Search results
For query "/A-series_Cylinder_Heads"
There is no page titled ":/A-series_Cylinder_Heads". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 14 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. A12GX Engine (12809 bytes)
    40: {{SeeEx|see=Main|A-series_Cylinder_Heads#A12GX_Head|A12GX Head}}
    53: # [[A-series_Cylinder_Heads#Port_Sizes|Extra-large oval ports]] 30x35 mm (lar...
    57: # Heart shaped [[A-series_Cylinder_Heads#Combustion_Chamber|combustion chambers]] (Type B)
    61: # Valves: [[A-series_Cylinder_Heads#Valve_sizes|35mm inlet, 29mm exhaust]] (smaller t...
  2. EGI (26751 bytes)
    182: [[A-series_Cylinder_Heads#H92|H92]] cylinder head with standard A14-size va...
  3. Piston (17660 bytes)
    415: ..._Cylinder_Heads#H89|H89 cylinder head]] and the [[A-series_Cylinder_Heads#H95_Small-Oval_Shrouded-port_Head|H95]] head
  4. Cylinder Head Identification (18394 bytes)
    134: ...H23]] vs [[A-series_Cylinder_Heads#H89|H89]] vs [[A-series_Cylinder_Heads#A12_H10_Head|H10]]
    288: * 5-bolt update ([[A-series_Cylinder_Heads#H990|990]] shown)
    292: * 5-bolt with undrilled Air Pump air passage ([[A-series_Cylinder_Heads#H75|H75]] shown)
  5. A14T Part Numbers (5265 bytes)
    19: ...and exhaust valves. A14 standard valves (37/30) [[A-series_Cylinder_Heads#Valve_sizes|are larger than]] A12/A12GX valves (3...
  6. Cylinder Heads (7039 bytes)
    193: See [[A-series_Cylinder_Heads#Nissan_Competition_Catalog|Nissan Competition Hea...
  7. H89 (311 bytes)
    6: {{See|A-series_Cylinder_Heads#H89}}
  8. A15 Engine (3650 bytes)
    78: C120 JDM - [[A-series_Cylinder_Heads#H89|H89]] Type A15
  9. FU Engine (4944 bytes)
    48: ...rd A14 was 80 HP, but FU engine was 65 HP. Type [[A-series_Cylinder_Heads#728|728]] cylinder head had round ports, which co...
    78: [[A-series_Cylinder_Heads|Cylinder head]] features:
  10. 1984 Nissan Competition Catalog (13558 bytes)
    39: * [[A-series_Cylinder_Heads#Nissan_Competition_Catalog|Cylinder Heads & Compo...
  11. Cylinder Head Index (1710 bytes)
    4: [[A-series_Cylinder_Heads#A12GX_Head|GX]]
    7: [[A-series_Cylinder_Heads#A12_G25_Head|G25]]
    10: [[A-series_Cylinder_Heads#H85|H85]]
    13: [[A-series_Cylinder_Heads#H77|H77]]
    16: [[A-series_Cylinder_Heads#H89|H89]]
  12. Cylinder Head Part Numbers (24003 bytes)
    55: 180, H01, and [[A-series_Cylinder_Heads#A12_H10_Head|H10]] heads for B10 Sedan & Van
    73: [[A-series_Cylinder_Heads#A12_H10_Head|H10]] Head
    82: [[A-series_Cylinder_Heads#A12GX Head|H23]] Head for [[A12GX Engine]]
    83: * Appears identical to [[A-series_Cylinder_Heads#A12GX Head|Early A12T Head]]
    94: [[A-series_Cylinder_Heads#A12_H10_Head|H10]] Closed Chamber (same as JDM he...
  13. PB110 Engine (6323 bytes)
  14. Water Ports (2692 bytes)
    43: Nissan Competition head [[A-series_Cylinder_Heads#Competition_Head|99996-H1165]]
Search in namespaces :
List redirects   Search for
