Main : Mechanical : Engine WATER LEAK in 120y ENGINE HEAD
[<   Previous  2283  2284  2285  2286  2287  2288  2289  Next   >]
WATER LEAK in 120y ENGINE HEADPopular
SubmitterFAZPIOESMore Photos from FAZPIOES   Last Update2007/1/17 18:52    Tell a friendTell a friend
Hits2688  Comments2    0.00 (0 votes)0.00 (0 votes)
You may see in the arrow where the WATER started to leak , between the two valve sits . How could that HAPPEN ???
So screw has been removed and aluminium welded - looks good now .
Allso I took the chance to cut 0.02 milimiters to the head  ...
jaimecidpedro
Posted: 2007/1/17 19:26  Updated: 2007/1/17 19:26
 Re: WATER LEAK in 120y ENGINE HEAD
That is most unfortunate...but good you took care of it. Where you having water clouds as you drove?? or was it a subtle but steady leak???
FAZPIOES
Posted: 2007/1/17 22:50  Updated: 2007/1/17 22:50
- Lots of white smoke coming from Air Filter
- All Water from Radiator mixed with Engine Oil
- Drove > 20 kms home like this - engine running great with this sound of a wash machine : Tchloc Tchloc .
At first I thought engine block was broken , but when I took head cover out, adding water to radiator I could see it all coming inside the block through this hole .
Must be factory defect , or rust - the other screws areas are ok ...
