There is no page titled ":Hemi". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 13 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Engine Swaps (25633 bytes)
303: ...olet small block and LS, even the mighty Chrysler HEMI — all have been swapped into Datsun 1200s!
389: == Astron Hemi ==
390: The famous Chrysler Hemi 2.6 -- Mitsubishi Astron engine 1974-1997
405: == Toyota Hemi ==
528: <tr><td>Hemi 392</td><td>337 kg</td><td>745 lbs</td></tr> - Bored And Stroked (14763 bytes)
154: E15 with 10mm hemi dish 19x63 pin - AY12 engine (5638 bytes)
15: ...ecial design. Because of the {{wikiEx|Hemi_engine|hemi}} combustion chamber, the pushrod-activated valve...
31: # Using a hemi cylinder head design, the valves are in better po...
33: #The chamber is hemi, it can take more compression without unintended ...
84: {{Album|28755|was=Photo\aycrossflowhemipiston1qo1.jpg}} - V8 (3426 bytes)
4: ...olet small block and LS, even the mighty Chrysler HEMI — all have been swapped into Datsun 1200s!
17: [[#HEMI|#Chrysler 392 HEMI V8]]
54: == HEMI {{RefNo|Hemi|}} ==
55: Chrysler HEMI 392 [[Convertible|Roadster]] - Head Porting (8992 bytes)
81: ...e openings. Some engines (for example, the Street Hemi) has massive flow but poor swirl and didn't run w... - Nissan A Engine (14574 bytes)
67: ...cars used an overbored 1300cc A12, or the special hemi-head AY12 engine.
80: ...he piston was also special design. Because of the hemi combustion chamber, the pushrod-activated valve r... - A12 Engine (4780 bytes)
63: ...cars used an overbored 1300cc A12, or the special hemi-head AY12 engine. - L26 (5354 bytes)
39: ... at {{wiki|Bremerton, Washington}}: 2-dr sedan vs HEMI - Convertible (1813 bytes)
12: HEMI [[V8#Hemi|V8]] powered Datsun 1200 Roadster - Toyota T Engine Swap (1582 bytes)
1: Hemi-head four cylinder. 1970-1985.
4: Before the 4AGE, there was the T series. Alloy hemi-head, durable cast-iron block.
18: Hemi in a 1400 bakkie | 1200 sedan - CCing (4389 bytes)
10: ... available from animal feed stores or your local chemist. Get a couple of syringes one thats about 20mls...
41: ...r. Yes, both are 360-degree 'open', but the term "hemi" refers to valves at 45-degrees to each other (al... - Blown 1200s (1205 bytes)
14: = HEMI =
15: Chrysler Hemi-powered Datsun 1200
17: {{SeeMainArticle|V8#Hemi|26011|MED}} - Trix (2391 bytes)
37: [[Toyota_T_Engine_Swap#Trix]] 2T 1600cc hemi-head motor with twin carburetors
