There is no page titled ":Injector". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Fuel Injection (19606 bytes)
26: * four fuel injectors
61: ...luding high-pressure fuel pump, fuel distributor, injectors/throttle bodies and lines.
141: ...$20 used, [http://www.extrudabody.com/servlet/the-Injectors/Categories $70 new])
167: ...$20 used, [http://www.extrudabody.com/servlet/the-Injectors/Categories $70 new])
182: ...CU and GM sensors. Or fitting Ford TBI with Bosch injectors and a GM brain. - 200SX EFI (13119 bytes)
8: ...y of the parts are available on the 280ZX such as injectors, sensors and fuel pump. See the EGI article for ...
63: Fuel injector
76: * Injector - usually included with used Manifold
181: ...eously and independent of the engine stroke. Each injector supplies half the amount of fuel required by the ...
197: Injector Wiring for the 1981 ECU: - A-series Cylinder Heads (27426 bytes)
534: * Oval Ports with ?notch for injector - 1/4 mile time log (25722 bytes)
909: * Injector:750cc
1051: * 1600cc Injectors
1102: * 12 x 1600cc Injectors - C16 Fuel - EGI (26751 bytes)
198: * has notches at the top for the injectors
566: == Injectors ==
567: See main article: [[Injectors#16603-N7616]]
570: 16612-N8500 HOLDER-INJECTOR [lower] 7910- $6.33 USD
571: * replaced 16612-N4200 HOLDER-INJECTOR -7909 - Carburetor Part Numbers (7751 bytes)
29: 17 16171-25710 WEIGHT INJECTOR A12 CRANK
108: 23 16171-25710 WEIGHT-INJECTOR A12 EXHAUST & EVAPO - DCH Carburetor Part Numbers (7505 bytes)
54: 28 16171-25710 WEIGHT-INJECTOR -672
55: 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710
143: 28 16171-25710 WEIGHT-INJECTOR -672
144: 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710 - Fuel Part Numbers (24315 bytes)
112: * 16171-25710 WEIGHT-INJECTOR 1 A12 EXHAUST & EVAPO -
208: * 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
209: * 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710
295: * 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
296: * 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710 - Hyundai EFI (3787 bytes)
25: ...size all the way through but close up towards the injectors)
50: ....com/catalog/x,carcode,1208045,parttype,6224 Fuel Injector] - Raw List (34158 bytes)
461: 16171-25710 WEIGHT INJECTOR
823: 16171-25710 WEIGHT-INJECTOR
919: 16171-25710 WEIGHT-INJECTOR
920: 16171-H7010 WEIGHT-INJECTOR
1006: 16171-25710 WEIGHT-INJECTOR - MR.12.00 (3716 bytes)
30: * Ford Falcon CFI throttle body (twin injector) - Cylinder Head Part Numbers (24003 bytes)
356: * Medium Oval Ports with notch for injector - 14035 (3030 bytes)
100: ...8x32 mm intake ports (medium oval) with notch for injector - Zenith EFI (3807 bytes)
1: ...buretor-replacement system for Nissan A15 engine (injector and fuel inlet at top)
6: * 15 psi injector
18: 2 GASOLINE INJECTOR (O-RINGS INCL.) C282-366
19: 2A O-RING KIT (GASOLINE INJECTOR & FUEL PRESSURE REG.) C282-14
45: * INJECTOR, GASOLINE (O-RING INCL.) - EFI Manifold (5944 bytes)
57: * Nissan RB30 injectors
68: 35mm motor bike throttle bodies with injectors inbuilt
86: ...75 Hilborn] injection manifold (A15 manifold with injector bosses welded on) - Injectors (11277 bytes)
3: = Injector Sizing =
4: ...utput by boosting fuel pressure, for example some injectors might be safe at 70lbs pressure.
11: With 4 injectors, they need to be 25 lbs/hr
12: ...for 80% operation, you should get 30 lbs/hr rated injectors. If you are planning on raising power output lat...
14: = High or Low Resistance Injectors? = - EGI Wiring (5246 bytes)
18: * Injectors
30: * Injector outputs (4)
127: = Injector Wiring =
128: How the injectors are wired depends on the [[ECU]] you use. The fo...
134: <br>{{Photo|200X_EFI_injectors.jpg|Datsun%201200/wiki/200sxEFI}} - EGI MegaSquirt (4668 bytes)
3: = Manifold and Injectors =
10: * the fuel injectors included
56: * injectors
64: Obtain a dropping resistor pack, and connect to injectors
96: * injector flow rate 188 - Nissan Optical CAS (7489 bytes)
179: ...e donor Nissan. For spark-only control, leave the injector harness unplugged. Custom spark maps cab be progr... - Budget EFI (10125 bytes)
6: = Manifold and Injector =
16: * Fuel Injector ([[Injectors#16600-5L700|365cc]] for stock A12)
20: Injector/Regulator assembly
24: ...ill each end to 14mm opening for the push-in type injector and the push-in type regulator
26: ...PCV opening with 14mm drill bit (for push-in type injector)
