Alternator Wiring
From Datsun 1200 Club
Categories: Charging System | Wiring
Early 1200 use Alternator with external Voltage regulator. Later 1200s (from 1981) use an Internally Regulated (IR) Alternator.
Early 1200
Our Datsun B110 used -- as with most 1964-1974 cars -- an Alternator with external Voltage regulator.
Alternator Connections
terminalColorLogical Connections
A (Alternator)WR or W* To Battery + terminal through the Fusible Link
* To Regulator "A" terminal (W wire)
F (Field)WB* To Regulator "F" terminal
N (neutral point)Y* To Regulator "N" terminal
* To electric choke relay Y wire
E (Earth/ground)B* To body ground
* To Regulator "E" terminal
Regulator Connections
A (Alternator)W* To Alternator "A" terminal (WR or W)
F (Field)WB* To Alternator "F" terminal
N (nuetral point)Y* To Alternator "N" terminal
E (Earth)B* To body ground
* To Alternator "E" terminal
IG (ignition)WL (72: W?)* To fuse box "M" terminal (does not go through IGN switch)
L (Light)WR* To dash light "IGN" ('72, '73) or "CHG" (1971)
Hitachi LT-series uses the typical 1970s Hitachi T-shaped connector:
F Field - stem of Tee
N Nuetral point - head of Tee
Late-model Alternator
Datsun 1200 from 1981 (Japan-market models) use an internally-regulated Hitachi LR Alernator or equivalent.
Also see Hitachi LR Alternator Wiring
Using in Older 1200
The LR135 is a bolt-in replacement for the LT135 BUT you must modify the wiring slightly.
See main article: IR Alternator Conversion Wiring
B310 North America
Datsun 210 uses an internally-regulated Hitachi LR-150 alternator.
Black: earth/ground
White: battery via Fusible Link (large wire)
White/Red: dash CHG lamp
While: battery via Fusible Link (small wire)
How the Alternator Dash Light Works
The dash lamp is connected to IGN +. The other side goes to the "L" terminal of the external regulator.
  • When the alternator is not putting out current, the "L" terminal is at '-' voltage, so the dash light turns on
  • Once the alternator starts putting out current, the "L" terminal is at + voltage, so the light turns off (both sides of the light are at +)
This also is connected to the F (field) connection of the alternator, so it "turns on" the alternator. It is the switched 12V (through the lamp) that kick starts the alternator fields.
WARNING: This mean that if the dash lamp
is burned out, the alternator does not work
Automatic Choke Relay
On Datsuns equipped with an electric Automatic Choke, a relay is used so that the choke heater is activated only when the engine is running.
See main article: Electric Choke Wiring
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Alternator_Wiring"
This page has been accessed 5,522 times. This page was last modified 09:42, 20 November 2012. Content is available under Datsun 1200 Club.
