<-- Back to EGI
Contents[hide] |
[edit]
A14E & A15E engines used EGI.
On the bottom of the intake manifold is the water hose. It connects to the front block water tube.
Water hose is "E" in this photo
14052-H9200 HOSE-WATER * 08723-12000 CLAMP (2)
[edit]
High RPM Usage
Modified for 8500 RPM use including larger throttle body
[edit]
Port Size
Port size * 28x32 mm (medium oval) with injection cutout of extending up to 40mm * compare to standard A14: 28x34* Port sizes on the same manifold vary a bit
14003-H9200 MANIFOLD-INTAKE A14E 14003-H9254 MANIFOLD-INTAKE A15E * 08223-84510 STUD $1.15 USD * 08223-84010 STUD $0.78 USD
Be sure to port match, as ports can vary.
Black shows the gasket opening (port matching)
[edit]
Support Bracket
Just like the B310 A14 & A15 carburetor manifolds, the EFI manifold needs a support brace.
14018-H9200 MANIFOLD SUPPORT fasteners to manifold * 14018E (2) 11053-H9200 MANIFOLD BRACKET WASHER * 08120-81610 BOLT M8x16 fasteners to engine mount stud * 08915-53810 PLAIN LARGE WASHER M8 * 08915-23810 THICK SPRING LOCK WASHER M8 * 08911-10810 M8 NUT
