PB110 Badges
From Datsun 1200 Club
Category: PB110
The PB110 "Sunny Excellent 1400" model line for the most part uses unique badging, with only few emblems shared with the Sunny 1200.
image search サニー エクセレント 1400 バッジ
The badges that appear to be the same as A12-powered B110 are:
2006.jpgAlbum 2006
Grille
Coupe and sedan use the same grille. All trims use the same ornament.
62312-H2725 'S' shield-shaped radiator grille ornament
174_5a6cfbbdbde7e.jpgPost 487422 174_5a6cfbcf074d6.jpgPost click for topic
1985.jpgAlbum 1985 26406.jpgAlbum 26406
Grille can be placed Upside Down
856.jpgAlbum 856
correct orientation (point of sheild pointing down)
174_61deac6142702.jpgPost 496434
174_5a6cfc4857fbc.jpgPost 487422 174_5a6cfc55dc596.jpgPost 487422 174_5a6cfc99c086d.jpgPost 487422 174_5a6cfca4209ba.jpgPost 487422
Steering wheel badges
PB110 Excellent 1400 uses the same center badge on its steering wheels as the regular B110 1200.
GL, Deluxe, GX
27802.jpgAlbum 27802
'Sunny' Quarter Badge
Both sedan & coupe used the Sunny badge -- one on right side, and one on left side.
NOTE:The PB110 emblem is in a different font than the B110 version.
76854-H2800 EMBLEM - body side 'Sunny' (coupe, sedan)
25642.jpgAlbum 25642
76854-H2800 EMBLEM - body side 'Sunny' (coupe,sedan)
174_5d5270b6d938a.jpgPost 492238 174_5d5270d5091db.jpgPost 492238
Compare to the B110 sedan badge font 76854-H1000
174_5d5270a05de0e.jpgPost 492238
The fastening pins look to be in the same places horizontally but the vertical alignment may differ?
27807.jpgAlbum 27807
PB110
174_5d5270eb6156d.jpgPost 492238 174_5d5270f63bc92.jpgPost 492238
about 16cm long
174_5d52712f73d2d.jpgPost 492238
Coupe
6381.jpgAlbum click to view
Quarter
Coupe side (rear of quarter panel): 'Sunny' then 'Excellent' followed by: 'GL','GX' or 'Deluxe'
EMBLEM - body side
#76854-H2800 'Sunny' (coupe,sedan)
76854-H2500 'Excellent' RH
76855-H2500 'Excellent' LH
MARK
76862-H2500 'Deluxe' mark
76862-H2600 'GL' mark
76862-H2700 'GX' mark
Sunny
#76854-H2800 'Sunny' (coupe,sedan) [~160mm long x ~65mm high]
Excellent
76854-H2500 'Excellent' RH [~199mm long]
Similar:
* THIS PB110 coupe side 'Excellent' 'E' open  loop
  no background, italics script
* PB210 coupe side 'Excellent' 'E' closed loop
  solid background, compressed script
  27815.jpgAlbum 27815
27805.jpgAlbum 27805 27806.jpgAlbum 27806
24168.jpgAlbum 24168 29587.jpgAlbum 29587 29588.jpgAlbum 29588
Deluxe
76862-H2500 '1400 Deluxe' mark
27811.jpgAlbum 27811
GL
GX
76862-H2700 'GX' mark ~90 mm long, infill color is the typical 'GX red' although it fades over the years
PB221857.jpg 27804.jpgAlbum 27804 27808.jpgAlbum 27808 27809.jpgAlbum 27809
Rear Panel Excellent
25855.jpgAlbum 25855
Center Rear: 'Excellent' on black-out panel between taillights
756.jpgAlbum 756 2128.jpgAlbum 2128
EMBLEM - rear finisher
79820-H2525 'EXCELLENT'
25856.jpgAlbum 25856
25857.jpgAlbum 25857
Trunk lid fitting
MARK
#84822-H2501 '1400 DELUXE'
#84822-H2601 '1400 GL'
#84822-H2701 '1400 GX'
#79200-H2520 'NISSAN FULL AUTO MATIC'
1400 DELUXE
84822-H2501 MARK '1400DELUXE'
1400 GL
84822-H2601 MARK '1400GL'
11546.jpgAlbum 11546 v123009229600x450-2006122800115.jpg v123009229600x450-2006122800114.jpg
25558.jpgAlbum 25558 25559.jpgAlbum 25559
25560.jpgAlbum 25560
1400 GX
84822-H2701 MARK '1400GX'
* ~180mm long
27803.jpgAlbum 27803 29695.jpgAlbum 29695
Automatic Badge (COUPE)
79200-H2520 MARK "NISSAN FULL AUTOMATIC"
* similar, but not same as B110
* not same as Sedan
Coupe placement of automatic badge
photo needed
Sedan
#C-pillar
#Quarter rear side
#Trunk Lid rear
Excellent Sedan badges
25663.jpgAlbum 25663 174_5d52772c5c883.jpgPost 492239
Sedan GL set with R and L c-pillar badges
C-pillar
#76852-H2800 'Excellent DELUXE'
#76852-H2900 'Excellent GL'
#76852-H3000 'Excellent GX'
76852-H2800 Deluxe
'Excellent Deluxe'
25572.jpgAlbum 25572 25573.jpgAlbum 25573 25574.jpgAlbum 25574 12109.jpgAlbum 12109
76852-H2900 GL
'Excellent GL'
76852-H3000 GX
'Excellent GX'
25523.jpgAlbum 25523 25525.jpgAlbum 25525 25524.jpgAlbum 25524
about 110mm long
174_5d5277ee99da1.jpgPost 492239 174_5d5277fa3a7f1.jpgPost 492239
Quarter
76854-H2800 Sunny
Trunk Lid
(right) trim label
174_5d52f541277ce.pngPost 492243
(left) '1400' + #Automatic
174_65ad91efcfccd.jpgPost 498203
MARK
#84824-H2800 '1400'
#79200-H2820 'NISSAN FULL AUTO MATIC'
EMBLEM for Trim Level (Deluxe, GL or GX)
#84822-H2800 'EXCELLENT DELUXE'
#84822-H2900 'EXCELLENT GL'
#84822-H3000 'EXCELLENT GX'
Search: search
757.jpgAlbum 757
79200-H2820 Automatic Badge (SEDAN)
79200-H2820 'Nissan Full Auto Matic' badge
* same as late B110 Coupe
* differs to #PB110 Coupe badge
26203.jpgAlbum 26203
Automatic badge (sedan placement on left side of trunk lid)
84824-H2800 1400
84824-H2800 '1400' MARK PB110 SEDAN ~85mm long (placement: left side trunk lid)
27801.jpgAlbum 27801
29580.jpgAlbum 29580
84822-H2800 EXCELLENT DELUXE
12108.jpgAlbum 12108
84822-H2900 EXCELLENT GL
29581.jpgAlbum 29581
Trunk right-side GL
29582.jpgAlbum 29582 29583.jpgAlbum 29583
174_5d52f5345cd03.jpgPost 492243
84822-H3000 EXCELLENT GX
29584.jpgAlbum 29584 29585.jpgAlbum 29585
11131.jpgAlbum 11131
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=PB110_Badges"
This page has been accessed 21,440 times. This page was last modified 04:53, 1 September 2025. Content is available under Datsun 1200 Club.
