Heater Part Numbers
From Datsun 1200 Club
Categories: Body Electrical System | Heating And Ventilation Systems | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
Heater
Ventilation
Knobs
NOTE: Individual parts that make up the heater assembly are not listed.
ROOM HEATER
27010-H1000 HEATER KIT-room DX,GL,GX
27010-G1000 HEATER KIT-room Truck DX, (op.) TRUCK STD <> 27010-G1001
27010-G1001 HEATER KIT-room Truck DX, (op.) TRUCK STD
27010-G1002 HEATER KIT-room Truck DX, (op.) TRUCK STD (from '72-10) > 27010-G1001
Late Sunny Truck
1975-1994
HEATING UNIT ASSY-FRONT
      27011-G1001 7510-7803 NICHIRA <0,0> 27011-G1060
      27011-G1060 7804-8910 NICHIRA
      27100-95W00 8910-
27015 CASE ASSY-FRONT HEATER
      27016-G1000 7510-7803 BLACK NICHIRA
      27016-G1060 7804-8910 BROWN NICHIRA
      27124-95W00 8910-
27025 27022-H1000 HOSE-WATER
27070 27014-G1000 MOTOR & FAN ASSY-BLOWER NICHIRA
27077 27015-H3100 RESISTANCE-ELECTRIC NICHIRA
27115 27013-H1001 CORE ASSY-FRONT HEATER NICHIRA
27117 27017-B8520 COCK ASSY-FRONT HEATER
74148M 27017-G1000 KNOB-CONTROL NICHIRA B421
27610 27610-H7900 COOLING UNIT ASSY 7804- DKKC B421
27616 BRACKET-COOLING UNIT, NO 2
      27616-G1660 7804-8109 DKKC
      27616-G1900 8110- DKKC
27618 BRACKET-COOLING UNIT, NO 4
      27618-G1660 7804-8109 DKKC
      27618-G1900 8110- DKKC
Standard Type
1 27010-H1600 KIT-ROOM HEATER OP
27013-H1001 ASSY-CORE HEATER OP 27013-H1000
2 27013-H1000 ASSY-CORE HEATER OP
3 27014-H1000 ASSY-MOTOR HEATER OP
4 27015-H3100 ASSY-RESISTANCE WITH FUSE OP 0272-
5 27135-H1600 COMP-CONTROL HEATER OP
6 27137-H1000 KNOB-HEATER CONTROL'A' OP
7 27138-H1000 KNOB-HEATER CONTROL'B' OP
8 08310-30612 SCREW 2 OP
9 08915-13310 WASHER 2 OP
10 27139-H1600 ASSY-CABLE HEATER CONTROL'A' OP
11 27140-H1600 ASSY-CABLE HEATER CONTROL'B' OP
12 27141-H1600 ROD-HEATER CONTROL OP
13 27142-H1000 PIN-CONTROL ROD OP
14 27143-H1000 WASHER CONTROL ROD OP
15 08915-13510 WASHER 2 OP
16 08410-51212 SCREW 2 OP
17 08310-61014 SCREW 2 OP 0570-
18 27018-H1000 VALVE-ROOM HEATER 2 OP
19 27161-H1000 HOSE-DEFROSTER 2 OP -972 2
19 27161-H1001 HOSE-DEFROSTER 2 OP 1072- 2 27161-H1000
20 27171-H1000 NOZZLE-DEFROSTER 2 OP -972 2
20 27171-H1001 NOZZLE-DEFROSTER 2 OP 1072- 6 27171-H1000
21 08513-51212 SCREW 4 OP
22 08915-43510 WASHER 4 OP
23 08964-10510 NUT-SPRING 4 OP
24 27020-H1000 HOSE-WATER OP
24 27020-G1900 HOSE-WATER OP 27020-H1000
25 27021-H1000 HOSE-WATER OP
25 B7021-H1002 HOSE-WATER OP 27021-H1000
26 08723-12000 CLAMP-HOSE 5 OP
27 27051-E0100 CLIP-WATER OP
28 08723-13600 CLAMP-HOSE 2 OP
29 27070-H1000 CONNECTOR-WATER INLET OP
30 27075-H1000 CONNECTOR-WATER OUTLET OP
31 27078-B2000 CLIP 2 DELUXE(OP STD) 0570-
32 08510-51012 SCREW-TAPPING 2 DELUXE(OP STD) 0570-
33 08915-43510 WASHER-PLAIN 2 DELUXE(OP STD) 0570-
34 27363-18001 GROMMET-HEATER 2 OP 2 27363-18200
34 27363-18200 GROMMET-HEATER 2 OP
35 08915-53610 WASHER-PLAIN 4 OP
36 08915-13610 WASHER-SPRING 4 OP
37 08460-61612 SCREW 4 OP
38 27012-H1000 PLATE-AIR INTAKE FOR HEATER LESS OP
39 08915-53610 WASHER-PLAIN PLATE FIX 4 STD
40 08915-13610 WASHER-SPRING 4
41 X2160-30231 KNOB-VENTIRATOR OP
42 X2160-30213 ASSY-PANEL HEATER BOX OP
43 X2160-30600 ASSY-VALVE WATER CONTROL OP
43 X2161-30600 ASSY-VALVE WATER CONTROL OP 2 X2160-30600
43 B7017-B8500 ASSY-VALVE WATER CONTROL OP X2161-30600
44 X2160-30503 HOSE-HEATR OP
44 27022-H1000 HOSE-HEATR OP X2160-30503
Air Ventilator
1 66502-H1000 ASSY-PLATE, AIR VENTILATOR
2 66511-H1000 ASSY-LID, AIR VENTILATOR
3 66504-18001 SPRING-AIR VENTILATOR R.H.
4 66505-18001 SPRING-AIR VENTILATOR L.H.
5 66507-18000 PIN-AIR VENTILATOR
6 66520-H1000 ASSY-CONTROL, AIR VENTILATOR
7 27137-H1000 KNOB-HEATER CONTROL
8 84371-78200 HOLDER-ROD 2
9 08915-53610 WASHER-PLAIN 2
10 08915-13610 WASHER-LOCK 2
11 08460-61612 SCREW M6 2
12 08310-51214 SCREW M5 2
13 66522-H1600 ROD-CONTROL, VENTILATOR
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Heater_Part_Numbers"
This page has been accessed 10,395 times. This page was last modified 04:26, 4 September 2017. Content is available under Datsun 1200 Club.
