120Y Front Suspension
(Redirected from 120Y Suspension)
Categories: Datsun B210 | Front Axle And Front Suspension
120Y was the marketing name for A12-powered B210 in many countries. The suspension differs generally from A14-powered B210. Early 120Y used different components than Late 120Y, except for the strut tops and strut bearing.
Early 120Y used the exact same front strut assembly as the B110 -- except for the strut top. Various spring rates were used.
Early: from 1973 introduction to November 1975
Late: from December 1975 to end (B211)
Late VAN: from October 1975 (VB210)
Part number Applied Model Codes (original appplication)
180 - Datsun B10 (1000)
210 - Datsun 510 (1600)
H10 - Datsun B110 (1200)
H16 - Datsun B110 Coupe
H25 - Datsun B110 Coupe
H50 - Datsun B210
H62 - Datsun B210 1974
H74 - Datsun B210 A12 Late
H75 - Datsun B210 A14 GL,GX
H85 -
U01 - Datsun 610 1972
Japan Market
In Japan the A12-powered B210 was marketed as the Datsun Sunny 1200 B210.
VH=PT: Van High-engine (A14), Super-Deluxe
Early (Sedan/Coupe/Van) SAME AS B110
DRUM STD, DX
54302-H5025 STRUT KIT-front suspension (Atsugi) 2
DISC GL, GX
54302-H5125 STRUT KIT-front suspension (R.H.) (Atsugi)
54303-H5125 STRUT KIT-front suspension (L.H.) (Atsugi)
Late
DRUM A12S.(S+K).DX + V-VH=PT (Left & Right are identical)
 54302-H7425 ATSUGI 2
 or
 54302-H7426 TOKICO 2
DISC A12S.(S+K).GL + A14.(S+K) + VH=PT
 54302-H7427 RH ATSUGI
 54303-H7427 LH ATSUGI
Spring
Early
54010-H5000 SPRING-front suspension 2 ALL <> 54010-H5000
54010-H5001 SPRING-front suspension (R.H.) (from '74-1) ALL
54010-H5000 SPRING-front suspension (L.H.) (from '74-1) ALL
Late
* A12 same as A14
* Sedan/Coupe/Van all use the same
54010-H6200*SPRING-front suspension (R.H.) NHK
54010-H1601*SPRING-front suspension (L.H.) NHK
* H1601 same as USA B110 (disc brake) L=213
Shock Absorber
Early
56110-H1025 SHOCK ABSORBER KIT-front (厚木) 2 ALL
* superceded by 56105-H5025 STRUT CARTRIDGE
* Same as USA B110
Late
* A14, A12 use same kit
56110-H7425*SHOCK ABSORBER KIT-front (厚木) 2
56110-H7426*SHOCK ABSORBER KIT-front (トキコ) 2 <> 56110-H8525
56110-H8525 SHOCK ABSORBER KIT-front (トキコ) 2 7804-
KIT includes the following (Same as USA B110):
54308-H1025 PACKING KIT-gland (厚木) 2
54308-H1026*PACKING KIT-gland (トキコ) 2
54324-21000 NUT 2 [M12]
08915-44210 WASHER-plain 2 [M12]
54313-22129 OIL-suspension strut (360 cc) (厚木) 2 ALL
54313-28525 OIL-suspension strut (360 cc) (トキコ) (from '75-10) 2 VAN
Spindle Nut
Early
40262-18000 NUT-lock, front wheel bearing 2
08921-32510 PIN [cotter] 2
Late
40262-U0100*NUT-lock, front wheel bearing 2
00921-43000*PIN [cotter] 2
Strut Top
Strut Mounting Insulator differs from B110.
54320-H5000 INSULATOR-strut mounting 2 ALL
08915-14010 WASHER-lock, insulator to body 6 ALL
08911-64010 NUT, insulator to body 6 ALL
H10 parts are sourced from B110
54050-H1000 BUMPER-bound, front suspension 2 ALL
54040-H1000 SEAT-front suspension upper 2 ALL [spring seat]
54059-H1000 SEAL-dust, font suspension strut 2 ALL
54325-H1000 BEARING-strut mounting 2 ALL
54055-H1000 COVER-dust, front suspension strut 2 ALL
Hub
Hub for DISC type - GL,GX
Early
40202-H1005 HUB ASS'Y-road wheel 2
Late
40202-H7405 S,K.A12S.GL+S,K.A14+VH=PT 2
LCA
Late LCA uses H74 parts for both drum and disc types
Steering Linkage
Cross Rod (center link/drag link) is the same as B110, except the 120Y version has slightly different bends to it.
Side Rod assembly (components not sold separately by Nissan)
* Side Rod Bar. Presumably longer than B110, since B210 track is 35mm wider.
* Side Rods (tie-rod ends) [M12 castle nut???] [M14 threads???]
STEERING LINKAGE A12,A14 same.
48500-H5000 LINKAGE ASS'Y-steering
 48502-H5000 ARM-steering gear early
 48550-H1000 ARM-steering gear late
  Fixing Arm to Gearbox
  08911-25010 NUT
  08915-15010 WASHER-lock
 48510-H5025 ROD ASS'Y-side steering (R.H.)
 48610-H5025 ROD ASS'Y-side steering (L.H.)
  Fixing side rod ends
   01227-00011 NUT 4
   08921-32010 PIN-cotter 4
 48530-H5000 IDLE ASS'Y-steering
  48551-H1000 ARM-idler steering
  48544-H1000 BUSH-idler 2
  48541-H1000 WASHER-upper idler
  08912-44210 NUT
  Fixing Idler to chassis
   08124-27510 BOLT 2
   08912-64210 NUT 2
 48560-H5025 ROD ASS'Y-cross steering
  01227-00011 NUT 2
  08921-32010 PIN-cotter 2
Side Rod Ends
Side Bar threads: M14 x 1.50 Left-Hand Threads X Right-Hand Threads
LEFT OUTER  48640-W5025/48640-H5025/48640-H1001
LEFT INNER  48641-W5025/48641-H5025/48641-H1001
RIGHT OUTER 48520-W5025/48520-H5025/48520-H1001
RIGHT INNER 48521-W5025/48521-H5025/48521-H1001
OUTER
Cone Pitch   1/10
Length       79 mm
Cone Size    11.3 mm
Stud Thread  M12 x 1.5 or M10 x 1.25
Inner Thread M14 x 1.5
Overall Length [mm] 95
Overall Height [mm] 65
Thread Length [mm] 45
SIDE ROD END
OUTER Left: With left-hand thread
 * Nissan 48640-H5025
   * Nissan 48640-W5025
   * Nissan 48640-H1001
 * B210 Sunny 120Y
 * B310 Sunny 120Y/140Y/150Y
 * B120 Sunny Truck
 * S110 Silvia/Gazelle
 * A10 Violet 160J
 * M14 x 1.5
 MOOG NIES2440
 FIRST LINE FTR4037
 LEMFÖRDER 16337 01 - 183000013574
 MEYLE 36-16 020 0003
 OCAP 0293553
 KLARIUS/QUINTON HAZELL QR1367LHT $11 USD Rockauto.com
 * Cone Size: 11.5 mm
 * Inner Thread: M14 x 1.50
 * Cone size: 11.3 mm
 * Cone pitch: 1/10
 * Length: 79 mm
 SIDEM 41538
 SPIDAN 44298
 555 (TRIPLE FIVE) SE4141L
 TRW ES2440L
OUTER RIGHT: with right-hand thread
Nissan 48520-W5025
SIDEM 41539
SPIDAN 44296
QUINTON HAZELL QR1367RHT
MOOG NI-ES-2439
OCAP 0283553
TRISCAN 8500 136700H
555 SE4141R
INNER LEFT
Nissan 48641-W5025
SIDEM 41630
555 SE4142L
INNER RIGHT
Nissan 48521-W5025
SIDEM 41631
555 SE4142R
Steering Gearbox
48010-H5000 COLLAPSIBLE A12/A14 EARLY/LATE
48010-H5500 NON-COLLAPSIBLE WITH COLUMN EARLY VAN
48010-H5510 NON-COLLAPSIBLE WITH COLUMN EARLY VAN
Disc Rotor
Early
40206-H1006 GL,GX [212.5 mm]
Late
40206-H7500 S,K.A12S.GL+S,K.A14+VH=PT 2 [219 mm]
* 220 mm per Datsun factory service manual
Caliper
LOADED CALIPER
Early
41000-H1007 CALIPER ASS'Y-front brake (R.H.) GL,GX
41010-H1007 CALIPER ASS'Y-front brake (L.H.) GL,GX
Late
41000-H7501 BRAKE ASSY-FRONT S,K.A12S.GL+S,K.A14
41000-H7800 BRAKE ASSY-FRONT VH=PT
* only difference is the brake pad formula:
  41060-H7825 PAD KIT-DISC BRAKE VH=PT [AKEBONO S21B]
  41060-M3225 S,K.A12S.GL+S,K.A14 <> 41060-M3226 [TOKICO D64P]
Crossmember
54401-H5000 A12S,A14 early & late
Oil Pan
11110-H5000 A12S,A14 early & late
* USA used different, unique oil pan
USA Market
A12-powered B210 was not sold in USA or Canada. All were HB210 (A13/A14 engines) but were fitted with suspension from the Datsun 610, which was also used in Japan-market by the PB210 (L14-powered B210).
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=120Y_Front_Suspension"
This page has been accessed 2,335 times. This page was last modified 01:21, 12 April 2013. Content is available under Datsun 1200 Club.
