Kangaroo Bag
(Redirected from Washer)
Categories: Body Electrical System | Maintenance And Daily Care
<-- back to Wipers
Fill the windshield washer bag with wiper fluid. In summer, plain water may be used, but in winter only wiper fluid with anti-freeze properties should be used to prevent freezing damage to the pump.
Daily Care
CAUTION
Always use clear washer solvent with pure water.
Do not use soap water.
31396.jpgAlbum 31396
  • Windshield washer fluid level
  • Remove cap and top up the Kangaroo Bag.
  • Turn key to ON, twist wiper switch to verify correct washer action.
Bag and bracket are same as later Datsun 1000
1712.jpgAlbum 1712 31397.jpgAlbum 31397 31398.jpgAlbum 31398
Testing
To test the washer motor:
  1. Put some water in the bag
  2. Connect Blue/Red wire to 12V +
  3. Connect Black/blue wire to ground/earth
The washer pump should make noise and squirt water
19375.jpgAlbum 19375 17656.jpgAlbum 17656
If the pumps makes noise, but no water squirts, the nozzie atop the back of the bonnet may be clogged. Take a sewing pin and insert in the two little holes.
Nozzle
The windshield washer spray nozzle is mounted on the hood.
28930-G1900 buy at Bprojects
31395.jpgAlbum 31395 26404.jpgAlbum 26404
ウォッシャー ノズル
Nozzle Repair
If the nozzle break off where the hose attaches, use a rubber fitting to repair it. I used a 70s-80s GM vacuum fitting that has a small hole in one side and a large hole in the other side. Jam the small hole onto the Nozzle and fit the hose into the larger hole.
Or buy a new nozzle at about $15 USD.
19503.jpgAlbum 19503
27480-H1001 ASSY-BAG WINDSHIELD WASHER $138.33 USD
* replaces 27480-89901 ASSY-BAG WINDSHIELD WASHER
6 27446-89901 BRACKET-BAG
7 08513-61212 SCREW BACK FIX 2
8 08915-43610 WASHER BACK FIX 2
27440-H1001 NOZZLE ASSY-WASHER B110
* 28930-G1900 NOZZLE ASSY-WASHER B120
COMPARISON
27480-89900 521 0568- [same as B110]
27415-89900 520 -0468 [uses external pump]
510 [uses plastic tank]
PL620 [uses plastic tank]
Kangaroo Bag Clone
Bag with internal 12V pump. As low as $30 USD.
  • 33199
  • DGEWP16
  • GT SP-401104
  • YH-XDU
  • Ferrari 308: part number 3567W
  • Honda Civic IAT (Bag Type)
  • FIAT (Bag Type)
  • Zhenqi ZQ-XDu
Denso
Denso デンソー formerly NipponDenso (ND) washer bag, Denso Corporation. DENSO is a member of the Toyoda Group of companies.
  • 060800-1330 WASHER ASSY
  • 160200-1570 WASHER ASSY
VENDOR: Bprojects Product: DENSO Windshield Washer Bag Kit
21085.jpgAlbum 21085
ND bag
6595_4b63ef15e727d.jpgUpload click to view
Mitsuba
ミツバ Mitsuba has a strong historical relationship with Honda.
Mitsuba EW-4B (also see MITSUBA EWP16, EW-3B, 38510-810)
21328.jpgAlbum 21328
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Kangaroo_Bag"
This page has been accessed 33,554 times. This page was last modified 05:16, 30 November 2025. Content is available under Datsun 1200 Club.
