There is no page titled ":Fuses". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 12 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Parts Sources (15979 bytes)
89: ...ng lights, Turn-signal "flasher" unit]], [[Wiring|fuses]], [[Oil]], [[Front Axle|Wheel bearing grease]], ... - Anti-diesel valve (4205 bytes)
31: No: Check your fuses...trace the wires and see why it's not getting po... - Headlight Wiring (9056 bytes)
129: You can get 14-gauge connectors and wires, the fuses and lengths of wire from a wrecking yard. Or buy ...
144: # Comes with the proper fuses and will bypass the stock Fusible Link
153: * Two fuses (or circuit breakers?):
160: # Fix fuses to these two short HOT wires, to protect the rest... - Fuse Box (12018 bytes)
8: '''Fuses'''
9: <br>B110 uses the standard cylindrical fuses used by all cars until around 1980. The numbers a...
26: ...two empty holes in the fuse box to hold two spare fuses.
60: ...w the harness wires go directly to the individual fuses, whereas formerly they ended at large spade conne...
75: Unknown year fuse box used all ten fuses, unlike Japan or - Sunny Truck Model Changes (18380 bytes)
316: * Fuse box with rectangular fuses - KA Engine Swap (19647 bytes)
397: ... connect to the car's wiring via three relays and fuses. - Fusible Link (5066 bytes)
57: ... used as replacement fuses for fusible links. FMX fuses are the female standard cartridges that provide b... - Turn Signal Testing (7003 bytes)
103: ...he Turn Signals use the same lamps, but different fuses. So if they flash on one, but not the other, your... - IR Alternator Conversion Wiring (7659 bytes)
57: ...ff. In any case it should not cause a fire if the Fuses and Fusible Link are all in place. Older Datsun 5... - 620 Headlight Wiring (5837 bytes)
106: = Fuses = - EFI Wiring (7013 bytes)
1: ...f them to connect up. Use severals relays and new fuses. It's a chore but you'll have OEM EFI — pow...
17: = Relays And Fuses =
53: ...is circuit board contains three relays and proper fuses. Relay for fuel pump, ECU relay, etc. Has termina... - $1200 EFI Turbo A12 (18363 bytes)
275: ...ting extra fuses. Just saves a bit of wiring. The fuses are not fitted in the pic.
