Main : Members : Gary_P Radiator purge tank
[<   Previous  5  6  7  8  9  10  11  Next   >]
Radiator purge tank
Radiator purge tankPopular
SubmitterGary_PMore Photos from Gary_P   Last Update2006/9/8 2:23    Tell a friendTell a friend
Hits3137  Comments2    0.00 (0 votes)0.00 (0 votes)
The Volkswagen cooling system uses a purge tank. as such you have to add one to use the Golf radiator. There is no fill provisions on the radiator. The purge tank has a small line from the top of the radiator to let the air out of the system and a larger line that that goes into the lower radiator hose someware. I connected the purge tank outlet line into the heater hose that returns to the lower radiator hose. The Golf purge tank is a nice little round unit but uses a bracket that is welded into the Golf. I found that one of the Audi's, a 5000 IIRC has a purge tank that bolts on to a flat surface. The Audi tank is working for now but I plan on putting a Golf purge tank in when the battery is moved to the trunk.
Posted: 2012/2/16 22:12  Updated: 2012/2/16 22:13
 Re: Radiator purge tank
Can you tell us more about the tank connections? Where does the top line connect? Is it a pressure tank?
Bottom line tees into lower radiator hose.
98 Jetta tank
Gary_P
Posted: 2012/8/7 4:33  Updated: 2012/8/7 4:34
The top hose connects to the top of the radiator. The VW radiators have a small hose connection right by the main inlet hose. The tank is pressurized in normal usage.
I've found that many of the Volvo's use a similar tank.
Picture 11 shows the top hose connection to the radiator.
Sorry about the slow reply, haven't logged in in a long time...
