Also see: * Applied Model Codes Overview * Early Applied Model Codes 001-999 * Applied Model Codes 2 A,B,G,N,R,T,U * Applied Model Codes 3 xxW codes (01W-99W) * Applied Model codes list for A-engined vehicles H,G,M,W - Sunny, Sunny Truck, Cherry/Pulsar, Violet * Nissan Part Number Overview * Nissan hardware part number (N.E.S.) for bolts, nuts, etc.
[edit]
A
A01 GC10T A02 PGC10T A06 510S ('69) A07 510P ('69) A08 510 ('69) A09 510-T ('69) A11 P510-TK ('69) A13 P510S ('69) A14 R510 ('69) A15 R510T ('69) A16 WP510 ('69) A17 WP510-A ('69) A18 V510S ('69) A19 V510 ('69) A20 510U ('69) A21 P510UT ('69) A22 PL5105 ('69) A23 PL510 ('69) A24 PL510T ('69) A25 PL510A ('69) A26 PL510UT ('69) A26 WPL510UT ('69) A27 PL510UA ('69) A29 WPL510 ('69) A30 WPL510UT ('69) A32 SR311 ('69) A33 SPL311U ('69) A34 P510P ('69) A35 P510 ('691 A36 P510-A ('69) A40 R510A ('69.5) A41 P510A ('69.5) A42 WP510A (69.5) A44 510 ('69.5) A45 SP311 (69,5) A46 P510 ('70) A47 R510 ('70) A48 P510P ('70) A49 P510S ('70) A50 P510A ('70) A51 P510TK ('70) A52 KP510TK A53 WP510 A55 PL510TU A56 PL510AU A57 WP510A A58 WPL510 A59 WPL510TU A60 PL510TK A61 PC10M A62 PC10MA A63 PC10MT A64 WP10M A65 VP10M A68 C10S A69 C10 A70 VC10 A72 PGC10T A74 SR311 A80 KPC10T A81 KPC1OAT A82 KGC1OT A83 KGC1OAT A84 GC10AT ('70) A86 N510S ['1400' Standard] A87 H510TK A88 N510P A88 N510Y A89 N510 A89 N510T A90 N510H A90 P510H A91 N510HT A91 P510HT A92 N510HA A92 N510RA A92 P510HAT A93 N510R A93 N510RS A93 N510RST A93 N510RT A94 KH510TK A95 VN510
[edit]
B
B01 521 ('68) B02 G521 ('68) B05 U521 ('68) B06 V521 ('68) B07 A320 ('69) B08 SA320 ('69) B10 KA320 ('69) B11 T641L-1 ('69) B11 T641H-1 ('69) B13 T641LC-1 ('69) B13 T641HC-1 ('69) B14 V641A-1 ('69) B14 V641AC-1 ('69) B15 AT641L-1 ('69) B18 UA320 ('69) B19 VA320 ('69) B19 VA320-P ('69) B21 A320 ('70) B22 KA320 ('70) B22 VA320 ('70) B24 GKA320 ('70) B30 521 ('70) B34 N521 ('70) B39 A321 B39 A321-H B39 UA321-S B40 PA321 B40 PA321-H B40 UPA321 B41 SA321 B41 SA321-H B42 VA321 B42 VA321-SV B42 KA321 B42 GKA321 B42 VA321-SP B42 VA321-S B43 VPA321-SPB B43 VPA321 B43 VPA321SV B43 VPA321P B43 VPA321PB B43 KPA321 B43 GKPA321 B50 620-S B50 620-D B50 620-T B50 N620-S B50 N620 B50 N620-T B53 G620-S B53 G620-D B53 G620-T B53 GN620-S B53 GN620 B53 GN620-T B56 UN620-S B56 UN620
[edit]
C
C03 Q4W73 C49 FH60 C51 VH60
[edit]
E
E01 H130 ('69)
E02 P130 ('69)
E03 P130S ('69)
E04 VP130 ('69)
E05 WP130 ('69)
E06 H130V ('69)
E07 130S ('69)
E08 130P ('69)
E09 Q130 ('69)
E10 Y130 ('69)
E20 C30-S ('69)
E21 C30-ST,C30-T ('69)
E22 C30-SA,C30-A ('69)
E23 C30 ('69)
E30 H130v ('70)
E32 H130 ('70)
E34 130S ('70)
E35 WH130 ('70)
E40 C30SA,C30A ('69.5)
E41 S30 ('70)
E42 PS30 ('70)
E48 C30 ('69.5)
E49 130 ('69.5)
E50 A30S,A30Y,A30P ('70)
E51 VA30 ('70)
E52 VA30,HA30 ('70)
E53 HA30,HA30M ('70)
E54 HA30Q,HA30QM ('70)
E55 HA30QA,HA30QMA ('70)
E56 VHA30 ('70)
E60 C30Sᵂ ('70)
E61 C30 ('70)
E62 C30AT ('70)
E66 KC30-T,KPC30-T
E67 KPC30-AT
E68 KPC30-TK,KPC30ATK
E73 C30-S,C30-SA ('71)
E74 C30,C30-T,C30-A,C30-AT ('71)
E75 C30-H,C30-HT ('71)
E79 S30A
E82 S30
[edit]
G
G01 B20 ('69) G03 C20 G03 C20S G04 C20HS G05 VC20 G05 VC20S G05 VC20VS G06 KC20 G10 B120S ('71) G10 B120 ('71) G11 B120ST ('71) G11 B120T ('71)
[edit]
J
J01 140 ('71) J03 N140 ('71) J04 140G ('71) J10 CHC240 ('72) J11 GC240 ('72) J14 C240R ('72) J15 C240WR ('72)
[edit]
K
K01 710 Sedan '74 K03 710T Sedan '74 4-speed K03 710HT Hardtop '74 4-speed K04 710TK Sedan SSS K05 710S Sedan Standard '74 K06 710Y K07 710P LPG K08 P710AT K09 P710TE K10 710SR 2-door Sedan Standard '74 K11 710R 2-door Sedan '74 K12 P710HRT Sedan '74 K13 K710 Coupe '74 K14 KP710TK 1800SSS K15 KP710TE 1800SSS-E K16 710U Sedan '74 K17 L710 Sedan '74 K18 PL710Y K19 PL710TK LHD SSS K20 NL710TX Sedan '74 K21 KPL710T Coupe '74 K22 P710FK 5-speed SSS K23 KP710GFK K24 HL710TU L20B 4-speed K25 KHL710TU Coupe '74 K26 KHL710TQ K27 P710STU K28 V710S K29 V710 Wagon '74 K30 WP710HT Wagon '74 K31 WP710TU Wagon '74 K32 WHL710TU Wagon '74 K33 WNL710TX K34 WPL710TQ K35 PL710P
[edit]
M
M01 El0R M01 E10 M02 E10RT M03 E10T M04 E10SR M04 E10SRT M04 E10S M04 E10ST M05 VE10SR M05 VE10SRT M06 VE10R M07 VE10RT M08 PE10RTKN M08 PE10TKN M12 E10HRT M12 E10HT M14 KE10T M15 KPE10HT
[edit]
N
N01 P510S ('71) N01 P510ST ('71) N02 P510 ('71) N02 P510T ('71) N03 P510A ('71) N04 P510TK ('71) N04 KP510ATK ('71) N05 KP510TK ('71) N06 WP510A ('71) N07 510 ('71) N08 510 ('71) N09 510 ('71) N10 W510 ('71) N11 510 WAGON ('71) N12 JN510Y ('72) N12 JP510Y ('72) N13 JN510P ('72) N13 JP510P ('72) N16 P510 ('72) N16 N510 ('72) N16 N510T ('72) N16 P510T ('72) N16 P510A ('72) N16 P510AT ('72) N16 RN510 ('72) N16 RN510T ('72) N16 RN510A ('72) N17 P510HT ('72) N17 N510H ('72) N17 N510HT ('72) N17 N510HA ('72) N17 P510H ('72) N17 P510HA ('72) N17 P510HAT ('72) N18 KP510AT ('72) N18 KP510T ('72) N20 P510TK ('72) N20 KP510TK ('72) N21 N510S ('72) N21 N510ST ('72) N21 RN510S ('72) N21 RN510 ('72) N22 ..510 ('72) N23 510 2-DOOR ('72) N24 VN510 ('72) N24 VN510T ('72) N27 510 ('72) N28 510 2-DOOR ('73) N82 ? S110 N84 ? S110 D81 ? S110.Z22E N85 ? S110.U [FED] N87 ? S110.V [CAL]
[edit]
P
P01 230-HK,230-H ('71) P02 230-V ('71) P03 230-Q ('71) P05 N230-S ('71) P07 Q230 ('71) P08 V230 ('71) P09 VN230 ('71) P10 W230 ('71) P11 Y-230-T ('71) P20 K230-HTK,K230-HT ('71) P21 K230-QTK,K230-QT ('71) P25 230-HTK,230-HTK,230-VT,230-QT,W230-T ('71) P26 230-HKA,230-HA,230-VA,230QA,W230-QA,W230-A,V230-A ('71) P27 230-HTKA,230-HTA,230-VTA,W230-TA ('71) P30 H230 ('71) P31 230-VP ('71) P40 230-HG,230-VG,230-QG,N230-SG,N230-PG P41 V230-G,VN230-SG P42 K230-HTG,K230-QTG P71 ? S130 P72 ? S130 P78 ? S130 P79 ? S130 P81 ? S130.U [FED] P82 ? S130.V [CAL] P90 ? S130.L28ET P91 ? S130.J [GL] P95 ? S130.L28ET P97 ? S130.J [GL] P99 ? S130.L28ET
[edit]
R
R01 C10M ('71) R01 PC10M ('71) R01 PC10WA ('71) R01 PC10WAT ('71) R01 C10WT ('71) R01 PC10WT ('71) R01 C10 ('71) R01 C10A ('71) R03 C10S ('71) R03 C10Y ('71) R03 C10P ('71) R07 VC10S ('71) R07 VC10M ('71) R07 VPC10M ('71) R08 VPC10WT ('71) R10 GC10T ('71) R10 GC10AT ('71) R11 KPGC10T R12 C10HT ('72) R12 PC10HT ('72) R14 KGC10TK ('72) R30 C110T ('73) R31 C110 ('73) R32 C110S ('73) R33 PC110T ('73) R34 PC110HT ('73) R35 C110A ('73) R36 C110P ('73) R37 C110HT ('73) R38 PC110AT ('73) R42 KC110HT ('73) R42 KC110HAT ('73) R42 KPC110HT ('73) R42 KPC110HAT('73) R43 VC110 ('73) R43 VC110T ('73) R43 VPC110 ('73) R43 VPC110T ('73) R45 WPC110T ('73) R45 WPC110AT ('73) R46 KGC110T ('73) R47 110TK ('73) R47 KGC110ATK ('73) R50 GC110T ('73) R50 GC110AT ('73) R50 GC110TK ('73) R50 GC110ATK ('73) R51 KGC110AT ('73)
[edit]
T
T01 T20 T01 T20H T03 T20R T03 T20HR T03 T20GR T03 T20GHR T03 HT20GR T03 VT20 T03 VT20G T04 T20GH T05 T20P T07 HT20G
[edit]
U
U01 610 U01 610S 1972 U02 610T U02 610ST U03 610A U04 K610AT U05 610H U06 P610T U06 P610A U06 P610AT U07 P610H U07 P610HT U07 P610HAT U08 P610TK U08 P610ATK U10 K610 U10 K610T U10 K610AT U11 K610HT U11 KP610HT U11 K610HAT U11 KP610HAT U12 KP610TK U12 KP610ATK U13 WP610HT U13 WP610HAT U14 V610 U14 Y610S U14 V610ST U15 610 Sedan U16 610 Wagon U17 610 U19 610 Hardtop U20 610 U23 610 Hardtop U25 610 Wagon 1972 U28 610TK U28 610ATK U29 K610TK U29 K610ATK U34 610 Sedan 1974 U37 610 Sedan 1974 U39 610 1972 U40 610 Sedan 1974 U43 610 U46 610 U48 610 Wagon 1974 U51 610 Sedan 1974 U52 610 Sedan 1974 U56 610 Coupe 1974 U57 610 Coupe 1974 U59 610 Sedan 1974 U60 610 Sedan 1974 U62 610 Wagon 1974 U63 610 Wagon 1974 U64 610 Wagon 1974 U65 610 Wagon 1974 U67 610 1976 U68 610 1976 U69 610 Wagon 1976 U70 610 1976 U73 610 Wagon 1976 U74 J810T/J811T U75 PJ810/PJ811 U76 P811G/P811JFE U77 RG810/PD811/RG811 U78 KRG810J/RG811J/RG811(Y) U80 J810HT/J811HT U81 KJ810/KPJ810,KJ811/KJP811 U83 P810/KP810,KP811G/KP811YFE U84 KRG810,KPD811,KRG811 U86 VJ810 U95 610 1976 U96 610 Sedan 1976 U99 610 Wagon 1976
[edit]
W
W03 PJ810 LPG W04 PJ811/KPJ811 W05 PJ811 LPG W50 A10 W51 A10S W52 A10H W53 PA10, PA10A W54 PA10H, PA10HA W55 PA10HE, PA10HAE W60 KA10 W61 KA10H W62 KPA10H,KPA10HA W63 KPA10HE,KPA10HAE W65 VA10,VA10S,VA10H W70 PA11G,PA11GF W71 PA11G-E W75 PA11 W76 PA11P,RA11 W77 KA11 W78 KPA11G W90 UPA11 ?01 FG101,FG102,FG103
more codes
{{Album|22592}|
[edit]
Sources
Bluebird Parts Catalog (JDM version) 1973.7 edition A,B,G,N,R,T,U 620 JDM parts catalog No. C-234 1977.2 C,E,J-P 810 catalog C-409 U74-U86, W03-W05
