There is no page titled ":Removing". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- QR25DE Engine (6399 bytes)
19: ... with proper exhaust, induction 15hp is freed and removing the counter balance shafts another 10+ hp. That's... - Heater (11024 bytes)
45: * Leaks (before removing, check for leaks in passenger area, under carpet,... - Strut Insert Part Numbers (10856 bytes)
18: ... a factory-quality Strut rebuild kit (rather than removing the factory strut parts and replacing with a new ... - Emission Controls (28459 bytes)
420: ...um at just above idle. This is a good system, and removing it (disconnecting Vacuum Advance) will result in ... - Carburetor Specifications (5963 bytes)
48: Main jets are accessible without removing the carburetor - Choosing A Carburetor (14914 bytes)
17: ...ory Datsun parts. It's easier than most think. By removing the venturi required by a carburetor, maximum air... - Changing Head Gasket (9192 bytes)
7: ...just replacing the gasket, you can get by without removing the intake/exhaust manifolds. However you will ne...
10: ...en all the rockers and remove the pushrods before removing the head bolts. Do not remove the rocker shaft. T... - Engine Troubleshooting Overview (17895 bytes)
162: ...e exhaust and loss of water from the radiator. By removing the radiator cap and allowing the engine to fast ... - Trayback Utes (2462 bytes)
19: Is it as easy has cutting off the quarter panels, removing the tray from the chassis and welding it all up a... - DAS (7541 bytes)
70: <br>The assembly operation consists of first removing a subframe that is on the chassis and carries the... - Camshaft replacement (8570 bytes)
40: = Removing Camshaft =
93: Is there any way to put the camshaft in without removing the engine? - Valve adjustment (7052 bytes)
58: #: Verify which TDC it is at by removing the distributor cap and noting where the rotor po...
74: You can verify which TDC it is at by removing the distributor cap and noting whether the rotor ... - Anti-diesel valve (4205 bytes)
41: ...l run well with this pin removed. The downside to removing the pin is that the engine may want to "run-on" (... - Tools (9147 bytes)
65: For safely removing flare nuts without damage. For brakes lines and h...
70: For removing rounded-off nuts or grabbing stubborn screw by th...
75: For removing that pesky carb nut next to the rocker cover, cut...
80: For removing the nut on the bottom of the [[Engine Mounts]], c... - Engine buildup (10548 bytes)
66: ...''. This is relatively easy -- it doesn't involve removing the engine. - Collapsible Steering Column (1399 bytes)
1: ...g the steering wheel. Special care is needed when removing or installing a collapsible column, as a sharp bl... - Suspension upgrades (19397 bytes)
49: ...actory-quality [[Strut]] rebuild kit (rather than removing the factory strut parts and replacing with a new ... - Universal Joint (5176 bytes)
112: Removing U-joints: Tap them out with a brass drift. It is ... - Brakes (15702 bytes)
79: After removing the hub from the strut, unbolt the four rotor-ret... - Dashboard removal (7203 bytes)
23: ...It also much easier to install a tachometer after removing the dash, but again that could be done by reachin...
27: ...wiring harness from the firewall. I've done it by removing wires from dash/gauges etc. and leaving the harne...
95: = Removing the Dash Pad =
