Cowl
From Datsun 1200 Club
Category: Body
<-- back to Body
The cowl is the part of a car body between the engine compartment and the dash face. The cowl includes the firewall, cowl top panel, and upper & lower dash panels -- but not the dash itself. For the Datsun 1200, the cowl is where fresh air for ventilation is drawn.
Also See
* Bonnet (hood) for engine covering
* Cowl Top Grille
* Ventilation
* Tunnel which is built of Lower Dash + Front Floor
Firewall & Dash
The steering post bracket bolts to the firewall.
These parts make up the Cowl:
23934.jpgAlbum 23934
  • Cowl Top
  • Dash-Upper
  • Dash-Lower
  • Dash-Side
19384.jpgAlbum 19384
The dash-side has openings for the optional speaker and the upper and lower door hinges
28828.jpgAlbum 28828 28838.jpgAlbum 28838
10146_4bfa3c29a9c04.jpgPost 318721
View from engine compartment:
1759.jpgAlbum 1759
View from inside cabin:
11732.jpgAlbum 11732
The water box is also known as the ventilation plenum -- it is where air enters the cabin. The large oval hole in the center is for the heater (or ventilator). The cowl vents are located at the base of the windshield due to aerodynamic reasons.
Cabin air Inlet
174_5bf7ce2b1d58c.jpgPost 489971
Normally, rainwater goes in through the top through the Cowl vents and falls onto the topside of the Upper Dash panel. From there it runs out a vent hole on the outside of the panel near the guards (fenders).
174_5bf7ce83697dd.jpgPost 489971 174_5bf7cef472726.jpgPost 489971 174_5bf7d05063b25.jpgPost 489971
Lower Dash panel:
4663.jpgAlbum 4663 4661.jpgAlbum 4661
In this photo, the Reinforcement has been removed, and you can see how the hoodledge joins with the firewall and radiator panel to form the engine compartment:
4665.jpgAlbum 4665
How the hoodledge (inner fender) ties in to the A-pillar:
23935.jpgAlbum 23935
The dash unit mounts via three brackets welded to the firewall
5044.jpgAlbum 5044
Insulation
174_5ac2dab230d16.jpgPost 487976
  • Low-density Fibreboard (LDF) insulation is used on the inside of the firewall.
  • Medium-density fibreboard is used on the Kick Panel
RHD 4-DR SEDAN, WAGON, EARLY UTE
67900-H1000 ASSY-DASH INSULATOR LH
67901-H1000 ASSY-DASH INSULATOR RH
LHD 2-DR SEDAN, COUPE
67900-H1600 ASSY-DASH INSULATOR RH
67901-H1600 ASSY-DASH INSULATOR LH
Cowl Baffle
The baffles bolt to the cowl top along with the cowl top grilles, and serve to keep water out of the ventilator/heater system.
20367.jpgAlbum 20367
7 66810-H1001 PLATE - BAFFLE COWL TOP - RH 109.38
8 66811-H1001 PLATE - BAFFLE COWL TOP - LH 172.15
R and L baffles
31426.jpgAlbum 31426
Repairing Water Box
Water comes in though the vents behind the bonnet, then runs down to a hole that is there to let it out. If this is rusted, it will instead leak down onto the fenders.
* 66301-H1000 PANEL-cowl top JAPAN
* 66301-H1600 PANEL-COWL TOP USA
* 66810-H1001 PLATE-BAFFLE COWL TOP RH
* 66811-H1001 PLATE-BAFFLE COWL TOP LH
* 24426-H1001 ASS'Y-BRACKET, battery
* 24427-H1001 STAY-BATTERY BRACKET
  * 24427-H1000 STAY-BATTERY BRACKET
  * 77720-89910 BOLT-SPECIAL
RHD
67300-H1000 ASS'Y-PANEL, dash, lower
67300-H1021 ASS'Y-PANEL, dash, lower Automatic
* 74306-H1020 ASS'Y-PANEL, A/T floor cover, front
46570-H1001 ASS'Y-BRACKET, pedal & steering post
* 81-10620-62 BOLT-with lock washer (fixing reinforcing & stay) (8)
46575-H1001 BRACKET-clutch cable
46582-H1000 PACKING-clutch cable bracket
* 83-10614-62 SCREW (3)
* 89-15436-1 WASHER-plain (3)
LHD
67300-H1600 ASSY-PANEL DASH LOWER
67300-H1601 ASSY-PANEL DASH LOWER
67300-H1922 ASSY-PANEL DASH LOWER
67300-H1921 ASSY-PANEL DASH LOWER
46570-H1600 ASSY-BRACKET PEDAL & STEERING POS
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Cowl"
This page has been accessed 16,661 times. This page was last modified 07:46, 1 December 2025. Content is available under Datsun 1200 Club.
