Fluids
(Redirected from Gas Station Information)
Categories: Daily Care | Clutch | Brake System | Cooling System
USA 1972 Owners manual (see page 43 for details):
Opening the hood (bonnet):
Page 21:
  • Brake Cylinders: Fill to top line (do not fill to the top of the reservior)
  • Clutch Master Cylinder: Fill to top line (do not fill to the top of the reservior)
  • Radiator: Fill to 1 inch (2.5 mm) below filler cap with Coolant
    • With heater: 5-3/16 US quarts (4-15/16 Imperial qts) or 4.9 liter
    • W/o heater: 4-7/16 US quarts (3-11/16 Imperial qts)
  • Windshield washer tank (windscreen washer)
Page 25:
  • Engine Oil: Recommend Oil Viscosity Number varies by ambient temperature range of your climate.
    • Oil pan capacity: 2-7/8 US qts (2-3/8 Imp. qts) or 2.7 liter
    • Oil filter: 1-1/8 US pints (1 Imp. pint) or 0.54 liter
    • See Oil Specifications for more details.
  • Battery: fill each cell to about 0.2 inch (5 mm) above the plates. Most batteries have a fill indicator. Do not overfill.
Page 24:
It is normal to add some engine oil between the 3,000 mile (5,000 km) oil changes.
  • Transmission Gear Oil: APL-GL4
  • Differential Gear Oil: APL-GL5
  • Automatic Transmission Fluid: Type DEXRON ATF
  • Multipurpose grease: For "lube and filter" job and other Lubrication uses
  • Brake Fluid: SAE J1703a (DOT 3, US FMVSS No. 116)
  • Clutch Fluid: same as brake fluid
  • Antifreeze for radiator: Ethylene Glycol base Coolant
Page 24:
During freezing weather...
  • Petrol: 9 Imperial gallons
  • Gasoline: 10 US gallons
  • 87 R+M/2, or 90 RON equivalent. See Fuel Requirements
Page 22:
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fluids"
This page has been accessed 3,667 times. This page was last modified 05:38, 7 January 2013. Content is available under Datsun 1200 Club.
