc. 4 speed)
   74904-H1011 MAT-floor, tunnel S-Std. (exc. 3 speed)
   74904-H1101 CARPET-floor, tunnel (黒 black) S-Dx. (exc. 4 speed)
   74904-H1102 CARPET-floor, tunnel (黄 yellow) S-Dx. (exc. 4 speed)
   74904-H1111 CARPET-floor, tunnel (黒 black) S-Dx. (exc. 3 speed)
   74904-H1113 CARPET-floor, tunnel (黄 yellow) S-Dx. (exc. 3 speed)
   74904-H2011 CARPET-floor, tunnel 2GT, 4GT
   74904-H2012 CARPET-floor, tunnel 4GX
   74904-H1121 CARPET-floor, tunnel (黒 black) 2DA, 4DA
   74904-H1121 CARPET-floor, tunnel (黄 yellow) 2DA, 4DA
   74904-H2021 CARPET-floor, tunnel 2GA, 4GA
18 74907-H1001 MAT-floor, rear S-Std.
H10     designed for 1200 STD
H11     designed for 1200 sedan DX
H20     designed for 1200 GL
FLOOR TRIMMING (COUPE)
1971.11 page 125-2
1971.4 pages 125-3 to 125-4
Truck
Floor Trimming
Carpet
Side Trim & Kicking Plate
Console Box
Sedan
1 74902-H1605 MAT-FLOOR FRONT RH SEDAN
2 74902-H2031 CARPET-FLOOR FRONT RH OP SEDAN
3 74903-H1605 MAT-FLOOR FRONT LH SEDAN MANUAL
3 74903-H1725 MAT-FLOOR FRONT LH SEDAN AUTOMATIC
3 G4903-H1005 MAT-FLOOR FRONT LH SEDAN MANUAL
4 74903-H2031 CARPET-FLOOR FRONT LH OP SEDAN MANUAL
4 74903-H2025 CARPET-FLOOR FRONT LH OP SEDAN AUTOMATIC
5 74904-H2031 CARPET-FLOOR TUNNEL SEDAN MANUAL
6 74904-H2025 CARPET-FLOOR FRONT SEDAN AUTOMATIC
7 74907-H1105 MAT-FLOOR REAR SEDAN
8 74907-H2011 CARPET-FLOOR REAR OP SEDAN
9 61140-0502P HOOK 1 (12) SEDAN
10 08530-52512 SCREW-TAPPING 1 (12) SEDAN
11 74943-H1111 JUTE-TUNNEL FRONT SEDAN 4 SPEED
11 74943-H1121 JUTE-TUNNEL FRONT SEDAN AUTOMATIC
12 74941-H2011 JUTE-FRONT FLOOR (2) SEDAN
13 74921-H1100 COVER-FLOOR SIDE FRONT RH SEDAN
13 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 SEDAN 0772-
13 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 SEDAN 0173-
13 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 SEDAN 0173-
14 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 SEDAN 0173-
14 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 SEDAN 0173-
14 74922-H1100 COVER-FLOOR SIDE FRONT LH SEDAN
14 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211 SEDAN 0772-
15 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 SEDAN 0772-
15 74925-H7001 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 SEDAN 0173-
15 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 SEDAN 0173-
15 74925-H1300 COVER-FLOOR SIDE REAR RH SEDAN
16 74926-H1300 COVER-FLOOR SIDE REAR LH SEDAN
16 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 SEDAN 0772-
16 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 SEDAN 0173-
16 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 SEDAN 0173-
17 74914-H7000 COVER-REAR SEAT LOWER RH (BLUE,LB-211 SEDAN 0772-
17 74914-H7005 COVER-REAR SEAT LOWER LH (BLACK,LG-13 SEDAN 0173-
17 74914-H7003 COVER-REAR SEAT LOWER LH (BEIGE,LH-20 SEDAN 0173-
17 74914-H7001 COVER-REAR SEAT LOWER LH SEDAN 0772-
17 74914-H7002 COVER-REAR SEAT LOWER RH (BEIGE,LH-20 SEDAN 0173-
17 74914-H1101 COVER-REAR SEAT LOWER H SEDAN
17 74914-H7004 COVER-REAR SEAT LOWER RH (BLACK,LG-13 SEDAN 0173-
18 74915-H1000 COVER-REAR WHEEL HOUSE BLACK#1742 (2) SEDAN
18 74915-H1001 COVER-REAR WHEEL HOUSE YELLOW (2) SEDAN(DX) 1270-
18 74915-H7000 COVER-REAR WHEEL HOUSE (BLUE,LB-211 (2) SEDAN 0772-
18 74915-H7001 COVER-REAR WHEEL HOUSE (BEIGE,LH-20 (2) SEDAN 0772-
18 74915-H7002 COVER-REAR WHEEL HOUSE (BLACK,LG-13 (2) SEDAN 0173-
19 74917-18200 PAD-REAR WHEEL HOUSE (2) SEDAN
20 74951-H3600 PLATE-KICKING FRONT RH SEDAN 2 DOOR 1271-
20 74951-H1200 PLATE-KICKING FRONT RH SEDAN 2 DOOR
21 74952-H1200 PLATE-KICKING FRONT LH SEDAN 2 DOOR
21 74952-H3600 PLATE-KICKING FRONT LH SEDAN 2 DOOR 1271-
22 08540-41242 SCREW-TAPPING M4 (8) SEDAN 2 DOOR
22 08540-14242 SCREW-TAPPING M4 1 (16) SEDAN 2 DOOR 1271-
23 74980-H1801 ASSY-BOX CONSOL SEDAN MANUAL
23 74980-H7000 ASSY-BOX CONSOL SEDAN (MANUAL) 0772-
23 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC
24 74980-H7001 ASSY-BOX,CONSOL SEDAN (MANUAL) 0772-
25 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC
25 74982-H1801 FINISHER-CONSOL BOX SEDAN MANUAL
26 74986-H1801 ASSY-BOOT SEDAN MANUAL
26 74986-H7000 ASSY-BOOT SEDAN (MANUAL) 0772-
27 74983-H1921 INDICATOR-COVER SEDAN AUTOMATIC
28 25172-H2520 ASSY-SOCKET SEDAN AUTOMATIC
29 74970-H1021 BULB SEDAN AUTOMATIC
30 74984-H1921 PLATE-POSITION SEDAN AUTOMATIC
31 74985-H1021 PLATE-SLIDE SEDAN AUTOMATIC
32 08510-61642 SCREW (8) SEDAN
33 08915-43642 WASHER-PLAIN (8) SEDAN
34 08310-41242 SCREW (2) SEDAN AUTOMATIC
35 08510-51242 SCREW (4) SEDAN AUTOMATIC
36 08915-43542 WASHER PLAIN (6) SEDAN AUTOMATIC
37 01241-00061 NUT-SPRING TYPE A (4) SEDAN
38 74990-H1800 MASK-CLOCK OP SEDAN(MANUAL)
39 08915-41212 SCREW (3) OP SEDAN(MANUAL)
40 08915-43410 WASHER-PLAINE (3) OP SEDAN(MANUAL)
Coupe
1 74902-H1605 MAT-FLOOR FRONT RH COUPE
2 74902-H2031 CARPET-FLOOR FRONT RH OP COUPE
3 74903-H1605 MAT-FLOOR FRONT LH COUPE
4 74903-H2031 CARPET-FLOOR FRONT LH OP COUPE
5 74904-H2025 CARPET-FLOOR TUNNEL COUPE AUTOMATIC
5 74904-H2031 CARPET-FLOOR TUNNEL COUPE 4 SPEED
6 74907-H1102 CARPET-FLOOR REAR COUPE 2 74907-H1101
6 74907-H1105 MAT-FLOOR REAR COUPE
6 74907-H1101 CARPET-FLOOR REAR COUPE
7 74907-H2011 CARPET-FLOOR REAR OP COUPE
8 08530-52512 SCREW-TAPPING 1 (12) COUPE
9 74943-H1111 JUTE-TUNNEL FRONT COUPE 4 SPEED
9 74943-H1121 JUTE-TUNNEL FRONT COUPE AUTOMATIC
10 74941-H2011 JUTE-FRONT FLOOR (2) COUPE
11 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 COUPE 0173-
11 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 COUPE 0173-
11 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 COUPE 0772-
11 74921-H1100 COVER-FLOOR SIDE FRONT RH COUPE
12 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211 COUPE 0772-
12 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 COUPE 0173-
12 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 COUPE 0173-
12 74922-H1100 COVER-FLOOR SIDE FRONT LH COUPE
13 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 COUPE 0173-
13 74925-H1800 COVER-FLOOR SIDE REAR RH COUPE
13 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 COUPE 0772-
13 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 COUPE 0173-
14 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 COUPE 0173-
14 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 COUPE 0173-
14 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 COUPE 0772-
14 74926-H1800 COVER-FLOOR SIDE REAR LH COUPE
15 74914-H1100 COVER-REAR SEAT LOWER RH COUPE
15 74914-H7000 COVER-REAR SEAT LOWER RH (BLUE,LB-211 COUPE 0772-
15 74914-H7002 COVER-REAR SEAT LOWER RH (BEIGE,LH-20 COUPE 0173-
15 74914-H7004 COVER-REAR SEAT LOWER RH (BLACK,LG-13 COUPE 0173-
16 74914-H7001 COVER-REAR SEAT LOWER LH (BLUE,LB-211 COUPE 0772-
16 74914-H7003 COVER-REAR SEAT LOWER LH (BEIGE,LH-20 COUPE 0173-
16 74914-H1101 COVER-REAR SEAT LOWER LH COUPE
16 74914-H7005 COVER-REAR SEAT LOWER LH (BLACK,LG-13 COUPE 0173-
17 74915-H1800 COVER-REAR WHEEL HOUSE RH COUPE
17 74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW COUPE 1270-
17 74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 COUPE 0772-
17 74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 COUPE 0772-
17 74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 COUPE 0173-
18 74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW COUPE 1270-
18 74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 COUPE 0173-
18 74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 COUPE 0772-
18 74916-H1800 COVER-REAR WHEEL HOUSE LH COUPE
18 74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) COUPE 0772-
19 74917-H1800 PAD-REAR WHEEL HOUSE (2) COUPE
19 74917-H7000 PAD-REAR WHEEL HOUSE (2) COUPE 0173-
20 74951-H1200 PLATE-KICKING FRONT RH COUPE
20 74951-H3600 PLATE-KICKING FRONT RH COUPE 1271- 0 74951-H1200
21 74952-H3600 PLATE-KICKING FRONT LH COUPE 1271- 0 74952-H1200
21 74952-H1200 PLATE-KICKING FRONT LH COUPE
22 08540-41242 SCREW-TAPPING M4 (8) COUPE
22 08540-41242 SCREW-TAPPING M4 1 (16) COUPE 1271-
23 74961-H1100 TRIM-SEAT RISER RH COUPE
24 74962-H1100 TRIM-SEAT RISER LH COUPE
24 74962-G1000 TRIM-SEAT RISER,LH COUPE 2 74962-H1100
25 74980-H1801 ASSY-BOX CONSOL COUPE MANUAL
25 74980-H7000 ASSY-BOX CONSOL COUPE MANUAL 0772- 0 74980-H1801
25 74980-H1921 ASSY-BOX CONSOL COUPE AUTOMATIC
26 74980-H7001 ASSY-BOX CONSOLE COUPE MANUAL 0772- 0 74980-H2010
26 74980-H2010 ASSY-BOX CONSOL COUPE MANUAL 0772-
27 74982-H1801 FINISHER-CONSOL BOX COUPE MANUAL
28 74986-H1801 ASSY-BOOT COUPE MANUAL
28 74986-H7000 ASSY-BOOT COUPE MANUAL 0772- 0 74986-H1801
29 08510-51242 SCREW (8) COUPE MANUAL
30 08915-43542 WASHER-PLAIN (8) COUPE MANUAL
31 01241-00061 NUT-SPRING (4) COUPE
32 74990-H1800 MASK-CLOCK COUPE MANUAL
33 08513-41212 SCREW (3) COUPE MANUAL
34 08915-43410 WASHER-PLAIN (3) COUPE MANUAL
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Floor_Trim_Part_Numbers"
This page has been accessed 7,971 times. This page was last modified 09:30, 25 November 2021. Content is available under Datsun 1200 Club.
