Diff Gasket
(Redirected from 38320)
For comparison: Gear carrier (main axle housing) gasket.
Live Axle
38320 GASKET-GEAR CARRIER
th_H145_differential_cover_gasket.jpg 23236.jpg th_H190_differential_cover_gasket.jpg th_M78_differential_cover_gasket.jpg
LIVE AXLE
H145 38320-18010 GASKET-GEAR CARRIER $1.70 USD
H150 38320-H5000 GASKET-gear carrier
         38320-H5001 Gasket-carrier $4.43 USD
H165 38320-04110 GASKET-GEAR CARRIER H165
         38320-N5000AS Gasket-carrier $4.27 USD
         38320-N5000
         38320-N5001
H190 38320-B3002 Gasket-cover $4.13 USD
         38320-B3000 GASKET-GEAR CARRIER
         38320-25670 GASKET-GEAR CARRIER (10)
         38320-25660 GASKET-GEAR CARRIER (10)
LIVE AXLE - SALISBURY TYPE
CA200 38353-Y0801
      38353-Y0800
      38353-Y0812 ?
8-bolt circle
H145
H150
8-bolt circle/straight sides
CA200
IRS
NOTE: Gaskets for IRS diff are used by some RWD diffs, so there are two parts catalog codes:
38320 GASKET-GEAR CARRIER (rear final drive)
38520 GASKET-GEAR CARRIER (front final drive)
28879.jpgAlbum 28879 28880.jpgAlbum 28880 28881.jpgAlbum 28881 28882.jpgAlbum 28882
NOTE: all have shape of a Squared-Off Circle
R200 8-BOLT Width: wide
R180 8-BOLT Width: medium
R160 8-BOLT Width: narrow
R145 11-BOLT split gasket
R145 Split Case
     Liquid Gasket (silicone) for split gasket surfaces
     999MP-A7007P K11 [w/fluid coupling]
     C8320-00330 $22 Silicon Gasket
     28883.pngAlbum 28883
R160 38353-21000 (R160 from 510)
     38320-N1901
R180 38353-U3000 R180 $5 USD
     38320-U3011
     38353-78500
     * USA.S130+910+M10+M11
     * JDM.M10+M11+B12+U12+910+U12+P10+C31+F30+C31+N13+R30+S12
     38320-01G02 Gasket Gear Carrier $28 USD
     38320-01G03
     38320-01G00
     * reportedly interchanges with R180 gasket
     * JDM.N14,N15,B13,B14,B15,C22,C23,D21,D22,F23,E24,M12,VE24,WE24
       G10,JU30,U30,N30,RB14, R20,R30,R33,S14,W11,W30,A31,C33,C34,
       R20,U13,WD21
     * USA D21,D22 (front diff, four-cylinder models)
R200 38353-N3100 R200 $5 USD
     38320-N3111
     * USD.S12+S130+Z31
38354-41W00 720 front (R200?)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Diff_Gasket"
This page has been accessed 12,174 times. This page was last modified 00:01, 15 November 2023. Content is available under Datsun 1200 Club.
