Seat Rails
From Datsun 1200 Club
Category: Interior
Seat runners are of two kinds: 1) Full adjustable fore-aft sliding 2) Non-sliding (truck passenger side).
Unbolt the rails from your seats and bolt them to the new seat.
H16 (sliding type) left seat
5185.jpgAlbum 5185
H10 fixed
* All 4-doors
* Truck
H16 Sliding
* JDM Coupe
* all USA (sedan & coupe)
Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
* Side to side: 15-11/16 inch
* Front to back: 12-3/16 inch
Left seat slide
8461_4e3529b0c0718.jpgUpload click to view 8461_4e352945506b6.jpgUpload click to view 035.jpg 036.jpg
USA seat with Seat Belt Warning System switch
14991.jpgAlbum 14991 14976.jpgAlbum 14976
All 1200 rails interchange:
  • B110 (sedan/coupe/wagon) and B120 (Truck) rails interchange
  • Sliding and fixed types interchange (with loss of functionality)
B210 seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat.
* early B210 seats fit B110 directly
* late B210 seats have a non-flat bottom
If you don't have the B110/B210 rails, you can adapt B310 slides:
5086.jpgAlbum 5086
Modifying B310 brackets to fit B110 chassis
ModifiedB110 rails may fit B10 (one-piece slide cut into two)
21712.jpgAlbum 21712
Location
The seat rails bolt to the floor risers.
Front Riser "A", Rear risers "B" and "C"
23056.jpgAlbum 23056
Front Riser "A"
Lowering
Seat Rail
22677.jpgAlbum 22677 22678.jpgAlbum 22678 22679.jpgAlbum 22679 22680.jpgAlbum 22680
Converter Seats
1200s from Oct 1989 have a Catalytic Convertor. So do B210 1976-up (JDM and USA).
Passenger side rail is shaped differently to clear the Catalytic Convertor bulge in the floor
19043.jpgAlbum 19043
Truck
Truck driver's seat has an adjustable slide. The passenger seat is a fixed (non-adjustable) "seat riser" bracket.
87500-G1000 SLIDE ASS'Y-driver seat ドライバ- シート スライド -1974
87501-G1000 SLIDE-RH SEAT, OUTSIDE スライド、RH シート アウトサイド
87502-G1000 SLIDE-RH SEAT, INSIDE スライド、RH シート インサイド
87556
87505-G1000 BRACKET ASSY-FRONT SEAT, LH ブラクット アッセンブリ、フロント シートLH
 RISER ASS'Y-seat シート ライザー
 [non-adjustable]
08110-81862 BOLT fixing slide to floor (8)
08915-43810 WASHER fixing slide to floor (8)
08310-82014 SCREW fixing slide to seat (8)
 08310-81812 -7510
08915-13810 WASHER fixing slide to seat (8)
Bride
The famous Bride rails for Sunny Truck
200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
  • Side to side: 15-11/16 inch
  • Front to back (left side): 12-3/16 inch
  • Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
    • slanted tabs
      15-1/2" at base, 16-1/4" at bottom edges
      front tab: 1-7/16" long
      rear tab: 1-3/8" long
Bride B122 Part Numbers
  • LH: code N030VO type V*1 TTM-L No. 939063
  • RH: code N029VO type V*1 TTM-L No. 939064
  • V type: for Bride full bucket, 30 mm height
  • S type: for Bride reclining seat
  • VF type: for Bride full bucket, no slide (fixed position)
174_677e68e29aba8.jpgPost 498704 174_677e68ebba5c3.jpgPost 498704 174_677e68f5820fe.jpgPost 498704
Photo Gallery
Click any thumbnail to see it full size (external web site)
008.jpg 009.jpg 010.jpg 011.jpg 012.jpg 013.jpg 014.jpg 015.jpg 016.jpg 017.jpg 018.jpg 019.jpg 020.jpg 021.jpg 022.jpg 023.jpg 024.jpg 025.jpg 026.jpg 027.jpg 028.jpg 029.jpg 030.jpg 031.jpg 032.jpg 033.jpg 037.jpg 038.jpg 039.jpg
シート スリイド シート リイザー ブラケット
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Seat_Rails"
This page has been accessed 10,935 times. This page was last modified 12:05, 8 January 2025. Content is available under Datsun 1200 Club.
